查看: 2698|回复: 1
下载了wcdma_simulink程学,可是里面很多关键的.mexsol文件。请问这是什么???
发表于 2006-3-30 09:48 | 显示全部楼层 |阅读模式
下载了wcdma_simulink程学,可是里面很多关键的.mexsol文件。请问这是什么???我估计可能是s函数编译以后的结果,如果想看里面的文件怎么办?.mdl文件都有,自定义模块指向了这些。mexsol文件。请教高手
发表于 2006-4-2 13:31 | 显示全部楼层
回复:(shark80)下载了wcdma_simulink程学,可是里面...
To compile and link the source files written in C, at the MATLAB prompt, type the command mex. This will create a mexsol file, which will behave exactly like an M-file in MATLAB. You can also combine several object and use libraries while building MEX-file
GMT+8, 2025-2-20 09:00 , Processed in 0.089453 second(s), 18 queries , Gzip On.
