查看: 1208|回复: 1
[结构分析] 求助,在瞬态分析读取TXT文档中荷载时出问题
发表于 2010-3-19 00:15 | 显示全部楼层 |阅读模式
如题:
我的程序如下
/config,nres,10000
*set,t1,0
*set,t2,200
*set,t3,0.5
amum=(t2-t1)/t3+1
*dim,nodel,array,1
nodel(1)=1
*dim,aan,table,amum,1,1,,,
*tread,aan,E:\luoqishao\xiaoluo,txt,,
但是会出现提示:
*tread end-of-file in data read
这是什么原因呢?
我的TXT文档时下面的这个排列
0.2864
0.8024
0.2419
0.7612
1.684
-0.59
-0.77
0.6944
1.3127
0.4484
1.9277
0.3159
0.8575
0.1286
0.763
1.5303
1.4464
2.4816
2.0273
2.1707
-0.4409
0.7259
-0.8735
-3.1068
-5.9747
-4.1924
-2.8496
-0.0382
-0.9223
-0.4096
-0.7859
-0.7568
-0.9773
-0.2669
1.3873
0.3227
2.0813
2.8129
3.3885
3.9299
1.9309
1.1292
2.7487
3.5769
2.5763
1.6115
0.3612
0.2602
-0.6641
0.4025
-0.9678
-2.0414
-1.5072
-2.4148
-1.3366
-2.1834
0.2725
0.2425
-1.2723
-1.563
1.8294
1.3376
0.5333
-0.0039
-0.8618
-0.5684
1.8072
3.7543
2.3256
0.0399
-0.6499
-1.2164
-0.2708
-1.0776
0.3224
1.1769
1.4399
-0.8524
-1.2414
2.1607
4.007
1.9015
1.5136
1.9378
2.0407
4.8202
1.6432
0.5788
1.4663
3.5497
2.789
1.5228
1.3288
2.4779
3.0919
1.7882
0.8376
-1.1202
-0.8536
-0.1663
0.3408
-0.5168
-1.2603
0.2024
0.9496
2.7025
-0.1295
-1.3078
0.0146
-0.4661
-0.1089
-0.3593
-0.0189
0.5476
0.4349
0.7476
0.5304
0.9731
-0.7899
0.1471
2.8574
2.2111
1.6836
1.7579
0.4903
-0.468
0.3199
-1.2669
-2.9753
-1.4773
0.1518
0.7094
-0.2391
-1.9444
-0.4422
1.2427
1.7047
1.241
0.8396
-0.5136
0.2215
1.0317
0.6899
0.2044
-0.6676
-1.9499
-0.552
-0.5886
-1.4378
-1.3716
-0.5827
-1.4063
-0.9215
-2.394
-0.495
-0.5954
-2.2311
-1.1806
-3.0682
-3.3962
-1.9041
-0.1289
-0.7103
-0.9743
-0.3484
-1.0654
1.2076
-0.622
-1.3377
-1.4058
-1.0135
0.9853
-0.5161
-0.8059
0.0681
1.2018
1.2905
1.0845
-0.7758
0.9774
-0.2867
-1.2127
0.6801
0.9732
2.1131
2.0867
1.5674
0.2734
-0.1305
1.3364
1.6218
2.8175
2.1463
1.1008
-0.3674
-1.6507
-0.3927
0.9833
1.3072
1.5311
2.9474
1.3344
-1.1342
-1.3473
0.9511
-0.1071
-0.0986
0.8171
0.3058
-0.0836
-1.5322
-0.6824
-1.1786
-1.9594
-2.4858
-2.461
-1.0823
-0.8201
1.0792
0.3975
-1.5811
-4.2885
-4.0037
-2.2885
-3.0778
-2.8503
0.4838
0.2985
-1.1588
-1.0994
-2.3333
0.1144
0.0198
-1.1214
-1.9268
-1.3953
-0.2529
-1.2058
-0.6634
0.1541
0.1265
-1.0994
-0.5113
0.599
-0.4671
-1.2237
-3.4709
-2.7736
-0.0971
1.8786
-0.5071
-0.1597
0.4186
-0.4671
0.0246
0.327
-0.3684
0.2378
1.4097
-1.1608
-0.3856
-0.0385
-0.2588
-1.463
-1.0737
-0.1026
1.5854
2.3641
2.3787
0.6614
-0.8373
-0.9165
-1.218
-1.256
-0.7793
-0.2066
-0.5285
-1.3654
-1.0699
-1.3712
-1.1712
-1.0527
-1.0687
-1.7504
-0.9109
0.7982
-1.6506
-0.5514
1.0922
0.8822
0.9303
2.0775
0.2486
-1.3126
-1.9768
-1.6124
0.4458
0.3929
0.4394
-0.2398
-1.6237
0.232
1.1978
-0.4306
-0.8304
0.9097
-0.1635
0.0992
0.2017
-0.1894
1.469
1.5748
-1.0568
2.6932
2.9068
1.4219
-0.3593
-0.7398
-0.1388
-0.6794
0.1177
0.7544
-0.474
0.9016
0.5906
-0.2436
-0.054
-0.2864
-0.2613
0.6121
0.646
0.6098
-0.7243
-0.6678
0.823
1.8305
2.4577
1.4016
0.8017
3.1215
3.7925
5.3332
0.848
0.6557
-0.6571
-1.3471
0.2739
0.7781
1.7393
1.7104
-0.8154
0.5829
1.8678
-1.6482
0.4323
-0.3642
-0.4446
-1.3203
-1.2543
-0.9351
-1.3256
-0.8034
0.7787
-1.1843
-2.3027
-1.7484
-0.747
-0.8119
-0.451
-2.1553
-3.5152
-4.2049
-5.1299
-2.6931
-0.5014
0.5951
-2.3281
-2.7817
-2.0995
-0.3259
-0.7607
-2.6122
-1.9127
-2.0365
-1.0595
-1.9254
-1.6944
-0.3036
-2.7421
1.5376
0.0657
-0.7513
0.3182
1.4044
0.4206
1.9708
-0.0245
-0.707
-0.745
0.2788
0.3681
求高手解答,现在很困惑
 楼主| 发表于 2010-3-19 13:43 | 显示全部楼层
该问题刚刚解决了,程序没有问题,关键在于必须从命令流中读入,而不能在命令行中输入
GMT+8, 2025-1-27 08:00 , Processed in 0.060121 second(s), 17 queries , Gzip On.
