查看: 2021|回复: 0
[综合讨论] Matlab 6.5安装遇到的问题
发表于 2009-7-27 12:46 | 显示全部楼层 |阅读模式
我在装Matlab 6.5 时遇到一个问题,请高手指点:
点击setup图标,出现了以下窗口
     The installer needs a newer version of the Microsoft Java Virtual Machine.
     Do you want to install a answer version of the Microsoft Java Virtual Machine.
     Pressing Yes will install it and reboot your machine.
     If you are installing from a CD you should leave the CD in your CD-ROM drive so that the installer can automatically    start after you log on to the machine.
     Pressing No will exit the installer.
                   是                                      否
当点击“是”后,又出现了一个窗口
You
must restart your computer before the new settings will take effect
     Do you want tu restart your computer now?
当点击“是”,电脑重启又重复上面的两个现象。
如果在matab下的这两个文件msjavx86和jsjavx86都装上,再点击setup图标,还是重复上面两个现象,不知道是什么问题,机子上就是装不上Matlab 6.5这个软件
                多谢了 !
GMT+8, 2025-1-27 06:04 , Processed in 0.075414 second(s), 18 queries , Gzip On.
