查看: 1542|回复: 3
[综合讨论] 对边简支对边自由板的模态
发表于 2010-12-8 13:57 | 显示全部楼层 |阅读模式
MXPAND,8                       ! EXPAND FIRST MODE
MODOPT,REDUC,5,,,2             ! PRINT ALL REDUCED MODE SHAPES
MP,EX,1,2E11
MP,DENS,1,7.86E3
MP,NUXY,1,0.3
K,1,,0                         !Defines a keypoint,NPT, X, Y;
K,2,0.38,0
KGEN,2,1,2,1,,0.3              !产生额外的2个keypoint,DY=0.6
L,1,3                          !Defines line
L,2,4
LESIZE,ALL,,,8                 ! 分割线段, NL1=all,ndiv=8;
A,1,2,4,3                      ! 分割线段的关键点走向,1,2点,4,3点直线
ESIZE,,8                       ! 定义默认线段划分数 NDIV=4
AMESH,1                        ! Generates nodes and area elements within areas
NSEL,S,LOC,Y,0.3               ! 选择一系列点,S 选择新的系列,Y =0.3
M,ALL,UZ                       ! Defines master degrees of freedom for reduced and superelement generation analyses.
/pnum,line,1                   !Controls entity numbering/coloring on plots.
LPLOT, All
dl,2,,uz                       !Defines DOF constraints on lines. DL, LINE, AREA, Lab, Value1, Value2
dl,2,,Rotx
dl,1,,ux                       !Defines DOF constraints on lines. DL, LINE, AREA, Lab, Value1, Value2
dl,1,,Roty
UTPR,ALL,1
FINISH
*CREATE,SOLVIT,MAC             ! CREATE MACRO TO SOLVE AND RETRIEVE RESULTS
/SOLU
SOLVE
*GET,FREQ,MODE,1,FREQ
*DIM,LABEL,CHAR,1,2
*DIM,VALUE,,1,3
LABEL(1,1) = '     f, '
LABEL(1,2) = 'Hz      '
*VFILL,VALUE(1,1),DATA,128.09
*VFILL,VALUE(1,2),DATA,FREQ
*VFILL,VALUE(1,3),DATA,ABS(FREQ/128.09)
FINISH
*END
SOLVIT                         ! EXECUTE MACRO TO SOLVE AND RETRIEVE RESULTS
我做了一个关于对边简支对边自由的板的模态分析
但是结果和别人做的有差异
请帮我看看哪里有问题,x=0,x=0.38简支,y=0,y=0.3自由
 楼主| 发表于 2010-12-8 13:58 | 显示全部楼层
发表于 2010-12-8 14:43 | 显示全部楼层
把你的结果和单元类型贴出来,再看问题
 楼主| 发表于 2010-12-8 17:18 | 显示全部楼层
/PREP7
SMRT,OFF
/units,si
/TITLE, VM66, VIBRATION OF A FLAT PLATE
C***          VIBRATION PROBS. IN ENGR., TIMOSHENKO, 3RD. ED., PAGE 338, ART. 53
C***          USING SHELL63 ELEMENTS WITH SHELL OPTION
ANTYPE,MODAL                   ! MODE-FREQUENCY ANALYSIS
ET,1,SHELL63
R,1,0.002                      ! THICKNESS = 0.002
MODOPT,LANB,5,,,2             ! PRINT ALL REDUCED MODE SHAPES
MP,EX,1,2E11
MP,DENS,1,7.86E3
MP,NUXY,1,0.3
K,2,0.38,0
L,1,3                          !Defines line
L,2,4
!NSEL,S,LOC,Y,0.15              ! 选择一系列点,S 选择新的系列,Y =0.3
!M,ALL,UZ                       ! Defines master degrees of freedom for reduced and superelement generation analyses.
LPLOT, All
dl,2,,uz                       !Defines DOF constraints on lines. DL, LINE, AREA, Lab, Value1, Value2(x=0.38)
dl,1,,ux                       !Defines DOF constraints on lines. DL, LINE, AREA, Lab, Value1, Value2(x=0)
dl,1,,uy
dl,1,,uz
dl,1,,Rotx
dl,1,,Rotz
BETAD,0.01
UTPR,ALL,1
FINISH
/SOLU
SOLVE
*DIM,LABEL,CHAR,1,2
*DIM,VALUE,,1,3
LABEL(1,1) = '     f, '
LABEL(1,2) = 'Hz      '
FINISH
*END
SAVE,TABLE_1
GMT+8, 2025-1-11 16:48 , Processed in 0.068055 second(s), 21 queries , Gzip On.
