查看: 2155|回复: 4
[编程技巧] 极坐标绘图
发表于 2010-6-17 21:11 | 显示全部楼层 |阅读模式
请教要如何才能绘制出如下的效果?
我用polar效果只能会出部分效果,角度有点差异
[ 本帖最后由 ChaChing 于 2010-6-17 23:28 编辑 ]
发表于 2010-6-17 23:22 | 显示全部楼层
印象中官网中好像有, LZ先搜下!
 楼主| 发表于 2010-6-19 18:42 | 显示全部楼层
网址
请问什么是官网,网址?
发表于 2010-6-20 00:23 | 显示全部楼层
发表于 2011-6-26 12:47 | 显示全部楼层
好像直接把4F程式列出较为完整!
  1. function h = halfPolar(phi,gain,linestyle,xtickval)
  2. % HALFPOLAR function performs the polar plot in radian angle range [0 pi]
  3. % using half polar coordinates
  4. %
  5. % HALFPOLAR(phi,gain) makes a plot with phi in radians angle range [0 pi]
  6. % and gain in half polar coordinates. Phi and gain could be vector or matrix
  7. % with the same dimensions. When Phi is a vector(1XN) and vector(1XN) and
  8. % matrix(MXN)gain values are allowable. When Phi is a matrix(MXN) and then
  9. % the gain should only be matrix(MXN) with the same row numbers.
  10. %
  11. % HALFPOLAR(phi,gain, linestyle) uses specified linestyle defined in cell
  12. % variable linestyle to plot phi and gain, like: linestyle = {'ko-','b--'}
  13. %
  14. % HALFPOLAR(phi,gain, linestyle, xtickval) plots phi and gain with the
  15. % prescribed tick value xtickval. like: xtickval = [15 25 45 75 105]
  16. %
  17. % IMPORTANT NOTE:
  18. % HALFPOLAR is designed especially for the radiated sould pressure level
  19. % demonstration. Accordingly the gain value is designed to be dB value.
  20. % the default xtickvalue is also designed to match the dB value range.
  21. % So you are permitted to modify the function in order to correctly
  22. % demonstrate data for your specified applications.
  23. %
  24. % HALFPOLAR is coded straightforward without variables checking and fault
  25. % testing.The author don't take the responsibility for the program bug.
  26. %
  27. % Example:
  28. % phi = linspace(0,pi,20);
  29. % gain = 80 * rand(3,length(phi)) + 40;
  30. % h = halfPolar(phi,gain,{'k-','g-.','r--','k-'},[30 40 65 80 95 120])
  31. %
  32. % See also polar;
  33. %
  34. % Don't heisitate to let me know the problems about the function:
  35. % lhd06@mails.thu.edu.cn
  36. % Departmen of Electrical Engineering,
  37. % Tsinghua University, Beijing, China.
  38. %
  39. % Reference function: polar.m provided by the matlab graphics toolbox
  40. %
  41. % If the program is modified and redistributed, the description above
  42. % should be included.
  43. min_gain = min(min(gain)); max_gain = max(max(gain));
  44. space_val = 4; spoke_val = 6; spoketickval = linspace(0,pi,spoke_val+1);
  45. if nargin < 2, error('Not enough input arguments.'); end
  46.
  47. % if nargin < 3, rangedb = [min_gain max_gain]; end
  48. if nargin < 3  linestyle = 'auto';xtickval = linspace(round(min_gain) - 10,round(max_gain) + 10,space_val);  end
  49. if nargin < 4, xtickval = linspace(round(min_gain) - 10,round(max_gain) + 10,space_val); end
  50. % normalization the input value
  51. gain_range = xtickval(end) - xtickval(1);   %obtain the gain range
  52. gain_scale = abs((gain - xtickval(1)))/gain_range; %[0,1]
  53. cax = newplot; tc = get(cax,'xcolor'); ls = get(cax,'gridlinestyle');
  54.
  55. th = linspace(0,pi,200); xunit = cos(th); yunit = sin(th);
  56. % plot background if necessary
  57. if ~isstr(get(cax,'color'))
  58.        patch('xdata',xunit,'ydata',yunit, 'edgecolor',tc,'facecolor',get(gca,'color'));
  59. end
  60. hold on; [m1,n1] =size(phi); [m2,n2] =size(gain);
  61. if(m1==1)
  62.     for i=1:m2
  63.         x = gain_scale(i,:) .* cos(phi); y = gain_scale(i,:) .* sin(phi);
  64.         if(strcmp(linestyle,'auto')), h(i) = plot(x,y,'linewidth',2);
  65.         else h(i) = plot(x,y,linestyle{i},'linewidth',2);
  66.         end
  67.     end
  68. else
  69.     if(m1 ~= m2), error('Matrix should be have the same dimension!');
  70.     else
  71.         for i=1:m2
  72.          x = gain_scale(i,:) .* cos(phi(i,:)); y = gain_scale(i,:) .* sin(phi(i,:));
  73.             if(strcmp(linestyle,'auto')), h(i) = plot(x,y,'linewidth',2);  %,'LineWidth', 2
  74.             else h(i) = plot(x,y,linestyle{i},'linewidth',2);
  75.             end
  76.         end
  77.     end
  78. end
  79. set(gca,'dataaspectratio',[1 1 1]);axis off;
  80. % legend_val = legend(h(1:end),'Controlled','Uncontrolled');
  81. % set(legend_val,'location','SouthOutside');
  82. hold on;
  83. %define the circle
  84. contour_val = zeros(1,length(xtickval));
  85. contour_val = abs((xtickval - xtickval(1))/gain_range);
  86. for k=2:length(contour_val) %gain circles
  87.     plot(xunit*contour_val(k), yunit*contour_val(k),ls,'color','black');
  88.     text(contour_val(k),-0.05, sprintf('%.3g',xtickval(k)),'horiz', 'center', 'vert', 'middle');
  89.     text(- contour_val(k),-0.05, sprintf('%.3g',xtickval(k)),'horiz', 'center', 'vert', 'middle');
  90. end
  91. text(contour_val(1),-0.05,sprintf('%.3g',xtickval(1)),'horiz', 'center', 'vert', 'middle');
  92. text(-0.45,-0.15,'Sound Pressure Level(SPL) /dB');
  93. %plot the spokes and  % annotate spokes in degrees
  94. cst = cos(spoketickval); snt = sin(spoketickval);
  95. for k = 1:length(spoketickval) - 1
  96.     plot(cst(k) * contour_val,snt(k) * contour_val,ls,'color',tc,'linewidth',1, 'handlevisibility','off');
  97.     text(1.07*cst(k),1.07*snt(k), sprintf('%.3g^{o}',spoketickval(k)/pi*180, 'horiz', 'center', 'vert', 'middle');
  98. end
  99. text(1.08*cst(end),1.07*snt(end), sprintf('%.3g^{o}',spoketickval(end)/pi*180),'horiz', 'center', 'vert', 'middle');
  100. hold off;
GMT+8, 2025-1-10 02:25 , Processed in 0.077176 second(s), 21 queries , Gzip On.
