查看: 1521|回复: 2
[理论方法] 大家帮我看一下这个c_c方法的时间延迟的程序运行结果??
发表于 2009-11-11 16:30 | 显示全部楼层 |阅读模式
N=length(data);
max_d=200;%the maximum value of the time delay
sigma=std(data);%calcute standard deviation s_d
for t=1:max_d
     s_t=0;
     delt_s_s=0;
     for m=2:5
         s_t1=0;
         for j=1:4
             r=sigma*j/2;
             data_d=disjoint(data,N,t);%将时间序列分解成t个不相交的时间序列
             N_d=size(data_d);
             s_t3=0;
             for i=1:t
                 i;
                 Y=data_d(i,:);
                 C_1(i)=correlation_integral1(Y,N_d,r);%计算C(1,N_d,r,t)
                 X=reconstitution(Y,N_d,m,t);%相空间重构
                 N_r=N_d-(m-1)*t;
                 C_I(i)=correlation_integral(X,N_r,r);%计算C(m,N_r,r,t)
                 s_t3=s_t3+(C_I(i)-C_1(i)^m);%对t个不相关的时间序列求和
             s_t2(j)=s_t3/t;
             s_t1=s_t1+s_t2(j);%对rj求和
         delt_s_m(m)=max(s_t2)-min(s_t2);%求delt S(m,t)
         delt_s_s=delt_s_s+delt_s_m(m);%delt S(m,t)对m求和
         s_t0(m)=s_t1;
         s_t=s_t+s_t0(m);%S对m求和
     s(t)=s_t/16;
     delt_s(t)=delt_s_s/4;
     s_cor(t)=delt_s(t)+abs(s(t));
fid=fopen('result.txt','w');
fprintf(fid,'%f %f %f %f/n',t,s(t),delt_s(t),s_cor(t));
fclose(fid);
t=1:max_d;
plot(t,s,t,delt_s,'.',t,s_cor,'*')
function C_I=correlation_integral(Y,M,r)
% 此函数用于计算关联积分,取无穷范数
% Y为重构的相空间
% M为相空间中点的个数
% r为搜索半径
% Y为输出,是M*m维矩阵
C=0;
for i=1:M-1
     for j=i+1:M
         d=norm((Y(:,i)-Y(:,j)),inf);      % 计算状态空间中每两点之间的距离,取无穷范数
         if r-d>=0
             C=C+1;
C_I=2*C/(M*(M-1));
??? Error using ==> mtimes
Inner matrix dimensions must agree.
Error in ==> correlation_integral1 at 17
C_I=2*C/(M*(M-1));
Error in ==> c_c at 18
这是怎么回事啊,望各位指点
发表于 2009-11-13 11:10 | 显示全部楼层
:@L :@L :@L :@L
 楼主| 发表于 2009-11-13 21:46 | 显示全部楼层
啥意思啊,是指调用出错?
GMT+8, 2025-1-27 06:19 , Processed in 0.078249 second(s), 17 queries , Gzip On.
