查看: 1573|回复: 3
[Virtual.Lab] FEM structure与FEM fluid 耦合出现的问题
发表于 2010-5-19 21:29 | 显示全部楼层 |阅读模式
请教各位:我在做铝板和空气耦合模拟阻抗管测量铝板传播损失的时候,在Link后出现以下问题:然后界面跳出,不知是怎么回事,在流体和结构体耦合界面网格大小一样。
Building a LINK between Models:     1 and     2
      Behavior: STRUCTURE-FLUID (FEM-FEM)
      Model      1: Number of Interface Items:   800
      Model      2: Number of Interface Items:   800
TOTAL NUMBER OF DEFINED LINKS =         1
SCL> Solve
SCL>     Frequency 100
SCL>     Return
FREQUENCY RESPONSE MODULE
FOR    1 FREQUENCIES FROM      100.000 TO      100.000 HZ
ANALYSIS #     1  FREQUENCY =        100.000 HZ  TYPE = NORMAL
SOLVE PARAMETERS
MODEL:   1 - 1
    PHYSICAL Coordinates
    Saving POTENTIALS every        1 steps
    No saving of RESULTS
    Energy Calculation Enabled
    Surface post-processing on positive side
SOLVE PARAMETERS
MODEL:   2 - 2
    MODAL Coordinates:         13 Vectors
    Saving DISPLACEMENTS every     1 steps
LAUNCHING COUPLED FEM-FEM (Mixed Coords - Freq) ANALYSIS
SAVING MODEL 2
FILE NAME    _model2.sdb.7
SAVING STRUCTURAL MODES INTO DATABASE
SAVING MODEL 1
FILE NAME    _model1.sdb.33
Building FLUID / STRUCTURE interface
Using Model      2 as STRUCTURAL Model
Using Model      1 as FLUID Model
There are    882 interface node(s) on the FEM FLUID side
There are    882 interface node(s) on the FEM STRUCTURE side
Generating INTERFACE mesh
INTERFACE MESH contains        800 elements
Computing FLUID Element System Matrices
Computing MASS and STIFFNESS elements matrices
CPU Stats --- Delta:  0:00:04 (      4.21)  Total:  0:00:22 (     22.39)
Computing VELOCITY matrices on elements faces
CPU Stats --- Delta:  0:00:06 (      6.40)  Total:  0:00:29 (     28.79)
Computing ADMITTANCE matrices on elements faces
CPU Stats --- Delta:  0:00:00 (      0.05)  Total:  0:00:29 (     28.84)
Computing COUPLING matrices for FLUID-STRUCTURE interface elements
CPU Stats --- Delta:  0:00:01 (      1.19)  Total:  0:00:30 (     30.03)
Computing projected COUPLING matrix
Verification of projected COUPLING matrix
CPU Stats --- Delta:  0:00:01 (      0.72)  Total:  0:00:31 (     30.75)
Occupied space:   2211035 words  ( 22.11 %)
CPU Stats --- Delta:  0:00:01 (      0.79)  Total:  0:00:32 (     31.54)
Occupied space:   2211126 words  ( 22.11 %)
THIS PROBLEM WOULD NEED   110555422 WORDS TO RUN IN-CORE
MATRICES ARE TOO BIG FOR IN-CORE SOLVER
SELECTING THE OUT-OF-CORE SOLVER
Number of equations        =       18535
Average column height      =        1459
Number of terms in profile =    27039720
Number of blocks           =          29
Block length               =      950424
Occupied space:   9999993 words  (100.00 %)
This node (PC-201004111807) has number 0
ANALYSIS NUMBER      1 /      1                FREQUENCY =    100.000 Hz
CPU Stats --- Delta:  0:00:01 (      1.13)  Total:  0:00:33 (     32.67)
Building matrix of coefficients
      Building block #     1
      Building block #     2
      Building block #     3
      Building block #     4
      Building block #     5
      Building block #     6
      Building block #     7
      Building block #     8
      Building block #     9
      Building block #    10
      Building block #    11
      Building block #    12
      Building block #    13
      Building block #    14
      Building block #    15
      Building block #    16
      Building block #    17
      Building block #    18
      Building block #    19
      Building block #    20
      Building block #    21
      Building block #    22
      Building block #    23
      Building block #    24
      Building block #    25
      Building block #    26
      Building block #    27
      Building block #    28
      Building block #    29
Generating RHS vector
Assembling Structural Right-Hand-Side vector
CPU Stats --- Delta:  0:03:04 (    184.06)  Total:  0:03:37 (    216.73)
Solving system of equations
Solving system of equations (out-of-core solver)
Beginning triangulation
      Block #    1
      Block #    2
      Block #    3
      Block #    4
      Block #    5
      Block #    6
      Block #    7
      Block #    8
      Block #    9
      Block #   10
      Block #   11
      Block #   12
      Block #   13
      Block #   14
      Block #   15
      Block #   16
      Block #   17
      Block #   18
      Block #   19
      Block #   20
      Block #   21
      Block #   22
      Block #   23
      Block #   24
      Block #   25
      Block #   26
      Block #   27
      Block #   28
      Block #   29
Beginning back substitution
发表于 2010-5-21 16:44 | 显示全部楼层
单元过多,计算机内存不足
 楼主| 发表于 2010-5-21 23:06 | 显示全部楼层
非常感谢mao的回答,我马上去试试,但是有个疑问,当sysnoise内存不足时,应该提示low memory或者弹出一个框,上面好像是10,000,但是我这个为什么是这种提示呢?恳请高手回答
发表于 2010-6-6 11:31 | 显示全部楼层
软件没有你说的好,它不会弹出任何窗口的
GMT+8, 2025-1-12 09:02 , Processed in 0.084879 second(s), 18 queries , Gzip On.
