查看: 2032|回复: 4
[求助]用null 解线性齐次方程组 出错
发表于 2006-4-5 10:29 | 显示全部楼层 |阅读模式
<P>偶 刚学习matlab,现在遇到了一个小问题。<br>用 null 解线性齐次方程组时,总是得零解呢?系数矩阵是正定的阿!<br>例如<br>e =</P>
<P>  -13.8063   13.8063<br>   41.4189  -41.4189<br><br>&gt;&gt; null(e,'r')</P>
<P>ans =</P>
<P>   Empty matrix: 2-by-0<br><br>但是明明应该有解的阿。哪位大虾给指点一下。问题出在哪里了阿?<br><br>还有,null(a,'r') 和 null(a)有什么区别阿?<br></P>
[此贴子已经被作者于2006-4-5 10:30:19编辑过]
发表于 2006-4-5 14:47 | 显示全部楼层
回复:(lynette100)[求助]用null 解线性齐次方程组 ...
帮助里不是有吗?自己看吧doc null<BR>
发表于 2006-4-5 15:02 | 显示全部楼层
<P><BR>Syntax<BR>Z = null(A)<BR>Z = null(A,'r')</P>
<P>Description</P>
<P>Z = null(A) is an orthonormal basis for the null space of A obtained from the singular value decomposition. That is, A*Z has negligible elements, size(Z,2) is the nullity of A, and Z'*Z = I. <BR><BR>Z = null(A,'r') is a "rational" basis for the null space obtained from the reduced row echelon form. A*Z is zero, size(Z,2) is an estimate for the nullity of A, and, if A is a small matrix with integer elements, the elements of the reduced row echelon form (as computed using rref) are ratios of small integers. <BR>The orthonormal basis is preferable numerically, while the rational basis may be preferable pedagogically.<BR>不过我英文不好,大概明白...<BR>多多学习才是,哎,<BR>我麻时候能成为高手呢<BR>快了快了<BR>就在今天...<BR><BR>不过弱问,2-by-0是什么意思呢?2行2列全是0?</P>
发表于 2006-4-6 09:10 | 显示全部楼层
<P>2-by-0表示2*0的矩阵</P>
 楼主| 发表于 2006-4-6 11:21 | 显示全部楼层
恩,看的有点晕,矩阵的知识都忘光了<BR><BR>现在关键是,不知道自己那样哪里出错了<BR>还望高手指点一二阿
GMT+8, 2025-1-19 08:10 , Processed in 0.071125 second(s), 17 queries , Gzip On.
