查看: 2753|回复: 1
[ADAMS专区] 曲轴柔性体替换刚性体时出问题
发表于 2009-9-14 16:07 | 显示全部楼层 |阅读模式
WARNING: The distance between the J marker and the I marker is 0.1256680455.
          (No warnings if less than +/-1.0E-003)
          Revolute Joint = .MODEL_1.JOINT_13
          I Marker = .MODEL_1.PART5.MARKER_25
          J Marker = .MODEL_1.PART2_flex.MARKER_26
WARNING: The distance between the J marker and the I marker is 3.8422193915E-002.
          Revolute Joint = .MODEL_1.JOINT_14
          I Marker = .MODEL_1.PART2_flex.MARKER_27
          J Marker = .MODEL_1.ground.MARKER_28
WARNING:    The markers for JOINT MODEL_1.JOINT_13 are not initially coincident.
   The relative displacement between the markers, expressed in the
   J marker coordinate frame is:
   Delta X = 6.09265E-02   Delta Y = -8.46021E-05   Delta Z = -0.10991.
WARNING:    The markers for JOINT MODEL_1.JOINT_14 are not initially coincident.
   Delta X = -9.26499E-04   Delta Y = 8.46021E-05   Delta Z = 3.84109E-02.
WARNING:    The corrector has not converged after 6 attempts. No. of iterations = 10.
ERROR:      The simulation is terminating at time = 0.0.
   ADAMS can not solve the equations of motion because the mechanism has
   "locked up."    At least one constraint  can  no longer be satisfied.
   ADAMS is unable to satisfy the constraint for: ??? .
ERROR:   Lockup detected
哪位知道什么原因,请指教!谢谢
[ 本帖最后由 xzsjjn 于 2009-9-14 16:08 编辑 ]
发表于 2013-6-24 15:47 | 显示全部楼层
我也遇到这个问题了。请问,您这个问题怎么解决的呢?
GMT+8, 2024-12-28 14:13 , Processed in 0.089045 second(s), 18 queries , Gzip On.
