查看: 1425|回复: 2
计算时间延迟C——C算法
发表于 2010-5-2 10:54 | 显示全部楼层 |阅读模式
function [s,delt_s,s_cor]=C_CMethod(data)
%this function calculate time delay and embedding demension with C-C
%Method,which proved by H.S.Kim
%skyhawk&flyinghawk
% clear all;
% data=load('C:\Documents and Settings\Administrator\??\a.txt');% ????
data=load('y.txt');
N=length(data)
max_d=2;%the maximum value of the time delay
sigma=std(data);%calcute standard deviation s_d
for t=1:max_d
    t;
    s_t=0;
    delt_s_s=0;
    for m=2:5
        s_t1=0;
        for j=1:4
            r=sigma*j/2;
            data_d=disjoint(data,N,t);%将时间序列分解成t个不相交的时间序列
            [ll,N_d]=size(data_d);
            s_t3=0;
            for i=1:t
                i;
                Y=data_d(i,:);
                C_1(i)=correlation_integral(Y,N_d,r);%计算C(1,N_d,r,t)
                X=reconstitution(Y,N_d,m,t);%相空间重构
                N_r=N_d-(m-1)*t;
                C_I(i)=correlation_integral(X,N_r,r);%计算C(m,N_r,r,t)
                s_t3=s_t3+(C_I(i)-C_1(i)^m);%对t个不相关的时间序列求和
            s_t2(j)=s_t3/t;
            s_t1=s_t1+s_t2(j);%对rj求和
        delt_s_m(m)=max(s_t2)-min(s_t2);%求delt S(m,t)
        delt_s_s=delt_s_s+delt_s_m(m);%delt S(m,t)对m求和
        s_t0(m)=s_t1;
        s_t=s_t+s_t0(m);%S对m求和
    s(t)=s_t/16;
    delt_s(t)=delt_s_s/4;
    s_cor(t)=delt_s(t)+abs(s(t));
fid=fopen('result.txt','w');
fprintf(fid,'%f %f %f %f/n',t,s(t),delt_s(t),s_cor(t));
fclose(fid);
t=1:max_d;
plot(t,s,t,delt_s,'.',t,s_cor,'*')
谁能给我解释一下运行的结果是什么含义吗?
y.txt
7.57 KB, 下载次数: 2
头像被屏蔽
发表于 2010-5-4 11:11 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2010-5-4 20:54 | 显示全部楼层
回复 沙发 123426006 的帖子
楼上属广告帖请删除! 已禁止访问! 一一报告还需等45秒! 没时间等  :@Q
处理完记得也删除此帖
GMT+8, 2025-1-6 12:42 , Processed in 0.067979 second(s), 26 queries , Gzip On.
