查看: 6277|回复: 17
[工具箱] matlab 工具箱大全
发表于 2011-2-15 18:10 | 显示全部楼层 |阅读模式
【转贴】Matlab 工具箱大全-一旦拥有,别无所求
在这里
http://stommel.tamu.edu/~baum/toolboxes.html
内容有
Matlab Toolboxes
ADCPtools - acoustic doppler current profiler data processing
AFDesign - designing analog and digital filters
AIRES - automatic integration of reusable embedded software
Air-Sea - air-sea flux estimates in oceanography
Animation - developing scientific animations
ARfit - estimation of parameters and eigenmodes of multivariate autoregressive methods
ARMASA - power spectrum estimation
AR-Toolkit - computer vision tracking
Auditory - auditory models
b4m - interval arithmetic
Bayes Net - inference and learning for directed graphical models
Binaural Modeling - calculating binaural cross-correlograms of sound
Bode Step - design of control systems with maximized feedback
Bootstrap - for resampling, hypothesis testing and confidence interval estimation
BrainStorm - MEG and EEG data visualization and processing
BSTEX - equation viewer
CALFEM - interactive program for teaching the finite element method
Calibr - for calibrating CCD cameras
Camera Calibration
Captain - non-stationary time series analysis and forecasting
CHMMBOX - for coupled hidden Markov modeling using maximum likelihood EM
Classification - supervised and unsupervised classification algorithms
CLOSID
Cluster - for analysis of Gaussian mixture models for data set clustering
Clustering - cluster analysis
ClusterPack - cluster analysis
COLEA - speech analysis
CompEcon - solving problems in economics and finance
Complex - for estimating temporal and spatial signal complexities
Computational Statistics
Coral - seismic waveform analysis
DACE - kriging approximations to computer models
DAIHM - data assimilation in hydrological and hydrodynamic models
Data Visualization
DBT - radar array processing
DDE-BIFTOOL - bifurcation analysis of delay differential equations
Denoise - for removing noise from signals
DiffMan - solving differential equations on manifolds
Dimensional Analysis -
DIPimage - scientific image processing
Direct - Laplace transform inversion via the direct integration method
DirectSD - analysis and design of computer controlled systems with process-oriented models
DMsuite - differentiation matrix suite
DMTTEQ - design and test time domain equalizer design methods
DrawFilt - drawing digital and analog filters
DSFWAV - spline interpolation with Dean wave solutions
DWT - discrete wavelet transforms
EasyKrig
Econometrics
EEGLAB
EigTool - graphical tool for nonsymmetric eigenproblems
EMSC - separating light scattering and absorbance by extended multiplicative signal correction
Engineering Vibration
FastICA - fixed-point algorithm for ICA and projection pursuit
FDC - flight dynamics and control
FDtools - fractional delay filter design
FlexICA - for independent components analysis
FMBPC - fuzzy model-based predictive control
ForWaRD - Fourier-wavelet regularized deconvolution
FracLab - fractal analysis for signal processing
FSBOX - stepwise forward and backward selection of features using linear regression
GABLE - geometric algebra tutorial
GAOT - genetic algorithm optimization
Garch - estimating and diagnosing heteroskedasticity in time series models
GCE Data - managing, analyzing and displaying data and metadata stored using the GCE data structure specification
GCSV - growing cell structure visualization
GEMANOVA - fitting multilinear ANOVA models
Genetic Algorithm
Geodetic - geodetic calculations
GHSOM - growing hierarchical self-organizing map
glmlab - general linear models
GPIB - wrapper for GPIB library from National Instrument
GTM - generative topographic mapping, a model for density modeling and data visualization
GVF - gradient vector flow for finding 3-D object boundaries
HFRadarmap - converts HF radar data from radial current vectors to total vectors
HFRC - importing, processing and manipulating HF radar data
Hilbert - Hilbert transform by the rational eigenfunction expansion method
HMM - hidden Markov models
HMMBOX - for hidden Markov modeling using maximum likelihood EM
HUTear - auditory modeling
ICALAB - signal and image processing using ICA and higher order statistics
Imputation - analysis of incomplete datasets
IPEM - perception based musical analysis
JMatLink - Matlab Java classes
Kalman - Bayesian Kalman filter
Kalman Filter - filtering, smoothing and parameter estimation (using EM) for linear dynamical systems
KALMTOOL - state estimation of nonlinear systems
Kautz - Kautz filter design
Kriging
LDestimate - estimation of scaling exponents
LDPC - low density parity check codes
LISQ - wavelet lifting scheme on quincunx grids
LKER - Laguerre kernel estimation tool
LMAM-OLMAM - Levenberg Marquardt with Adaptive Momentum algorithm for training feedforward neural networks
Low-Field NMR - for exponential fitting, phase correction of quadrature data and slicing
LPSVM - Newton method for LP support vector machine for machine learning problems
LSDPTOOL - robust control system design using the loop shaping design procedure
LS-SVMlab
LSVM - Lagrangian support vector machine for machine learning problems
Lyngby - functional neuroimaging
MARBOX - for multivariate autogressive modeling and cross-spectral estimation
MatArray - analysis of microarray data
