查看: 2099|回复: 0
[综合讨论] matlab紧急求助:关于matlab自动关闭的问题
发表于 2009-9-14 14:57 | 显示全部楼层 |阅读模式
我的matlab7.4版本的,在M文件窗口,和主窗口切换的时候总是自动关闭,并有以下输出M文件:内容如下。有哪位高手帮忙解决一下。
附注:http://forum.vibunion.com/forum/thread-19124-1-1.html中解决方法不管用的。我试过了。有谁遇到过类似问题的,帮帮忙,先行谢过!
# An unexpected error has been detected by HotSpot Virtual Machine:
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x02ab32fe, pid=2668, tid=984
# Java VM: Java HotSpot(TM) Client VM (1.5.0_07-b03 mixed mode)
# Problematic frame:
# C  [SOGOUPY.IME+0x432fe]
---------------  T H R E A D  ---------------
Current thread (0x09798a40):  JavaThread "AWT-Windows" daemon [_thread_in_native, id=984]
siginfo: ExceptionCode=0xc0000005, reading address 0x00000024
Registers:
EAX=0x00000000, EBX=0x0a0ff8d4, ECX=0x00000000, EDX=0x7c92e514
ESP=0x0a0ff8a4, EBP=0x00000000, ESI=0x000817c0, EDI=0x000007f1
EIP=0x02ab32fe, EFLAGS=0x00010246
Top of Stack: (sp=0x0a0ff8a4)
0x0a0ff8a4:   0a0ff98c 000817c0 00000000 02ab0ed7
0x0a0ff8b4:   02c926b0 000817c0 00000000 02ab0fc2
0x0a0ff8c4:   000007f1 003203d6 00000000 77d188a6
0x0a0ff8d4:   00000000 02ab0dcb 000817c0 003203d6
0x0a0ff8e4:   000007f1 00000000 00000000 0a0ff970
0x0a0ff8f4:   0a0ff934 00000000 02ab0e3d 00000000
0x0a0ff904:   00000000 02ab0de0 77d18734 003203d6
0x0a0ff914:   000007f1 00000000 00000000 02ab0de0
Instructions: (pc=0x02ab32fe)
0x02ab32ee:   b4 bc 02 85 c0 75 1f 8b 4e 0c 88 86 bc 08 00 00
0x02ab32fe:   39 41 24 74 11 8b 56 08 50 50 68 f0 07 00 00 52
Stack: [0x0a080000,0x0a100000),  sp=0x0a0ff8a4,  free space=510k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
[error occurred during error reporting, step 120, id 0xc0000005]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j  sun.awt.windows.WToolkit.eventLoop()V+0
j  sun.awt.windows.WToolkit.run()V+69
j  java.lang.Thread.run()V+11
v  ~StubRoutines::call_stub
---------------  P R O C E S S  ---------------
Java Threads: ( => current thread )
  0x09770ce8 JavaThread "Thread-12" [_thread_blocked, id=3524]
  0x09700188 JavaThread "Active Reference Queue Daemon" daemon [_thread_blocked, id=3320]
  0x096fa318 JavaThread "Timer-3" daemon [_thread_blocked, id=2956]
  0x099bd008 JavaThread "Prefs Updater" [_thread_blocked, id=2816]
  0x09b22c10 JavaThread "Timer-1" daemon [_thread_blocked, id=2104]
  0x09a28a20 JavaThread "TimerQueue" daemon [_thread_blocked, id=4044]
  0x09939e70 JavaThread "AWT-EventQueue-0" [_thread_in_native, id=2832]
  0x099562d8 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=3728]
  0x09667890 JavaThread "Timer-0" [_thread_blocked, id=3576]
=>0x09798a40 JavaThread "AWT-Windows" daemon [_thread_in_native, id=984]
  0x0923dd50 JavaThread "AWT-Shutdown" [_thread_blocked, id=2700]
  0x0656c690 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=2980]
  0x0656b390 JavaThread "CompilerThread0" daemon [_thread_blocked, id=3436]
  0x0656a750 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=1364]
  0x0655cae8 JavaThread "Finalizer" daemon [_thread_blocked, id=3800]
  0x0655bfa0 JavaThread "Reference Handler" daemon [_thread_blocked, id=3144]
  0x0164c018 JavaThread "main" [_thread_in_native, id=2748]
Other Threads:
  0x0651ccb8 VMThread [id=2456]
  0x06579970 WatcherThread [id=2392]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation   total 14848K, used 8949K [0x10010000, 0x11020000, 0x11810000)
  eden space 13248K,  66% used [0x10010000, 0x108a7898, 0x10d00000)
  from space 1600K,   9% used [0x10e90000, 0x10eb5d78, 0x11020000)
  to   space 1600K,   0% used [0x10d00000, 0x10d00000, 0x10e90000)
tenured generation   total 49152K, used 36027K [0x11810000, 0x14810000, 0x16010000)
   the space 49152K,  73% used [0x11810000, 0x13b3efa8, 0x13b3f000, 0x14810000)
compacting perm gen  total 32768K, used 22390K [0x16010000, 0x18010000, 0x18010000)
   the space 32768K,  68% used [0x16010000, 0x175eda10, 0x175edc00, 0x18010000)
No shared spaces configured.
