查看: 3423|回复: 0
[前后处理] 人工边界Specified DOF constraint UY at unused node 516.
发表于 2010-5-25 14:52 | 显示全部楼层 |阅读模式
我是做动力分析,所以考虑到边界上用combin14单元建立了人工边界,但是总是出现这样的提示,但是模型还是能正常运算;
*** WARNING ***                         CP =       1.094   TIME= 13:58:56
Use of the -M switch is no longer recommended for normal ANSYS use.
ANSYS now dynamically allocates memory as needed.  Only use the -M
switch if you are certain that you need to do so.
*** WARNING ***                         CP =       6.922   TIME= 13:59:23
Specified DOF constraint UX at unused node 505.
Specified DOF constraint UY at unused node 505.
Specified DOF constraint UZ at unused node 505.
Specified DOF constraint UX at unused node 506.
Specified DOF constraint UY at unused node 506.
如果我把人工边界改为位移约束,就没有这样的提示。
而且我觉得提示的这些节点号在我模型里好像根本就不存在,不知道为什么,请各位大侠帮忙
GMT+8, 2025-1-26 07:05 , Processed in 0.055649 second(s), 18 queries , Gzip On.
