查看: 1547|回复: 2
[结构分析] 帮忙看下错误提示
发表于 2010-10-30 20:26 | 显示全部楼层 |阅读模式
*** WARNING ***                         CP =       7.266   TIME= 14:19:07
Element 4 has a diameter to thickness ratio less than 20.  The assumed
thin-walled pipe theory may not be valid.
  Check real constant table 1.
*** ERROR ***                           CP =       7.266   TIME= 14:19:07
Element 4 has a subtended angle that is too large.
  Check node locations and third constant in real constant table 1.
 楼主| 发表于 2010-10-30 20:27 | 显示全部楼层
命令流如下:
/PREP7
ET,1,PIPE60
R,1,57,3.5,150,
MP,EX,1,,2e11
MP,PRXY,1,,0.3
MP,DENS,1,,7850
ET,2,PIPE16
R,2,57,3.5,0,0,0,1142,
N,1,,,,,,,
N,2,,200,,,,,
TYPE,   2
MAT,       1
REAL,       2
ESYS,       0
SECNUM,
TSHAP,LINE
FLST,2,2,1
FITEM,2,1
FITEM,2,2
NWPAVE,       2
N,3,,112,,,,,
TYPE,   2
MAT,       1
REAL,       2
ESYS,       0
SECNUM,
TSHAP,LINE
FLST,2,2,1
FITEM,2,2
FITEM,2,3
NWPAVE,       3
N,4,150,0,,,,,
N,5,229.18,127.4,,,,,
TYPE,   1
MAT,       1
REAL,       1
ESYS,       0
SECNUM,
TSHAP,ARC
FLST,2,3,1
FITEM,2,3
FITEM,2,5
FITEM,2,4
NWPAVE,       5
N,6,500,-310.77,,,,,
TYPE,   2
MAT,       1
REAL,       2
ESYS,       0
SECNUM,
TSHAP,LINE
FLST,2,2,1
FITEM,2,5
FITEM,2,6
NWPAVE,       6
N,7,-79.18,-127.4,,,,,
NWPAVE,       7
N,8,150,0,,,,,
TYPE,   1
MAT,       1
REAL,       1
ESYS,       0
SECNUM,
TSHAP,ARC
FLST,2,3,1
FITEM,2,6
FITEM,2,8
FITEM,2,7
NWPAVE,       8
N,9,0,-12000,,,,,
TYPE,   2
MAT,       1
REAL,       2
ESYS,       0
SECNUM,
TSHAP,LINE
FLST,2,2,1
FITEM,2,8
FITEM,2,9
NWPAVE,       9
N,10,150,0,,,,,
N,11,150,-150,,,,,
TYPE,   1
MAT,       1
REAL,       1
ESYS,       0
SECNUM,
TSHAP,ARC
FLST,2,3,1
FITEM,2,9
FITEM,2,11
FITEM,2,10
NWPAVE,      11
N,12,1000,0,,,,,
TYPE,   2
MAT,       1
REAL,       2
ESYS,       0
SECNUM,
TSHAP,LINE
FLST,2,2,1
FITEM,2,11
FITEM,2,12
NWPAVE,      12
N,12,200,0,,,,,
TYPE,   2
MAT,       1
REAL,       2
ESYS,       0
SECNUM,
TSHAP,LINE
N,13,0,0,,,,,
FLST,2,2,1
FITEM,2,13
FITEM,2,12
CSYS,0
WPAVE,0,0,0
SAVE
FINISH
/SOL
FLST,2,1,1,ORDE,1
FITEM,2,13
D,P51X, , , , , ,UX,UY,UZ,ROTX,ROTY,ROTZ
FLST,2,1,1,ORDE,1
FITEM,2,2
FLST,2,1,1,ORDE,1
FITEM,2,2
D,P51X, ,-7, , , ,UY, , , , ,
GPLOT
/STATUS,SOLU
SOLVE
 楼主| 发表于 2010-10-30 20:30 | 显示全部楼层
我想用pipe16和pipe60做管道的应力分析,但是用pipe60做弯管时,如果弯管的角度大于90°,就会有错误提示显示角度过大,但是我又不知道大于90°的角度要用哪个pipe元素,哪位高手指点下哈!
GMT+8, 2025-1-11 16:49 , Processed in 0.059311 second(s), 17 queries , Gzip On.