Matrix Computation - constructing test matrices, computing matrix factorizations, visualizing matrices, and direct search optimization
MCAT - Monte Carlo analysis
MDP - Markov decision processes
MESHPART - graph and mesh partioning methods
MILES - maximum likelihood fitting using ordinary least squares algorithms
MIMO - multidimensional code synthesis
Missing - functions for handling missing data values
M_Map - geographic mapping tools
MODCONS - multi-objective control system design
MOEA - multi-objective evolutionary algorithms
MS - estimation of multiscaling exponents
Multiblock - analysis and regression on several data blocks simultaneously
Multiscale Shape Analysis
Music Analysis - feature extraction from raw audio signals for content-based music retrieval
MWM - multifractal wavelet model
NetCDF
Netlab - neural network algorithms
NiDAQ - data acquisition using the NiDAQ library
NEDM - nonlinear economic dynamic models
NMM - numerical methods in Matlab text
NNCTRL - design and simulation of control systems based on neural networks
NNSYSID - neural net based identification of nonlinear dynamic systems
NSVM - newton support vector machine for solving machine learning problems
NURBS - non-uniform rational B-splines
N-way - analysis of multiway data with multilinear models
OpenFEM - finite element development
PCNN - pulse coupled neural networks
Peruna - signal processing and analysis
PhiVis - probabilistic hierarchical interactive visualization, i.e. functions for visual analysis of multivariate continuous data
Planar Manipulator - simulation of n-DOF planar manipulators
PRTools - pattern recognition
psignifit - testing hyptheses about psychometric functions
PSVM - proximal support vector machine for solving machine learning problems
Psychophysics - vision research
PyrTools - multi-scale image processing
RBF - radial basis function neural networks
RBN - simulation of synchronous and asynchronous random boolean networks
ReBEL - sigma-point Kalman filters
Regression - basic multivariate data analysis and regression
Regularization Tools
Regularization Tools XP
Restore Tools
Robot - robotics functions, e.g. kinematics, dynamics and trajectory generation
Robust Calibration - robust calibration in stats
RRMT - rainfall-runoff modelling
SAM - structure and motion
Schwarz-Christoffel - computation of conformal maps to polygonally bounded regions
SDH - smoothed data histogram
SeaGrid - orthogonal grid maker
SEA-MAT - oceanographic analysis
SLS - sparse least squares
SolvOpt - solver for local optimization problems
SOM - self-organizing map
SOSTOOLS - solving sums of squares (SOS) optimization problems
Spatial and Geometric Analysis
Spatial Regression
Spatial Statistics
Spectral Methods
SPM - statistical parametric mapping
SSVM - smooth support vector machine for solving machine learning problems
STATBAG - for linear regression, feature selection, generation of data, and significance testing
StatBox - statistical routines
Statistical Pattern Recognition - pattern recognition methods
Stixbox - statistics
SVM - implements support vector machines
SVM Classifier
Symbolic Robot Dynamics
TEMPLAR - wavelet-based template learning and pattern classification
TextClust - model-based document clustering
TextureSynth - analyzing and synthesizing visual textures
TfMin - continous 3-D minimum time orbit transfer around Earth
Time-Frequency - analyzing non-stationary signals using time-frequency distributions
Tree-Ring - tasks in tree-ring analysis
TSA - uni- and multivariate, stationary and non-stationary time series analysis
TSTOOL - nonlinear time series analysis
T_Tide - harmonic analysis of tides
UTVtools - computing and modifying rank-revealing URV and UTV decompositions
Uvi_Wave - wavelet analysis
varimax - orthogonal rotation of EOFs
VBHMM - variation Bayesian hidden Markov models
VBMFA - variational Bayesian mixtures of factor analyzers
VMT - VRML Molecule Toolbox, for animating results from molecular dynamics experiments
VOICEBOX
VRMLplot - generates interactive VRML 2.0 graphs and animations
VSVtools - computing and modifying symmetric rank-revealing decompositions
WAFO - wave analysis for fatique and oceanography
WarpTB - frequency-warped signal processing
WAVEKIT - wavelet analysis
WaveLab - wavelet analysis
Weeks - Laplace transform inversion via the Weeks method
WetCDF - NetCDF interface
WHMT - wavelet-domain hidden Markov tree models
WInHD - Wavelet-based inverse halftoning via deconvolution
WSCT - weighted sequences clustering toolkit
XMLTree - XML parser
YAADA - analyze single particle mass spectrum data
ZMAP - quantitative seismicity analysis
发表于 2011-2-15 21:09 | 显示全部楼层
发表于 2011-2-16 17:30 | 显示全部楼层
真看不出来这个东西有什么用处
发表于 2011-2-22 10:00 | 显示全部楼层
有么有关于二维矩阵反卷积的呢
发表于 2011-3-18 10:57 | 显示全部楼层
怎么没找到偏微分工具箱?
发表于 2011-3-18 12:07 | 显示全部楼层
有么有关于二维矩阵反卷积的呢
发表于 2011-3-18 21:52 | 显示全部楼层
发表于 2011-3-26 09:09 | 显示全部楼层
挺好的啊谢谢楼主
发表于 2011-4-3 09:55 | 显示全部楼层
看到matlab功能的强大了
发表于 2011-4-3 10:40 | 显示全部楼层
matlab的这潭水很深呢!
发表于 2011-6-7 21:30 | 显示全部楼层
在这里
谢谢您的分享
感觉matlab功能太强大
发表于 2011-9-26 11:11 | 显示全部楼层
感谢分享!
发表于 2011-9-29 08:13 | 显示全部楼层
如果有实例就更好了,尤其是对于像我这样的初学者,哈哈,谢谢分享啊。
发表于 2011-10-20 16:34 | 显示全部楼层
发表于 2011-12-6 11:55 | 显示全部楼层
不得不收藏,备用。。。虽然我用的没找到
GMT+8, 2025-1-6 14:18 , Processed in 0.068255 second(s), 17 queries , Gzip On.
