查看: 3890|回复: 2
[CFX应用] cfx流固耦合计算出现错误!!!高人指点啊
发表于 2009-12-1 22:37 | 显示全部楼层 |阅读模式
*** WARNING ***                         CP =      12.328   TIME= 22:02:41
Shape testing revealed that 396 of the 54982 new or modified elements
violate shape warning limits.  To review test results, please see the
output file or issue the CHECK command.
  ***** ROUTINE COMPLETED *****  CP =        14.219
*** WARNING ***                         CP =      58.234   TIME= 22:03:58
Zero thickness element 132623 may result in wrong thermal or bending
stress.  Check real constant table 11.
*** NOTE ***                            CP =      60.719   TIME= 22:04:00
The initial memory allocation (-m) has been exceeded.
  Supplemental memory allocations are being used.
*** ERROR ***                           CP =      82.984   TIME= 22:05:22
There is not enough memory for the Block Lanczos solver to proceed.
Please increase the virtual memory on your system and/or increase the
work space memory and rerun ANSYS.  Alternatively, forcing the use of
the minimum out-of-core memory mode (BCSOPTION,,MINIMUM) may allow a
solution to be achieved without increasing the system memory or
decreasing the problem size.  The memory currently allocated by ANSYS
= 482 MB.  The memory allocation attempted = 267 MB.  The largest
block of ANSYS memory available for the Block Lanczos solver = 153 MB.
 楼主| 发表于 2009-12-2 10:52 | 显示全部楼层
回复 楼主 kangking 的帖子
补充一下:
我的流体部分网格是fluent的gambit中建立的。定义了流固耦合的接触面,问题大概是这样的,我在gambit中建立了水下船体的计算域(长方体),在ansys中建立了水下船头球匕首部分(只建立了球匕首部分的结构)的固体结构,指定了fsi 流固耦合的接触面,流体域使用Tgrid分网的,但是在球匕首船体壁面上式四边形网格体部分是四面体tgrid,固体部分的网格为四边形网格,网格大小比gambit中四边形网格小。
gambit流体部分的网格单元大约63万,ansys中有13万个nodes。
问题:
1. 我在ansys中建立了球匕首部分,导出cdb文件,再将cdb文件导入ansys生成dat文件时就出现了上述第一个错误。
2.另外一方面,我在忽略了这个错误后强行计算就出现了上述内存不足的问题。也出现了这个上述第一个错误提示。
发表于 2013-9-11 20:44 | 显示全部楼层
你做的是单向还是双向流固耦合
GMT+8, 2025-3-13 17:23 , Processed in 0.092283 second(s), 17 queries , Gzip On.
