查看: 4461|回复: 1
[Fluent应用] 求助:单机多核带UDF并行计算fluent出错
发表于 2009-12-15 23:11 | 显示全部楼层 |阅读模式
interpreted UDF通过了,但是一开始计算就出现下述问题,是怎么回事?请指教!
unable to read the cmd header on the pmi context, Undefined dynamic error code.
999999 (..\..\src\mpsystem.c@1123): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 4 bytes: No such file or directory
received suspend command for a pmi context that doesn't exist: unmatched id = 3
received suspend command for a pmi context that doesn't exist: unmatched id = 2
received suspend command for a pmi context that doesn't exist: unmatched id = 0
job aborted:
rank: node: exit code[: error message]
0: HUXUEQIN: -1073741819: process 0 exited without calling finalize
1: HUXUEQIN: -1073741819: process 1 exited without calling finalize
2: HUXUEQIN: -1073741819: process 2 exited without calling finalize
3: HUXUEQIN: -1073741819: process 3 exited without calling finalize
The Parallel FLUENT process could not be started.
发表于 2010-1-26 09:03 | 显示全部楼层
单机多核可以实现多线程,未必是并行运算。
GMT+8, 2024-11-25 10:04 , Processed in 0.086655 second(s), 17 queries , Gzip On.