Dynamic libraries:
0x00400000 - 0x004ee000  C:Program FilesMATLABR2007ainwin32MATLAB.exe
0x7c920000 - 0x7c9b6000  C:WINDOWSsystem32
tdll.dll
0x7c800000 - 0x7c91e000  C:WINDOWSsystem32kernel32.dll
0x78e80000 - 0x79088000  C:Program FilesMATLABR2007ainwin32libmwservices.dll
0x77d10000 - 0x77da0000  C:WINDOWSsystem32USER32.dll
0x77ef0000 - 0x77f39000  C:WINDOWSsystem32GDI32.dll
0x76320000 - 0x76367000  C:WINDOWSsystem32comdlg32.dll
0x77da0000 - 0x77e49000  C:WINDOWSsystem32ADVAPI32.dll
0x77e50000 - 0x77ee2000  C:WINDOWSsystem32RPCRT4.dll
0x77fc0000 - 0x77fd1000  C:WINDOWSsystem32Secur32.dll
0x5d170000 - 0x5d20a000  C:WINDOWSsystem32COMCTL32.dll
0x7d590000 - 0x7dd84000  C:WINDOWSsystem32SHELL32.dll
0x77be0000 - 0x77c38000  C:WINDOWSsystem32msvcrt.dll
0x77f40000 - 0x77fb6000  C:WINDOWSsystem32SHLWAPI.dll
0x78530000 - 0x7857c000  C:Program FilesMATLABR2007ainwin32libmx.dll
0x78200000 - 0x78298000  C:Program FilesMATLABR2007ainwin32icuuc32.dll
0x10000000 - 0x10006000  C:Program FilesMATLABR2007ainwin32icudt32.dll
0x78130000 - 0x781cb000  C:WINDOWSWinSxSx86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_6b128700MSVCR80.dll
0x78460000 - 0x7846e000  C:Program FilesMATLABR2007ainwin32libz.dll
0x78470000 - 0x7852e000  C:Program FilesMATLABR2007ainwin32libut.dll
0x002e0000 - 0x00395000  C:Program FilesMATLABR2007ainwin32icuin32.dll
0x003b0000 - 0x003bc000  C:Program FilesMATLABR2007ainwin32icuio32.dll
0x7c420000 - 0x7c4a7000  C:WINDOWSWinSxSx86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_6b128700MSVCP80.dll
0x76c60000 - 0x76c88000  C:WINDOWSsystem32imagehlp.dll
0x79730000 - 0x79789000  C:Program FilesMATLABR2007ainwin32libmwmathutil.dll
0x785b0000 - 0x785c8000  C:Program FilesMATLABR2007ainwin32mpath.dll
0x5fdd0000 - 0x5fe25000  C:WINDOWSsystem32NETAPI32.dll
0x71a20000 - 0x71a37000  C:WINDOWSsystem32WS2_32.dll
0x71a10000 - 0x71a18000  C:WINDOWSsystem32WS2HELP.dll
0x79540000 - 0x79575000  C:Program FilesMATLABR2007ainwin32mcr.dll
0x76990000 - 0x76acd000  C:WINDOWSsystem32ole32.dll
0x78580000 - 0x78590000  C:Program FilesMATLABR2007ainwin32libmex.dll
0x78750000 - 0x7879d000  C:Program FilesMATLABR2007ainwin32m_dispatcher.dll
0x782a0000 - 0x7845b000  C:Program FilesMATLABR2007ainwin32xerces-c_2_6.dll
0x78e60000 - 0x78e7c000  C:Program FilesMATLABR2007ainwin32datasvcs.dll
0x79290000 - 0x79353000  C:Program FilesMATLABR2007ainwin32libmwgui.dll
0x786c0000 - 0x78749000  C:Program FilesMATLABR2007ainwin32udd.dll
0x785d0000 - 0x786b5000  C:Program FilesMATLABR2007ainwin32mcos.dll
