查看: 1060|回复: 0
[编程技巧] 请教:关于调用*.DAT文件的问题
发表于 2010-6-18 09:24 | 显示全部楼层 |阅读模式
请教:关于调用*.DAT文件的问题:'(
你好,由于工作需要,目前我使用MATLAB 不久,遇到调用*.dat文件的问题
我调用文件名为'NC1324C-A26-2-8-18-13-2010-05-04-10-26-56.dat'的文件时,能够运行出结果,但总是出现红色报警
但调用文件名为6B506PS_6Bit-A13danpNC1212J0000024-2010-06-08-15-59-01   BAD.dat'的文件时,运行就不会有问题。能否解决一下,看是什么问题。十分感谢。
执行程序:
% clear;clc
data_mulu='E:\fy\Data\A23\';%%%%%%%%%%%被调用的文件路径
flnm00=strcat(data_mulu,'1324-A26-2-8-18-13-2010-05-04-10-26-56.dat'))%%%%%%%%%%flnm00指被调用的文件名
A =load(flnm00,'-mat')
运行结果:
flnm00 =
E:\fy\Data\A23\1324-A26-2-8-18-13-2010-05-04-10-26-56.dat
显示结果时出现如下红色报警错误
??? Java exception occurred:
java.lang.UnsatisfiedLinkError: Can't load library: D:\Program Files\matlab\toolbox\instrument\instrumentadaptors\win32\mwagilentvisa.dll
        at java.lang.ClassLoader.loadLibrary(Unknown Source)
        at java.lang.Runtime.load0(Unknown Source)
        at java.lang.System.load(Unknown Source)
        at com.mathworks.toolbox.instrument.VisaAGILENT.<init>(VisaAGILENT.java:23)
        at com.mathworks.toolbox.instrument.VISA.createVisaObject(VISA.java:37)
        at com.mathworks.toolbox.instrument.GpibVisa.<init>(GpibVisa.java:115)
Error in ==> visa.loadobj at 91
            propInfo(i).obj = handle(com.mathworks.toolbox.instrument.GpibVisa(constructorArgs{:}));
A =
                ans: 'Y'
            hObject: 171.0012
          eventdata: []
            handles: [1x1 struct]
               MXRI: 1.8800
               MNRI: 0
               NXRO: 1.8800
               MNRO: 0
                NO1: 1
               num2: 30
           mininum1: 0
           mininum2: 0
               MNIL: -7
               MXIL: 0
            MINatt1: -0.8000
            MAXatt1: -0.4000
            MINatt2: -1.3000
            MAXatt2: -0.7000
            MINatt3: -2.3000
            MAXatt3: -1.8000
            MINatt4: -5.5000
            MAXatt4: -3.5000
            MINatt5: -11
            MAXatt5: -6
            MINatt6: -22
            MAXatt6: -13
               hege: 1
            BianHao: ''
             summit: [1x1 struct]
                 H1: 1
                 H2: 2
           chipnum2: 2
           chipnum3: 8
           chipnum4: 18
           chipnum5: 13
          chipnum11: 1
          chipnum22: 30
         chipnum11m: 0
         chipnum22m: 0
              edit1: 'A26'
    xinpianbianhao1: 'A26'
    xinpianbianhao2: '2'
    xinpianbianhao3: '8'
            yicedie: 17
                  a: 0
    xinpianbianhao4: '18'
    xinpianbianhao5: '13'
            yicesub: 0
             FSTART: 500000000
               FEND: 1.8000e+010
                OPC: [1x3 char]
             States: 8
                 ii: 8
               BKOP: 'ff'
               OPCX: [1x3 char]
                 jj: 4
               SSTD: [1x102 double]
                 ct: 51
              SSTD2: [51x2 double]
                CTT: {8x4 cell}
                CSS: {8x4 cell}
                 TT: 51
                 WW: 8
             MyFDBH: [51x8 double]
