查看: 1450|回复: 1
[前后处理] 槽钢结构网格划分时出现的问题
发表于 2010-10-27 22:12 | 显示全部楼层 |阅读模式
我在对一个模型进行网格划分时,出现了如下警告,请各位大侠给解释一下,谢谢!
solid 95单元,210e9模量,0.3泊松比
D:\My Documents\My Pictures\未命名.bmp
  <<<<<<       FOR NEW OR MODIFIED ELEMENTS       >>>>>>
                   |  Element count      9201 SOLID95   |
Test                Number tested  Warning count  Error count    Warn+Err %
Aspect Ratio               9201              0             0         0.00 %
Maximum Angle              9201              1             0         0.01 %
Jacobian Ratio             9201              0             0         0.00 %
Any                        9201              1             0         0.01 %
*** WARNING ***                         CP =       5.219   TIME= 22:00:12
Shape testing revealed that 1 of the 9201 new or modified elements
violate shape warning limits.  To review test results, please see the
output file or issue the CHECK command.
PRODUCE ELEMENT PLOT IN DSYS =   0
USER SCALING FOR WINDOW  1
   DISTANCE =    684.0
   FOCUS POINT =    175.0       0.000       110.0
view point for window  1   0.79719    -0.29100     0.52896
ROTATION ANGLE FOR WINDOW 1 IS   -26.26 ABOUT AXIS ZS
DISTANCE MULTIPLIER FOR WINDOW 1   1.082
DISTANCE FOR WINDOW 1   740.3
DISTANCE FOR WINDOW 1   801.1
DISTANCE FOR WINDOW 1   867.0
DISTANCE MULTIPLIER FOR WINDOW 1  0.9240
DISTANCE FOR WINDOW 1   684.0
DISTANCE FOR WINDOW 1   632.0
DISTANCE FOR WINDOW 1   584.0
DISTANCE FOR WINDOW 1   539.7
DISTANCE FOR WINDOW 1   498.6
view point for window  1   0.60345    -0.19726     0.77262
ROTATION ANGLE FOR WINDOW 1 IS   -21.81 ABOUT AXIS ZS
view point for window  1   0.44704    -0.33138E-01 0.89390
ROTATION ANGLE FOR WINDOW 1 IS   -20.38 ABOUT AXIS ZS
view point for window  1   0.11290     0.28683     0.95131
ROTATION ANGLE FOR WINDOW 1 IS   -22.28 ABOUT AXIS ZS
DISTANCE FOR WINDOW 1   460.8
DISTANCE FOR WINDOW 1   425.8
DISTANCE FOR WINDOW 1   393.4
DISTANCE FOR WINDOW 1   363.5
DISTANCE FOR WINDOW 1   335.9
DISTANCE FOR WINDOW 1   310.4
DISTANCE FOR WINDOW 1   286.8
DISTANCE FOR WINDOW 1   265.0
DISTANCE FOR WINDOW 1   244.9
DISTANCE FOR WINDOW 1   226.3
DISTANCE FOR WINDOW 1   209.1
DISTANCE FOR WINDOW 1   193.2
DISTANCE FOR WINDOW 1   178.5
DISTANCE FOR WINDOW 1   164.9
DISTANCE FOR WINDOW 1   152.4
DISTANCE FOR WINDOW 1   140.8
DISTANCE FOR WINDOW 1   130.1
DISTANCE FOR WINDOW 1   120.2
view point for window  1  -0.65020E-01 0.12625     0.98987
ROTATION ANGLE FOR WINDOW 1 IS   -24.75 ABOUT AXIS ZS
发表于 2010-11-7 08:25 | 显示全部楼层
网格质量太差
preprocessor->checking ctrls->shape checking
检查一下什么地方不合格
GMT+8, 2025-1-27 21:09 , Processed in 0.097639 second(s), 17 queries , Gzip On.
