查看: 1874|回复: 6
[非线性振动] 求两篇关于非线性的论文
发表于 2010-3-26 15:07 | 显示全部楼层 |阅读模式
我想要两篇论文,但在这怎么都下不到,请各位有的传我一下,在下不甚感激!!!
一篇是:Non-linear vibration of a traveling tensioned beam
作者是J.A. Wickert
另一篇是:Coupled belt-pulley vibration in serpentine drives with belt bending stiffness
作者是:L kong.和RG Wk Parker
谢谢!!!!
发表于 2010-3-26 16:21 | 显示全部楼层
只有第二篇,第一篇有点老
 楼主| 发表于 2010-3-27 18:03 | 显示全部楼层
谢谢!!能把第二篇发给我吗?我的邮箱是sghwxfqtd@163.com。非常感谢
发表于 2010-3-28 04:19 | 显示全部楼层
第一篇有。
发表于 2012-2-15 14:24 | 显示全部楼层
回复 4 # Seventy721 的帖子
麻烦给我传下第一篇,好吧,谢谢!我的邮箱lgdlina@163.com
发表于 2012-2-17 10:53 | 显示全部楼层
Abstract
Free non-linear vibration of an axially moving, elastic, tensioned beam is analyzed over the sub- and supercritical transport speed ranges. The pattern of equilibria is analogous to that of Euler column buckling and consists of the straight configuration and of non-trivial solutions that bifurcate with speed. The governing equations for finite local motion about the trivial equilibrium and for motion about each bifurcated solution are cast in the standard form of continuous gyroscopic systems. A perturbation theory for the near-modal free vibration of a general gyroscopic system with weakly non-linear stiffness and/or dissipation is derived through the asymptotic method of Krylov, Bogoliubov, and Mitropolsky. The method is subsequently specialized to non-linear vibration of a traveling beam, and of a traveling string in the limit of vanishing flexural rigidity. The contribution of non-linear stiffness to the response increases with subcritical speed, grows most rapidly near the critical speed, and can be several times greater for a translating beam than for one that is not translating. In the supercritical speed range, asymmetry of the non-linear stiffness distribution biases finite-amplitude vibration toward the straight configuration and lowers the effective modal stiffness. The linear vibration theory underestimates stability in the subcritical range, overestimates it for supercritical speeds, and is most limited in the near-critical regime.
发表于 2012-2-17 11:04 | 显示全部楼层
Abstract
A method is developed to evaluate the natural frequencies and vibration modes of serpentine belt drives where the belt is modeled as a moving beam with bending stiffness. Inclusion of bending stiffness leads to belt-pulley coupling not captured in moving string models. New dynamic characteristics of the system induced by belt bending stiffness are investigated. The belt-pulley coupling is studied through the evolution of the vibration modes. When the belt-pulley coupling is strong, the dynamic behavior of the system is quite different from that of the string model where there is no such coupling. The effects of major design variables on the system are discussed. The spatial discretization can be used to solve other hybrid continuous/discrete eigenvalue problems.
GMT+8, 2024-11-29 12:35 , Processed in 0.096852 second(s), 18 queries , Gzip On.
