查看: 1427|回复: 0
[综合讨论] 在ansys中做减法时出现下面的提示,?
发表于 2010-4-22 08:57 | 显示全部楼层 |阅读模式
Topological degeneracy detected for VSBV command.  Try modifying
geometry slightly or loosening the tolerance (BTOL command).  If BTOL
is relaxed, be sure to change the tolerance back to the default after
operation.
GMT+8, 2025-1-11 22:51 , Processed in 0.083813 second(s), 17 queries , Gzip On.
