查看: 1175|回复: 8
[求助]关于矩阵的表示问题
发表于 2006-4-5 10:37 | 显示全部楼层 |阅读模式
一个矩阵:0                     X                   2X               ```          NX<br>                 Y                    X+Y                2X+Y           ```          NX+Y<br>                 2Y                  X+2Y              2X+2Y         ```          NX+2Y<br>                <br>                  `                       `                       `                                `         <br>                  `                       `                       `                                `  <br>                  `                       `                       `                                `  <br>                NY                 X+NY               2X+NY         ```         NX+NY<br>这样的矩阵怎样表示呢?<br>不能直接用<br>                A=[  ]<br>表示!<br>
[此贴子已经被FtpAdmin于2006-4-5 10:44:15编辑过]
发表于 2006-4-5 11:02 | 显示全部楼层
<P>(0:N)'*ones(1,N+1)*Y+ones(N+1,1)*X*(0:N)'</P>
发表于 2006-4-5 11:05 | 显示全部楼层
呵呵……刚在哪个帖子里面看到过,大体意思是这样的吧,偶也记不太清了,不过试了一个好像是对的<BR>呵呵……偶也是新手哦!<BR><BR>[a,b] = meshgrid(0:N,0:N);<BR>A =X * a + Y * b;
发表于 2006-4-5 11:32 | 显示全部楼层
恩,是对的<BR>这样比较简洁
发表于 2006-4-5 15:35 | 显示全部楼层
<P -.5? mso-char-indent-count: -5.25pt; TEXT-INDENT: 5.25pt; 0pt 0cm><FONT face="Times New Roman"> </FONT>[X,Y]=meshgrid(x,y);其实是<FONT face="Times New Roman">x</FONT>管列数的,<FONT face="Times New Roman">y</FONT>管行数个数<br><br>语句执行后,矩阵X的每一行都是向量x,行数等于向量y的元素的个数,矩阵Y的每一列都是向量y,列数等于向量x的元素的个数。<br></P>
<P -.5? mso-char-indent-count: -5.25pt; TEXT-INDENT: 5.25pt; 0pt 0cm><FONT face="Times New Roman">[X,Y] = meshgrid(1:3,10:14) </FONT></P>
<P><FONT face="Times New Roman"></FONT></P>
<br>
<P -.5? mso-char-indent-count: -5.25pt; TEXT-INDENT: 5.25pt; 0pt 0cm><FONT face="Times New Roman">X =</FONT></P>
<p>
<P -.5? mso-char-indent-count: -5.25pt; TEXT-INDENT: 5.25pt; 0pt 0cm><FONT face="Times New Roman">     1     2     3</FONT></P>
<p>
<P -.5? mso-char-indent-count: -5.25pt; TEXT-INDENT: 5.25pt; 0pt 0cm><FONT face="Times New Roman">Y =</FONT></P>
<p>
<P -.5? mso-char-indent-count: -5.25pt; TEXT-INDENT: 5.25pt; 0pt 0cm><FONT face="Times New Roman">    10    10    10</FONT></P>
<P -.5? mso-char-indent-count: -5.25pt; TEXT-INDENT: 5.25pt; 0pt 0cm><FONT face="Times New Roman">    11    11    11</FONT></P>
<P -.5? mso-char-indent-count: -5.25pt; TEXT-INDENT: 5.25pt; 0pt 0cm><FONT face="Times New Roman">    12    12    12</FONT></P>
<P -.5? mso-char-indent-count: -5.25pt; TEXT-INDENT: 5.25pt; 0pt 0cm><FONT face="Times New Roman">    13    13    13</FONT></P>
<P -.5? mso-char-indent-count: -5.25pt; TEXT-INDENT: 5.25pt; 0pt 0cm><FONT face="Times New Roman">    14    14    14<br><br>嘿嘿,在这里天天可以学东西啊,安逸。</FONT></P>
[此贴子已经被作者于2006-4-9 14:32:08编辑过]
 楼主| 发表于 2006-4-6 18:22 | 显示全部楼层
回复:(cdwxg)[X,Y] = MESHGRID(x,y) 其实是x管列数...
<P>meshgrid是用来产生三惟绘图网格的啊<BR>能用他来定义这样的一个矩阵吗?</P>
发表于 2006-4-6 19:42 | 显示全部楼层
回复:(sier)回复:(cdwxg)[X,Y] = MESHGRID(x,y)...
<DIV class=quote><B>以下是引用<I>sier</I>在2006-4-6 18:22:49的发言:</B><BR>
<P>meshgrid是用来产生三惟绘图网格的啊<BR>能用他来定义这样的一个矩阵吗?</P></DIV>
<br>[X,Y,Z] = meshgrid(x,y,z); %这样是三维的<BR>[X,Y] = meshgrid(x,y);%这样是二维的
 楼主| 发表于 2006-4-6 21:38 | 显示全部楼层
啊?
矩阵中的X,Y只是个变量啊,不存在几惟的关系,如果给定:X=1,Y=2,矩阵只是单一的啊
发表于 2006-4-8 07:55 | 显示全部楼层
回复:(sier)啊?
<DIV class=quote><B>以下是引用<I>sier</I>在2006-4-6 21:38:17的发言:</B><BR>矩阵中的X,Y只是个变量啊,不存在几惟的关系,如果给定:X=1,Y=2,矩阵只是单一的啊</DIV>
<P>自己仔细看看什么和什么嘛<BR>不要拿你的矩阵和说明比<BR>meshgrid返回的是三个矩阵,换句话说也就是你矩阵里要的系数</P>
GMT+8, 2025-1-19 08:00 , Processed in 0.080656 second(s), 17 queries , Gzip On.
