查看: 3033|回复: 13
[HHT] 边际谱m程序问题
发表于 2010-4-8 21:47 | 显示全部楼层 |阅读模式
用了两种方法求边际谱~为何结果相差这么大呢?毕业在即,请高手指教,不甚感激
1.
clear all
clc
load('data.txt');
x=data(1:1000,2);
t=1:1000;
fs=50;
figure(10);
plot(1/fs*t,x);
xlabel('t/s');
ylabel('m/s^2');
%对信号作EMD分解,求出各IMF分量图和重构图及各IMF的时频图
[imf,ort,nbits]=emd(x);
%作出HHT归一化能量谱图(三维图),边际谱图和瞬时能量图
N=1000;
L=size(imf,1);  % Number of components in the decomposition
% loop for on each component
S=[];
clear x z m p freq
x=imf'; % now each column is a compenent
z=hilbert(x); % analytic signal
m=abs(z); % module of z
p=angle(z); % phase of z
for i=1:L
    freq(:,i)=instfreq(z(:,i));   % instantaneous frequency
    ceilfreq(:,i)=ceil(freq(:,i)*N);  % to have integer  values-also do a smoothing given the number
       for j=1:length(x)-2
       S(ceilfreq(j,i),j+1)=m(j+1,i);
eps=0.00001; % to avoid zero values before the log
E=20*log(S.^2+eps);  % Hilbert energ spectrum
% plot S
figure(90);
t=1:length(x);  % time sample
f=t/length(x)*25;    % frequency %%%%%%%%%
imagesc(t,f,E);
contour(t(1:999),1:50,E);  %画出等高线图
surfl(1:999,1:500,S.^2); shading interp; colormap(gray);axis([1 1000 1 500 0 0.05])
% mesh(1:999,1:50,S.^2);
% mesh(1:999,1:50,S); %画出三维图
set(gca,'YDir','normal');
xlabel('时间采样点');
ylabel('Frequency/Hz'); %%%%%%%%%%%%%%%%%%%%
% ylabel('Normalized Frequency');
% axis([0 772 0 300]); %%%%%%%%%%%%%%%%%%%%%%
S1=sum(S.^2,1);figure(100);plot((1:999)*0.02,S1); %瞬时能量
figure(110);
S2=sum(S.^2,2);plot(1:500,S2,'r') %边际能量谱
figure(120);
S3=sum(S,2);plot(1:500,S3,'g') %边际谱
2.接上
%%% 求边际谱
[A,fa,tt]=hhspectrum(imf(1:end-1,:));  % A--瞬时幅值,fa--瞬时频率,tt--
[E,tt1,ff]=toimage(A,fa,tt,length(tt));%% ff--中心频率
% disp_hhs(E);colorbar;
% colormap(flipud(gray)) %显示灰度图
for k=1:size(E,1)
    bjp(k)=sum(E(k,:))*1/fs;
f2=(0:N-3)/N*(fs/2); % fs/(2*N)是时频图上y方向的分辨率
figure(200)
plot(f2,bjp);  %%% 作边际谱图
xlabel('频率 / Hz');
ylabel('幅值');
 楼主| 发表于 2010-4-8 21:49 | 显示全部楼层
另,前一种方法 得到的横坐标不知是否要除以1000才是其真实的频率,若是,那范围只有0~0.5hz,未免也太小了一点吧
SOS:@)
 楼主| 发表于 2010-4-8 21:56 | 显示全部楼层
回复 楼主 babybear713 的帖子
function [S,freq] = HHTspe(imf,N,fs);
%%N--------分辨率
%fs-------采样频率
%s--------时间-频率-幅值矩阵
if(nargin<3)
    fs=1;
L = size(imf,1);
S = [];
clear x z m p freq
x = imf';
z = hilbtmf(x); % 用改进的Hilbert变换,效果好一些。
m = abs(z);
p = angle(z);
for i = 1:L
      freq(:,i) = instfreq(z(:,i))*fs; %乘以了采样频率
                  ceilfreq(:,i) = ceil(freq(:,i)*N);
            for j = 1:length(x)-2
            S(ceilfreq(j,i),j+1) = m(j+1,i);
%plot S
figure;
t=(1:length(x))/fs;
f=(1:size(S,1))/N; %
imagesc(t,f,S);
colorbar;
xlabel('Time t/s');
ylabel(' Frequency/HZ');
return
再请教,这个分辨率N是如何确定的???
发表于 2010-4-9 01:28 | 显示全部楼层
(1)第一个图不用除以1000,应该除以25,在您的程序中有一句,f=t/length(x)*25;  ,我不明白为什么您要乘以25。
(2)这个N的意思,我也一直没有明白,但是您的第一个程序给了我一些启示,我个人理解有两种:(1)N为采样频率 (2)N为采样点的个数也就是length(t),我用试验的方法做了一下,N为采样点数的时候效果好,但是计算时间较长。所以N是不是一个随便设定的值,取决于你想得到的精度。
发表于 2010-4-9 08:46 | 显示全部楼层
原帖由 babybear713 于 2010-4-8 21:49 发表
SOS:@)
不是除以1000吧,你的采样频率不是50吗?应该除以50吧
 楼主| 发表于 2010-4-9 09:17 | 显示全部楼层
回复 地板 杨德昌 的帖子
这个f 的设定是在画hht频谱图的时候用到的,因为根据采样定理是结构的最大频率应该不超过采样频率的一半,所以自认为它的最大频率为25
发表于 2010-4-9 09:26 | 显示全部楼层
请问各位? EMD后,如果采样频率是fS ,采样点数N  ,EMD后 只对IMF1做边际谱,所得到的频谱图的频率分辨率是fS /2N吗?  跟EMD的分解层数有关系吗?
发表于 2010-4-9 18:57 | 显示全部楼层
对楼主的问题,我也遇到了,希望高手指点!
 楼主| 发表于 2010-4-11 21:01 | 显示全部楼层
发现了一点问题,横坐标应该是(1:500)*fs/N,这样好些就差不多了
还有两个问题就是
1. 能量谱的话用
for k=1:size(E,1)
    bjp(k)=sum(E(k,:).^2)*1/fs;
可以么?又或者
  for k=1:size(E,1)
    bjp(k)=sum(E(k,:).*E(k,:))*1/fs*1/tspan;
2  什么时候后面要加上乘以  1/tspan?
 楼主| 发表于 2010-4-11 21:04 | 显示全部楼层
回复 9楼 babybear713 的帖子
呼唤版主及各位高人呀
发表于 2010-4-12 15:53 | 显示全部楼层
回复 10楼 babybear713 的帖子
其实您就是高人了!
 楼主| 发表于 2010-4-14 15:21 | 显示全部楼层
回复 11楼 杨德昌 的帖子
我是诚心求教
发表于 2010-8-4 11:06 | 显示全部楼层
你好,一直困惑为什么
中是0:N-3?这代表着什么呢?
发表于 2013-10-16 18:14 | 显示全部楼层
f2=(0:N-3)/N*(fs/2); 应该改为(0:399)/400*(fs/2);
GMT+8, 2025-1-8 02:11 , Processed in 0.066114 second(s), 22 queries , Gzip On.
