查看: 6344|回复: 15
[优化设计] 拓扑优化方面的经典99行程序
发表于 2010-5-5 22:22 | 显示全部楼层 |阅读模式
function top(nelx,nely,volfrac,penal,rmin);
% INITIALIZE
x(1:nely,1:nelx) = volfrac;
loop = 0;
change = 1.;
% START ITERATION
while change > 0.01
  loop = loop + 1;
  xold = x;
% FE-ANALYSIS
  [U]=FE(nelx,nely,x,penal);
% OBJECTIVE FUNCTION AND SENSITIVITY ANALYSIS
  [KE] = lk;
  c = 0.;
  for ely = 1:nely
    for elx = 1:nelx
      n1 = (nely+1)*(elx-1)+ely;
      n2 = (nely+1)* elx   +ely;
      Ue = U([2*n1-1;2*n1; 2*n2-1;2*n2; 2*n2+1;2*n2+2; 2*n1+1;2*n1+2],1);
      c = c + x(ely,elx)^penal*Ue'*KE*Ue;
      dc(ely,elx) = -penal*x(ely,elx)^(penal-1)*Ue'*KE*Ue;
% FILTERING OF SENSITIVITIES
  [dc]   = check(nelx,nely,rmin,x,dc);
% DESIGN UPDATE BY THE OPTIMALITY CRITERIA METHOD
  [x]    = OC(nelx,nely,x,volfrac,dc);
% PRINT RESULTS
  change = max(max(abs(x-xold)));
  disp([' It.: ' sprintf('%4i',loop) ' Obj.: ' sprintf('%10.4f',c) ...
       ' Vol.: ' sprintf('%6.3f',sum(sum(x))/(nelx*nely)) ...
        ' ch.: ' sprintf('%6.3f',change )])
% PLOT DENSITIES
  colormap(gray); imagesc(-x); axis equal; axis tight; axis off;pause(1e-6);
%%%%%%%%%% OPTIMALITY CRITERIA UPDATE %%%%%%%%%%%%%%%%%%%%%%%%%%%%
function [xnew]=OC(nelx,nely,x,volfrac,dc)
l1 = 0; l2 = 100000; move = 0.2;
while (l2-l1 > 1e-4)
  lmid = 0.5*(l2+l1);
  xnew = max(0.001,max(x-move,min(1.,min(x+move,x.*sqrt(-dc./lmid)))));
  if sum(sum(xnew)) - volfrac*nelx*nely > 0;
    l1 = lmid;
  else
    l2 = lmid;
%%%%%%%%%% MESH-INDEPENDENCY FILTER %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
function [dcn]=check(nelx,nely,rmin,x,dc)
dcn=zeros(nely,nelx);
for i = 1:nelx
  for j = 1:nely
    sum=0.0;
    for k = max(i-floor(rmin),1):min(i+floor(rmin),nelx)
      for l = max(j-floor(rmin),1):min(j+floor(rmin),nely)
        fac = rmin-sqrt((i-k)^2+(j-l)^2);
        sum = sum+max(0,fac);
        dcn(j,i) = dcn(j,i) + max(0,fac)*x(l,k)*dc(l,k);
    dcn(j,i) = dcn(j,i)/(x(j,i)*sum);
%%%%%%%%%% FE-ANALYSIS %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
function [U]=FE(nelx,nely,x,penal)
[KE] = lk;
K = sparse(2*(nelx+1)*(nely+1), 2*(nelx+1)*(nely+1));
F = sparse(2*(nely+1)*(nelx+1),1); U = zeros(2*(nely+1)*(nelx+1),1);
for elx = 1:nelx
  for ely = 1:nely
    edof = [2*n1-1; 2*n1; 2*n2-1; 2*n2; 2*n2+1; 2*n2+2; 2*n1+1; 2*n1+2];
    K(edof,edof) = K(edof,edof) + x(ely,elx)^penal*KE;
% DEFINE LOADS AND SUPPORTS (HALF MBB-BEAM)
F(2,1) = -1;
fixeddofs   = union([1:2:2*(nely+1)],[2*(nelx+1)*(nely+1)]);
alldofs     = [1:2*(nely+1)*(nelx+1)];
freedofs    = setdiff(alldofs,fixeddofs);
% SOLVING
U(freedofs,:) = K(freedofs,freedofs) \ F(freedofs,:);
U(fixeddofs,:)= 0;
%%%%%%%%%% ELEMENT STIFFNESS MATRIX %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
function [KE]=lk
E = 1.;
nu = 0.3;
k=[ 1/2-nu/6   1/8+nu/8 -1/4-nu/12 -1/8+3*nu/8 ...