0x787a0000 - 0x78c01000  C:Program FilesMATLABR2007ainwin32m_interpreter.dll
0x79790000 - 0x79799000  C:Program FilesMATLABR2007ainwin32libmwmathrng.dll
0x78e20000 - 0x78e31000  C:Program FilesMATLABR2007ainwin32m_pcodeio.dll
0x00d90000 - 0x00d9a000  C:Program FilesMATLABR2007ainwin32mtok.dll
0x78c10000 - 0x78db7000  C:Program FilesMATLABR2007ainwin32m_parser.dll
0x78dc0000 - 0x78df1000  C:Program FilesMATLABR2007ainwin32m_ir.dll
0x78e40000 - 0x78e4c000  C:Program FilesMATLABR2007ainwin32ir_xfmr.dll
0x00de0000 - 0x00e10000  C:Program FilesMATLABR2007ainwin32profiler.dll
0x78590000 - 0x785ac000  C:Program FilesMATLABR2007ainwin32libmat.dll
0x00e30000 - 0x00ef8000  C:Program FilesMATLABR2007ainwin32libhdf5.dll
0x78e00000 - 0x78e15000  C:Program FilesMATLABR2007ainwin32m_pcodegen.dll
0x7a020000 - 0x7a038000  C:Program FilesMATLABR2007ainwin32ridge.dll
0x00f20000 - 0x00f2f000  C:Program FilesMATLABR2007ainwin32iqm.dll
0x79f80000 - 0x79fca000  C:Program FilesMATLABR2007ainwin32comcli.dll
0x770f0000 - 0x7717b000  C:WINDOWSsystem32OLEAUT32.dll
0x79f40000 - 0x79f77000  C:Program FilesMATLABR2007ainwin32jmi.dll
0x71a40000 - 0x71a4b000  C:WINDOWSsystem32WSOCK32.dll
0x791b0000 - 0x79231000  C:Program FilesMATLABR2007ainwin32uiw.dll
0x79240000 - 0x79273000  C:Program FilesMATLABR2007ainwin32libuij.dll
0x79510000 - 0x7953c000  C:Program FilesMATLABR2007ainwin32libmwhardcopy.dll
0x79280000 - 0x79289000  C:Program FilesMATLABR2007ainwin32uinone.dll
0x00fa0000 - 0x010af000  C:WINDOWSWinSxSx86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_3bf8fa05MFC80.DLL
0x72f70000 - 0x72f96000  C:WINDOWSsystem32WINSPOOL.DRV
0x7c630000 - 0x7c64b000  C:WINDOWSWinSxSx86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_cbb27474ATL80.DLL
0x79ec0000 - 0x79ed4000  C:Program FilesMATLABR2007ainwin32mwoles05.DLL
0x79ee0000 - 0x79f3b000  C:Program FilesMATLABR2007ainwin32udd_mi.dll
0x79fd0000 - 0x79fdb000  C:Program FilesMATLABR2007ainwin32mlautoregister.dll
0x79360000 - 0x794c3000  C:Program FilesMATLABR2007ainwin32hg.dll
0x79580000 - 0x79725000  C:Program FilesMATLABR2007ainwin32
umerics.dll
0x79dd0000 - 0x79dd7000  C:Program FilesMATLABR2007ainwin32libmwamd.dll
0x79de0000 - 0x79e38000  C:Program FilesMATLABR2007ainwin32libmwcholmod.dll
0x79e40000 - 0x79e47000  C:Program FilesMATLABR2007ainwin32libmwcolamd.dll
0x797a0000 - 0x797c3000  C:Program FilesMATLABR2007ainwin32libmwlapack.dll
0x79810000 - 0x79897000  C:Program FilesMATLABR2007ainwin32libfftw3.dll
