查看: 1268|回复: 2
[编程技巧] 此处为何得到复数??着急
发表于 2010-8-14 23:40 | 显示全部楼层 |阅读模式
这是从总程序中切下来的一部分程序:
function canshu
global p n M0 H0 l
n=5
p=[1.0510e+004;3.9127e+003;-2.0353e+001;-8.1851e+002;-4.2596e+002;8.6051e+002]
B=[0.5;0.5;0.5;0.5;0.5;0.5]
M0=-10000
H0=10000
l=12
S1=Sumofp1(p,n)
M=Jiedianwanju(n)
fprintf('    节点号     p(i)                 S1               M(i)\n')
for i=1:n+1
   fprintf('%6d      %10.4e         %10.4e        %10.4e\n',...
              i,p(i),S1(i),M(i))
return
%计算S1(6,1)各元素的值%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
function  S1=Sumofp1(p,n)
global p n
S1=zeros(n+1,1)
for i=1:n+1
    for j=2:i-1
        if i<=2
            S1(i)=0
        else
            S1(i)=S1(i)+6*(i-j)*p(j)
return
%%%%%%%%%%%%%%%%%%计算M(6,1)各元素的值%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
function M=Jiedianwanju(n)
global M0 H0 p l B n S1
M=zeros(n+1,1)
for i=1:n+1
        if i<=2
            M(i)=-M0-H0*(i-1)*l/n+l.^2*B(i)/(6*n.^2)*((3*i-4)*p(1)+p(i))
        else
            M(i)=-M0-H0*(i-1)*l/n+l.^2*B(i)/(6*n.^2)*((3i-4)*p(1)+S1(i)+p(i))        %在此处得到复数????????
return
文中标示的部分计算竟然是复数的结果!!十分不解,请高手帮忙
 楼主| 发表于 2010-8-15 00:15 | 显示全部楼层
发现问题了,标注行  有个3i  中间少了个*号!!!
发表于 2010-8-15 00:23 | 显示全部楼层
回复 楼主 abench363219 的帖子
LZ贴的程序, 自己有试跑过吗? 还有错误!?
还有建议不要自己跟帖
GMT+8, 2025-1-10 23:49 , Processed in 0.053724 second(s), 17 queries , Gzip On.