   -1/4+nu/12 -1/8-nu/8  nu/6       1/8-3*nu/8];
KE = E/(1-nu^2)*[ k(1) k(2) k(3) k(4) k(5) k(6) k(7) k(8)
                  k(2) k(1) k(8) k(7) k(6) k(5) k(4) k(3)
                  k(3) k(8) k(1) k(6) k(7) k(4) k(5) k(2)
                  k(4) k(7) k(6) k(1) k(8) k(3) k(2) k(5)
                  k(5) k(6) k(7) k(8) k(1) k(2) k(3) k(4)
                  k(6) k(5) k(4) k(3) k(2) k(1) k(8) k(7)
                  k(7) k(4) k(5) k(2) k(3) k(8) k(1) k(6)
                  k(8) k(3) k(2) k(5) k(4) k(7) k(6) k(1)];
我不是建筑结构的,结构优化只是知道个皮毛。有限元只是上过课,可课上根本就不知道老师在讲什么。
但是,我现在想弄懂拓扑优化经典99行程序中有限元部分。我拿着清华大学出版社出的有限元教材,光知道这是个板单元,U代表位移,K刚度矩阵, F代表力。
还有,我想弄懂这段有限元代码,可是感觉一点不开窍。谁理解了这段代码,能否给我说一下具体要那些有限元知识,看清华大学出版社出的有限元教材就够了吗?
我是说一本有限元教材就能弄懂拓扑优化经典99行程序中有限元部分理论吗?我很不开窍啊!
那位牛人给我稍微指点一下迷津,不胜感激!!
 楼主| 发表于 2010-5-9 12:24 | 显示全部楼层
我看懂了单元刚度矩阵了,知道具体每个元素的构造过程。
现在看看前阵的发问有点愚蠢,确实只要看看平面矩形单元就可以看懂这个矩阵了!
接下来再看整体刚度矩阵,好像要用到SIMP。
 楼主| 发表于 2010-5-13 21:29 | 显示全部楼层
现在基本上全看懂了。
但还有点看不懂,谁稍微提示一下:75行左右的
这是在组集总刚度矩阵,怎么个对号入坐。等号后第一项是在累加矩阵,有点没看出来是在“对号入座”
发表于 2010-5-18 22:03 | 显示全部楼层
大家有在MATLAB中运行过的吗?我运行就出问题了 ,x(1:nely,1:nelx) = volfrac?
 楼主| 发表于 2010-5-19 20:55 | 显示全部楼层
volfrac是自己设定,为0.5 top(60,20,0.5,3.0,1.5)
发表于 2010-5-19 23:21 | 显示全部楼层
我有一篇关于这个程序的的英语论文,需要的话可以给你吗。
 楼主| 发表于 2010-5-20 22:46 | 显示全部楼层
我有这方面的论文,只是有些地方看不懂啊,BI-SECTION ALGORITHM是二分法的意思,让我看了好半天!还是看一些中文的吧,相关专业英语没学过,每个生词都查,太费劲了!
我现在优化准则还有些不太通,正在研究,
 楼主| 发表于 2010-5-20 22:51 | 显示全部楼层
我有点没理解这个volfrac指什么?是指刚开始时,在每个单元中,密度为真正的0.5吗?
发表于 2010-11-10 22:18 | 显示全部楼层
谢谢楼主分享,好好认真研究一下……
 楼主| 发表于 2010-12-21 10:31 | 显示全部楼层
多多指教啊!
发表于 2011-1-5 13:40 | 显示全部楼层
现在看不懂,记号
发表于 2011-1-14 10:14 | 显示全部楼层
拓扑优化?  学习一下啦
发表于 2011-1-14 19:44 | 显示全部楼层
回复 2 # 86029 的帖子
你好,我最近在研究99行程序,在网上看到了你的帖子,请问你有99行程序的注释吗?
 楼主| 发表于 2011-4-20 10:36 | 显示全部楼层
有,http://www.topopt.dtu.dk/MATLAB/matlab.pdf
发表于 2011-12-7 15:13 | 显示全部楼层
GMT+8, 2024-12-28 12:35 , Processed in 0.086963 second(s), 21 queries , Gzip On.
