查看: 1724|回复: 3
[结构力学] 几何中心与中和轴
发表于 2010-5-21 10:45 | 显示全部楼层 |阅读模式
请问一下,几何中心与中性(和)轴的区别是什么,谢谢?
发表于 2010-5-22 09:11 | 显示全部楼层
wiki上的解释不错:
The neutral axis is an axis in the cross section of a beam or shaft along which there are no longitudinal stresses or strains. If the section is symmetric and is not curved before a bend occurs, then the neutral axis is at the geometric centroid. All fibers on one side of the neutral axis are in a state of tension, while those on the opposite side are in compression
发表于 2010-5-23 08:38 | 显示全部楼层
回复 楼主 yiqing 的帖子
中和轴是受弯构件截面应力分布中,压应力和拉应力的分界线,并且它和弯曲主轴平行,对于钢材而言,中和轴两侧截面面积是相等的。
发表于 2010-5-23 20:33 | 显示全部楼层
几何中心仅仅从几何的角度来计算中心,是一个点
中心轴还得考虑进材性,是一条线
GMT+8, 2024-11-29 02:41 , Processed in 0.052221 second(s), 18 queries , Gzip On.