0x798a0000 - 0x7993b000  C:Program FilesMATLABR2007ainwin32libfftw3f.dll
0x79e50000 - 0x79ebc000  C:Program FilesMATLABR2007ainwin32libmwumfpack.dll
0x76300000 - 0x7631d000  C:WINDOWSsystem32IMM32.DLL
0x62c20000 - 0x62c29000  C:WINDOWSsystem32LPK.DLL
0x73fa0000 - 0x7400b000  C:WINDOWSsystem32USP10.dll
0x60000000 - 0x6009b000  C:WINDOWSsystem32kmon.dll
0x77180000 - 0x77283000  C:WINDOWSWinSxSx86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83comctl32.dll
0x5d360000 - 0x5d36a000  C:WINDOWSWinSxSx86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_91481303MFC80CHS.DLL
0x7bdf0000 - 0x7be25000  C:Program FilesMATLABR2007ainwin32libguide40.dll
0x797d0000 - 0x797f8000  C:Program FilesMATLABR2007ainwin32mkl.dll
0x79800000 - 0x79805000  C:Program FilesMATLABR2007ainwin32mklcompat.dll
0x79940000 - 0x79dc3000  C:Program FilesMATLABR2007ainwin32mllapack.dll
0x02510000 - 0x025ba000  C:Program FilesMATLABR2007ainwin32libifcoremd.dll
0x025c0000 - 0x027f0000  C:Program FilesMATLABR2007ainwin32libmmd.dll
0x02900000 - 0x0292d000  C:Program FilesRisingAntiSpywarecomx3.dll
0x02930000 - 0x02949000  C:Program FilesRisingAntiSpywareSyslay.dll
0x76f20000 - 0x76f28000  C:WINDOWSsystem32Wtsapi32.dll
0x762d0000 - 0x762e0000  C:WINDOWSsystem32WINSTA.dll
0x75c60000 - 0x75d00000  C:WINDOWSsystem32urlmon.dll
0x77bd0000 - 0x77bd8000  C:WINDOWSsystem32VERSION.dll
0x5adc0000 - 0x5adf7000  C:WINDOWSsystem32uxtheme.dll
0x02a00000 - 0x02a2f000  C:Program Files360safesafemonsafemon.dll
0x76680000 - 0x76726000  C:WINDOWSsystem32WININET.dll
0x765e0000 - 0x76673000  C:WINDOWSsystem32CRYPT32.dll
0x76db0000 - 0x76dc2000  C:WINDOWSsystem32MSASN1.dll
0x76bc0000 - 0x76bcb000  C:WINDOWSsystem32PSAPI.DLL
0x73640000 - 0x7366e000  C:WINDOWSsystem32msctfime.ime
0x02a70000 - 0x02c7c000  C:WINDOWSsystem32SOGOUPY.IME
0x762f0000 - 0x762f5000  C:WINDOWSsystem32MSIMG32.dll
0x02e50000 - 0x02e82000  C:Program FilesSogouInput4.2.3.2810Resource.dll
0x76cb0000 - 0x76cd0000  C:WINDOWSsystem32NTMARTA.DLL
0x71b70000 - 0x71b83000  C:WINDOWSsystem32SAMLIB.dll
0x76f30000 - 0x76f5c000  C:WINDOWSsystem32WLDAP32.dll
0x741f0000 - 0x741f4000  C:WINDOWSsystem32icmp.Dll
0x76d30000 - 0x76d48000  C:WINDOWSsystem32iphlpapi.dll
0x6d6c0000 - 0x6d857000  C:Program FilesMATLABR2007asysjavajrewin32jre1.5.0_07inclientjvm.dll
0x76b10000 - 0x76b3a000  C:WINDOWSsystem32WINMM.dll
0x6d280000 - 0x6d288000  C:Program FilesMATLABR2007asysjavajrewin32jre1.5.0_07inhpi.dll
0x6d690000 - 0x6d69c000  C:Program FilesMATLABR2007asysjavajrewin32jre1.5.0_07inverify.dll
