查看: 1296|回复: 1
[分形与混沌] CC算法出现的问题
发表于 2010-3-24 15:52 | 显示全部楼层 |阅读模式
data=b(:,1);N=length(data);
max_d=10;%the maximum value of the time delay
sigma=std(data);%calcute standard deviation s_d
    for t=1:max_d
    s_t=0;
    delt_s_s=0;
    for m=2:5
        s_t1=0;
        for j=1:4
            r=sigma*j/2;
           for i=1:t
    for j=1:N/t
        data_d(i,j)=data(i+(j-1)*t);
            [ll,N_d]=size(data_d);
      s_t3=0;
        for i=1:t
            Y=data_d(i,:);
                sum_H=0;
for ii=1:N/t-1
    for jj=i+1:N/t
        d=max(abs(Y(:,ii)-Y(:,jj)));%计算相空间中每两点之间的距离,
        if r>d
        %sita=heaviside(r,d);%计算Heaviside 函数之值n
           sum_H=sum_H+1;
C_1(i)=2*sum_H/(N/t*(N/t-1));
N_r=N/t-(m-1); %相空间中点的个数
Data=zeros(m, N_r);
for j=1:N_r
  for i=1:m           %相空间重构
    Data(i,j)=data((i-1)*t+j);
  sum=0;
for ii=1:N_r-1
    for jj=i+1:N_r
        d=norm((Data(:,ii)-Data(:,jj)),inf);%计算相空间中每两点之间的距离,其中NORM(V,inf) = max(abs(V)).
        if r>d
           sum=sum+1;
C_I(i)=2*sum/(N_r*(N_r-1));
   a=C_I(i)-C_1(i)^m;%对t个不相关的时间序列求和
          s_t3=s_t3+a;
          s_t2(j)=s_t3/t;
            s_t1=s_t1+s_t2(j);%对rj求和
        delt_s_m(m)=max(s_t2)-min(s_t2);%求delt S(m,t)
        delt_s_s=delt_s_s+delt_s_m(m);%delt S(m,t)对m求和
        s_t0(m)=s_t1;
        s_t=s_t+s_t0(m);%S对m求和
    s(t)=s_t/16;
    delt_s(t)=delt_s_s/4;
    s_cor(t)=delt_s(t)+abs(s(t));
fid=fopen('result.txt','w');
fprintf(fid,'%f %f %f %f/n',t,s(t),delt_s(t),s_cor(t));
fclose(fid);
t=1:max_d;
plot(t,s,t,delt_s,'.',t,s_cor,'*')
运行完之后总会出现如下问题
??? Attempted to access C_1(2); index out of bounds because numel(C_1)=1.
 楼主| 发表于 2010-3-24 15:54 | 显示全部楼层
还望各位高手指点
GMT+8, 2025-1-6 14:18 , Processed in 0.060005 second(s), 17 queries , Gzip On.