              FDBHF: 17.8906
            MYFDfre: 18
                  S: {1x9 cell}
               ATT0: [51x1 double]
               PHS0: [51x1 double]
               XWCH: [51x1 double]
                 SC: {[51x1 double]  [51x1 double]  [51x1 double]  [51x1 double]  [51x1 double]  [51x1 double]  [51x1 double]}
             ATTENN: '31.5dB'
                 e1: -9.4485
                 e2: -13.6410
                 q1: 1.9174
                 q2: 1.1360
                 w1: -0.4733
                 w2: -0.8191
             jieguo: ''
                 A1: 'Yes'
              MODEL: '1324'
              flnm0: 'e:\fy\Data\A23\shiyan\6B\'
             MyTIME: '2010-05-04-10-26-56'
            bianhao: 'A26-2-8-18-13'
                 av: 1
           Var2save: 'e:\fy\Data\A23\shiyan\6B\1324-A26-2-8-18-13-2010-05-04-10-26-56.dat'
              SHFHG: 'e:\fy\Data\A23\shiyan\6B\HEGEPIN.DOC'
           filemulu: 'e:\fy\Data\A23\shiyan\6B\1324-A26-2-8-18-13-2010-05-04-10-26-56\'
            fileDoc: 'e:\fy\Data\A23\shiyan\6B\1324-A26-2-8-18-13-2010-05-04-10-26-56\1324-A26-2-8-18-13-.doc'
            fileS2D: 'e:\fy\Data\A23\shiyan\6B\1324-A26-2-8-18-13-2010-05-04-10-26-56\1324-A26-2-8-18-13-.s2d'
           fileFig1: 'e:\fy\Data\A23\shiyan\6B\1324-A26-2-8-18-13-2010-05-04-10-26-56\fig1_1324-A26-2-8-18-13-.emf'
           fileFig2: 'e:\fy\Data\A23\shiyan\6B\1324-A26-2-8-18-13-2010-05-04-10-26-56\fig2_1324_A26-2-8-18-13-.emf'
                 AZ: [1 9]
                AZC: [1 7]
                 AX: [51 1]
             fileSP: 'e:\fy\Data\A23\shiyan\6B\1324-A26-2-8-17-13-2010-05-04-10-26-33\31.5dB.s2p'
              fidSP: 3
                 xx: 51
                 yy: 7
                 as: 1
              flnm1: 'e:\fy\Data\A23\shiyan\6B\16dB\'
            fileSP1: 'e:\fy\Data\A23\shiyan\6B\16dB\1324-A26-2-8-17-13--16dB.s2p'
             fidSP1: 3
             fidDoc: 3
          WantPoint: 51
当执行第二个程序(原程序如下):
% clear;clc
data_mulu='E:\fy\Data\A23\'; %%%%%%%%%%%被调用的文件路径
flnm00=strcat(data_mulu,'6B506PS_6Bit-A13danpNC1212J0000024-2010-06-08-15-59-01   BAD.dat')%%%%%%%%%%flnm00指被调用的文件名
运行结果:
flnm00 =
E:\fy\Data\A23\6B506PS_6Bit-A13danpNC1212J0000024-2010-06-08-15-59-01   BAD.dat
A =
           T: 1
     BianHao: 'A13danpNC1212J0000024'
         SBH: [1 21]
      FSTART: 5.0000e+009
        FEND: 6.0000e+009
         OPC: [1x3 char]
      States: 8
          ii: 8
        BKOP: '3f'
        OPCX: [1x3 char]
          jj: 4
          ct: 51
         CTT: {8x4 cell}
         CSS: {8x4 cell}
          TT: 51
          WW: 8
       MODEL: '6B506PS_6Bit'
       flnm0: 'e:\fy\Data\NEW\'
       SHFHG: 'e:\fy\Data\NEW\HEGEPIN.DOC'
      fidHGP: 3
      MyTIME: '2010-06-08-15-59-01'
          av: 1
    Var2save: 'e:\fy\Data\NEW\6B506PS_6Bit-A13danpNC1212J0000024-2010-06-08-15-59-01.dat'
请问如何解除掉第一个程序运行后的报错问题,不胜感激!
[ 本帖最后由 驻足停留时 于 2010-6-18 09:29 编辑 ]
GMT+8, 2025-1-11 00:24 , Processed in 0.063512 second(s), 18 queries , Gzip On.
