查看: 4271|回复: 3
请问一下在fmincon中exitflag=5的问题?
发表于 2006-4-7 09:15 | 显示全部楼层 |阅读模式
什么意思,怎么解决呢?<BR>Magnitude of directional derivative was less than the specified tolerance and constraint violation was less than options.TolCon. <BR>
发表于 2006-4-7 17:29 | 显示全部楼层
回复:(appla)请问一下在fmincon中exitflag=5的问题...
exitflagDescribes the exit condition:<BR>&gt; 0The function converged to a solution <BR>= 0The maximum number of function evaluations or iterations was exceeded.<BR>&lt; 0The function did not converge to a solution.
 楼主| 发表于 2006-4-8 10:13 | 显示全部楼层
回复:(darcy)回复:(appla)请问一下在fmincon中e...
<P>谢谢楼上的,但是&gt;0收敛于一点并不意味着就是它的最优解吧,在我的程序中出现过好几次exitflag=5,或者是4,<BR>说它的约束小于给定的TolCon设置,那么=5的时候取得的解可以认为是最优解吗?</P>
发表于 2006-4-8 14:50 | 显示全部楼层
应该是说在可行域内达到了最优解
GMT+8, 2025-1-19 07:53 , Processed in 0.066680 second(s), 17 queries , Gzip On.
