查看: 1383|回复: 1
[材料与接触] 帮我看看接触分析结果
发表于 2009-8-17 21:44 | 显示全部楼层 |阅读模式
刚做了一对斜齿轮的接触分析,下面是接触对检查的结果:
*** NOTE ***                            CP =   16601.906   TIME= 16:03:19
Min.  Initial gap 0.120005019 was detected between contact element
135524 and target element 134860.
The gap is closed due to initial adjustment.
1 CONTACT PAIR IS SELECTED
     CONTACT PAIR HAVING REAL ID =     3 IS INITIALLY OPEN
      BUT MAY BE AUTOMATICALLY CLOSED
是通过gap close 选项闭合的间隙,不知道这样的接触对算不算是接触上了?
发表于 2012-4-17 16:30 | 显示全部楼层
应该是接触上了
GMT+8, 2025-1-10 23:28 , Processed in 0.057832 second(s), 18 queries , Gzip On.