0x6d300000 - 0x6d31d000  C:Program FilesMATLABR2007asysjavajrewin32jre1.5.0_07injava.dll
0x6d6b0000 - 0x6d6bf000  C:Program FilesMATLABR2007asysjavajrewin32jre1.5.0_07inzip.dll
0x6d000000 - 0x6d167000  C:Program FilesMATLABR2007asysjavajrewin32jre1.5.0_07inawt.dll
0x7b330000 - 0x7b342000  C:Program FilesMATLABR2007ainwin32
ativejava.dll
0x0a110000 - 0x0a123000  C:Program FilesMATLABR2007ainwin32
ativejmi.dll
0x0a1c0000 - 0x0a1c6000  C:Program FilesMATLABR2007ainwin32
ativeservices.dll
0x6d240000 - 0x6d27f000  C:Program FilesMATLABR2007asysjavajrewin32jre1.5.0_07infontmanager.dll
0x6d4c0000 - 0x6d4d3000  C:Program FilesMATLABR2007asysjavajrewin32jre1.5.0_07in
et.dll
0x6d4e0000 - 0x6d4e9000  C:Program FilesMATLABR2007asysjavajrewin32jre1.5.0_07in
io.dll
0x7b350000 - 0x7b356000  C:Program FilesMATLABR2007ainwin32
ativelex.dll
0x0a500000 - 0x0a50c000  C:Program FilesMATLABR2007ainwin32
ativecmdwin.dll
0x05b20000 - 0x05b36000  D:Program FilesLingoesTranslator2opentext2.dll
0x05c60000 - 0x05c6c000  C:WINDOWSSystem32spoolDRIVERSW32X863mdiui.dll
0x3fde0000 - 0x40221000  C:WINDOWSsystem32msi.dll
0x6d1c0000 - 0x6d1e3000  C:Program FilesMATLABR2007asysjavajrewin32jre1.5.0_07indcpr.dll
0x79090000 - 0x791a3000  C:Program FilesMATLABR2007ainwin32libmwbuiltins.dll
0x76d70000 - 0x76d92000  C:WINDOWSsystem32Apphelp.dll
VM Arguments:
jvm_args: -Xss512k -XX:PermSize=32M -Xms64m -XX:NewRatio=3 -XX:MaxPermSize=32M -Xmx96m -Dsun.java2d.noddraw=true -Dsun.awt.nopixfmt=true -Xshare:off -Djava.library.path=C:Program FilesMATLABR2007ainwin32 vfprintf abort
java_command: <unknown>
Launcher Type: generic
Environment Variables:
PATH=C:WINDOWSsystem32;C:WINDOWS;C:WINDOWSsystem32wbem;C:Program FilesMATLABR2007ain;C:Program FilesMATLABR2007ainwin32;C:Program FilesCommon FilesTTKNBin;C:Program FilesCommon FilesThunder NetworkKanKanCodecs;C:Program FilesStormIICodec;C:Program FilesStormII
USERNAME=Administrator
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 6 Model 15 Stepping 13, GenuineIntel
---------------  S Y S T E M  ---------------
OS: Windows XP Build 2600 Service Pack 3
CPU:total 2 family 6, cmov, cx8, fxsr, mmx, sse, sse2, ht
Memory: 4k page, physical 2096620k(1355468k free), swap 4034616k(3242368k free)
vm_info: Java HotSpot(TM) Client VM (1.5.0_07-b03) for windows-x86, built on May  3 2006 01:04:38 by "java_re" with MS VC++ 6.0
[ 本帖最后由 大鹏之举 于 2009-9-14 15:02 编辑 ]
GMT+8, 2025-1-27 20:42 , Processed in 0.105193 second(s), 17 queries , Gzip On.
