查看: 2643|回复: 3
[1stopt] 请DINGDA老师帮忙!!
发表于 2010-10-31 09:11 | 显示全部楼层 |阅读模式
这里面有函数嵌套,不知我的输入是否表达有误,输入1STOPT里没有反映,请DINGDA老师帮忙!!谢谢啊!
Title "00";
Parameters a,b,c,d;
Variable x,y1;
VarParameter y2,y3,y4,y5;
SharedModel;
Function
y1=(y3*x*0.56495325+y2*(0.549452555-x)*(0.02438585+0.025909*(1/(1+(x/a)^(-b*0.84276))))+y4*0.450547445*d)/(y3*x+y2*(0.549452555-x)+y4*0.450547445);
y2=(1/3)*(2/(1+((0.02438585+0.025909*(1/(1+(x/a)^(-b*0.84276))))/y5-1)*c)+1/(1+((0.02438585+0.025909*(1/(1+(x/a)^(-b*0.84276))))/y5-1)*(1-2*c)));
y3=(1/3)*(2/(1+(0.56495325/y5-1)*c)+1/(1+(0.56495325/y5-1)*(1-2*c)));
y4=(1/3)*(2/(1+(d/y5-1)*c)+1/(1+(d/y5-1)*(1-2*c)));
y5=0.02438585+0.025909*(1/(1+(x/a)^(-b*0.84276)))+(1/(1+(x/a)^(-b*0.84276)))*(0.56495325-(0.02438585+0.025909*(1/(1+(x/a)^(-b*0.84276)))));
data;
x,y1=
0.0620         0.288
0.1276         0.437
0.1742         0.532
0.2096         0.577
0.3286         0.74
0.3694         0.884
0.3927         0.972
0.4371         1.143
0.5253         1.223
0.5322         1.204
enddataset;
发表于 2010-10-31 12:58 | 显示全部楼层
正确代码如下:
  1. Title "00";
  2. Parameters a,b,c,d;
  3. ConstStr y5=0.02438585+0.025909*(1/(1+(x/a)^(-b*0.84276)))+(1/(1+(x/a)^(-b*0.84276)))*(0.56495325-(0.02438585+0.025909*(1/(1+(x/a)^(-b*0.84276))))),
  4.         y2=(1/3)*(2/(1+((0.02438585+0.025909*(1/(1+(x/a)^(-b*0.84276))))/y5-1)*c)+1/(1+((0.02438585+0.025909*(1/(1+(x/a)^(-b*0.84276))))/y5-1)*(1-2*c))),
  5.         y3=(1/3)*(2/(1+(0.56495325/y5-1)*c)+1/(1+(0.56495325/y5-1)*(1-2*c))),
  6.         y4=(1/3)*(2/(1+(d/y5-1)*c)+1/(1+(d/y5-1)*(1-2*c)));
  7. Variable x,y1;
  8. Function y1=(y3*x*0.56495325+y2*(0.549452555-x)*(0.02438585+0.025909*(1/(1+(x/a)^(-b*0.84276))))+y4*0.450547445*d)/(y3*x+y2*(0.549452555-x)+y4*0.450547445);
  9. data;
  10. //x,y1=
  11. 0.0620         0.288
  12. 0.1276         0.437
  13. 0.1742         0.532
  14. 0.2096         0.577
  15. 0.3286         0.74
  16. 0.3694         0.884
  17. 0.3927         0.972
  18. 0.4371         1.143
  19. 0.5253         1.223
  20. 0.5322         1.204
结果:
(RMSE): 0.0145181338831429
(SSE): 0.00210776211448863
(R): 0.999013104343221
(R^2): 0.99802718264948
a        0.00931437175129268
b        -2.1702014929257
c        -0.0483359679641019
d        0.509969766796357
 楼主| 发表于 2010-10-31 14:02 | 显示全部楼层
dingd 老师 ,为什么我的计算结果和你不一样呢?我用的都是默认的算法和设置每次计算的结果也不相同,结果差别挺大,我用的1.5注册版,是版本的原因吗?还是应该给参数设定合适的范围才能正确计算?
"00"
迭代数: 21
计算用时(时:分:秒:微秒): 00:00:51:766
优化算法: 麦夸特法(Levenberg-Marquardt) + 通用全局优化法
计算结束原因: 达到收敛判断标准
均方差(RMSE): 0.0279012042685422
残差平方和(SSE): 0.00778477199634917
相关系数(R): 0.996179760369045
相关系数之平方(R^2): 0.992374114968929
决定系数(DC): 0.992334050225161
卡方系数(Chi-Square): 0.00879228169472202
F统计(F-Statistic): 1041.05856400985
参数        最佳估算
a                  0.533218831963338
b                  -2.91167052961833
c                  0.89603882971316
d                  -0.264388098152993
====== 结果输出 =====
No        实测值y1        计算值y1
1        0.288        0.3443463
2        0.437        0.4264247
3        0.532        0.4917516
4        0.577        0.5457608
5        0.74        0.7796007
6        0.884        0.8938094
7        0.972        0.9697738
8        1.143        1.1286227
9        1.223        1.2271294
10        1.204        1.2009908
发表于 2010-11-2 17:59 | 显示全部楼层
这道题要到达2楼的结果还是很困难的,多算几次,我用4.0版,有大约一半的成功概率。(用其他软件,几乎无可能)。
GMT+8, 2024-12-28 13:26 , Processed in 0.094816 second(s), 18 queries , Gzip On.
