查看: 2374|回复: 4
[声学基础] 求助:学过气动声学或熟悉Lighthill方程的同学请进.
发表于 2010-8-26 09:43 | 显示全部楼层 |阅读模式
对气动声学的lighthill方程和应力张量的确定方法很模糊,不知道怎么确定lighthill应力张量的那个矩阵。请知道的同学加下我,或指教我。不胜感激。
发表于 2010-8-26 13:19 | 显示全部楼层
对于Lighthill T(i,j)应力张量,可以通过实验的方法或者从流体力学基本方程直接进行数值计算来获得!
但是如果不考虑流体内部的密度的波动,那么应力张量可以简化为T(i,j)=row*u(i)*u(j)
 楼主| 发表于 2010-8-30 17:14 | 显示全部楼层
谢谢jin同学
那么上述公式里row是密度是吗?是流体的密度,流体为空气,我可以暂定为空气的密度吗?
而u(i)和u(j)是指扰动速度,i与j分别取x,y,z值吗?这个扰动速度是不是只能通过测量得到?还是有什么公式可以得到?知道噪声值可以反推得到扰动速度吗?
发表于 2010-8-30 19:08 | 显示全部楼层
1. yes, the "row" is the density, and also you can assure that this density is air density.
2. yes, the "i,j" is the coordinate vectors, and this may be need to define it through the experiment.
3. About this problem, I don't know, you can refer the "Aeroacoustic" which wrote by "Sun xiao feng", and also you can look up the "Aeroacoustic" book writen by Goldstain.
Thank you!
 楼主| 发表于 2010-8-31 09:23 | 显示全部楼层
Thank u for your help.
GMT+8, 2025-1-12 08:40 , Processed in 0.061447 second(s), 18 queries , Gzip On.
