查看: 2732|回复: 2
[综合讨论] 求指教:ansys中管道的例子
发表于 2010-11-28 20:55 | 显示全部楼层 |阅读模式
各位:小弟在做一个ansys帮助中管道的例子,命令流如下:
/FILNAM,SAMPLE              更改文件名称
/TITLE, SAMPLE PIPING INPUT
/UNITS,BIN   ! A reminder that consistent units are U. S. Customary inches
/PREP7
! Define material properties for pipe elements
MP,EX,1,30e6
MP,PRXY,1,0.3
MP,ALPX,1,8e-6      !thermal expansion coefficient 热膨胀系数
MP,DENS,1,.283
PUNIT,1        ! Units will be read as ft+in+fraction and converted to
                   ! decimal inches
PSPEC,1,8,STD      ! 8" standard pipe
POPT,B31.1         ! Piping analysis standard: ANSI B31.1
PTEMP,200          ! Temperature = 200°
PPRES,1000         ! Internal pressure = 1000 psi
PDRAG,,,-.2    ! Drag = 0.2 psi in -Z direction at any height (Y)
BRANCH,1,0+12,0+12 ! Start first pipe run at (12",12",0")
RUN,,7+4           ! Run 7'-4" in +Y direction
RUN,9+5+1/2        ! Run 9'-5 1/2" in +X direction
RUN,,,-8+4         ! Run 8'-4" in -Z direction
RUN,,8+4           ! Run 8'-4" in +Y direction
/PNUM,NODE,1       !图示节点及编号
/VIEW,1,1,2,3
EPLOT              ! Identify node number at which 2nd run starts
BRANCH,4           ! Start second pipe run at node 4
RUN,6+2+1/2        ! Run 6'-2 1/2" in +X direction
TEE,4,WT           ! Insert a tee at node 4   T形管
/PNUM,DEFA         恢复编号为默认值
/PNUM,ELEM,1
EPLOT           ! Identify element numbers for bend and miter inserts
BEND,1,2,SR     ! Insert a "short-radius" bend between elements 1 and 2
MITER,2,3,LR,2   ! Insert a two-piece miter between elements 2 and 3
/PNUM,DEFA
/PNUM,NODE,1
! Zoom in on miter bend to identify nodes for spring hangers
/ZOOM,  1,  242.93    ,  206.62    , -39.059    ,  26.866
PSPRNG,14,TRAN,1e4,,0+12     ! Insert Y-direction spring at node 14
PSPRNG,16,TRAN,1e4,,0+12     ! Insert Y-direction spring at node 16
! List and display interpreted input data
/AUTO
/PNUM,DEFA
EPLOT
NLIST
ELIST
SFELIST        !面载荷   surface loads
BFELIST        !体载荷   body
遇到问题整理如下:
1、        POPT,B31.1  此行进行选择时,有两种标准。该怎样选用??
2、        EPLOT是否即PLOT-REPLOT??
3、        /PNUM,DEFA 回复标号为默认值 有何作用? 不用也可以吧??
4、        SR  LR即半径大小 有何区分标准  如何确定??
5、        最后两行 为何会有载荷  这里并没有定义载荷呀??
6、        单位问题  这里单位用的是英制单位 用起来很不方便 若用国标,可以吗?若可以 第三行和第十行要怎样改呢??
7、        此题如要继续分析模态该怎样进行??我做了下 没做对 ^_^
8、        PDRAG  为外部流体载荷 是什么意思该怎样计算其数值??什么情况下用到??
问题较多,望各位就自己会的问题尽情讨论,不吝赐教!!可以把做的资料发我邮箱  jihejiong@126.com    共同进步,谢谢哈~~~
发表于 2010-11-29 10:07 | 显示全部楼层
B31.1指ASME B31.1标准,动力管道,还有B31.3工艺 管道,具体选那个要根据你管道设计的标准来。
查help
查help
弯头类型,看你选那种型号弯头,有相应标准。
查help,只是列表显示载荷
自己统一标准
看模态分析方法
没用过这个命令,不清楚。
PS:做管道和压力容器的应力分析,不清楚相应的设计计算标准最好不要想当然的去做。
 楼主| 发表于 2010-12-4 11:11 | 显示全部楼层
再次请教 PSPRNG,14,TRAN,1e4,,0+12  中   1..TRAN和ROT有什么区别?? 2..0+12意思是不是指 支撑的高度??    请不吝赐教!!
GMT+8, 2025-1-27 06:31 , Processed in 0.089144 second(s), 21 queries , Gzip On.
