查看: 5298|回复: 15
[Virtual.Lab] 介绍一篇关于多重声衍射解析计算和BEM计算的文章供参考
发表于 2009-7-17 17:34 | 显示全部楼层 |阅读模式
推荐一篇文章,其中提出了一种多重声衍射的解析计算方法,并使用sysnoise5.5提供的BEM结果对提出的解析方法进行了可靠的验证。可能对正在做多重衍射、声屏障计算、设计的朋友提供一些方法上的帮助;其中的实例都经过仔细验证,也可以给正在用SYSNOISE练手的朋友提供些验证实例,特别是在做声屏障计算方面。(两个附件存到本地后,将后缀名改为.rar即可正确解压并打开pdf)
国内目前有朋友(如武汉大学、北京劳保所)正在做Sound Scape的建模工作,其中对多种建筑或多重障碍物的声衍射(屏蔽)计算就比较头痛;我想这篇文章可以在这方面提供有益的帮助。
场合:多种声衍射;多重屏障、多重建筑物的声屏蔽计算
Multiple acoustic diffraction around rigid parallel wide barriers
J. Acoust. Soc. Am. Volume 126, Issue 1, pp. 179-186 (July 2009)
Issue Date: July 2009
Hequn Min and Xiaojun Qiu
State Key Laboratory of Modern Acoustics and Institute of Acoustics, Nanjing University, Nanjing 210093, People's Republic of China
A ray-based method is presented for evaluating multiple acoustic diffraction by separate rigid and parallel wide barriers, where two or more neighboring ones are of equal height. Based on the geometrical theory of diffraction and extended from the exact boundary solution for a rigid wedge, the proposed method is able to determine the multiple diffraction along arbitrary directions or at arbitrary receiver locations around the diffracting edges, including the positions along the shadow or reflection boundaries or very close to the edges. Comparisons between the results of the numerical simulations and the boundary element method show validity of the proposed method.
©2009 Acoustical Society of America
Keywords
acoustic wave diffraction, boundary-elements methods, receivers
Multiple acoustic diffraction around rigid parallel wide barriers.part1.txt (190.43 KB, 下载次数: 147)
Multiple acoustic diffraction around rigid parallel wide barriers.part2.txt (100.94 KB, 下载次数: 112)
[ 本帖最后由 minetree 于 2009-7-17 17:37 编辑 ]
发表于 2009-7-19 09:23 | 显示全部楼层
回复 楼主 minetree 的帖子
minetree,我对多重衍射很感兴趣,你是第几作者?有没有中文版本的?谢谢:@D ellips.wang@hotmail.com
发表于 2009-7-20 11:14 | 显示全部楼层
很牛,仿真与测试结果吻合的那么好,不可思议。。。。。
敢问楼主,你的建筑物尺寸很大吧,少说点也有3米;
计算到5kHz如何实现的,你的计算机很牛啊
 楼主| 发表于 2009-7-23 15:43 | 显示全部楼层
回复 沙发 w89986581 的帖子
呵呵还没有中文的,没来得及转,我是第一作者;这个方法我希望能有实用啊,欢迎借此讨论多重衍射的东西啊
 楼主| 发表于 2009-7-23 15:46 | 显示全部楼层
回复 板凳 hhhjjjhwc 的帖子
文章里面写了计算主机的配置,也一般,Q6600,4G内存而已,现在已经过时拉
的确不能过小,边边距离不能小于一个波长;里面的建筑模型,高度设置是3米左右,宽度比较小;这个符合实际的比例情况
发表于 2009-7-23 17:49 | 显示全部楼层
你应该是用边界元计算的吧?
直接边界元还是间接边界元?
模型你用的二维模型还是三维模型?
你们测试用的建筑物是居民房还是试验设备搭设的建议装置?
很佩服你们的计算?希望能多分享些你的经验,希望不吝赐教,谢谢!!
 楼主| 发表于 2009-7-23 19:46 | 显示全部楼层
回复 6楼 hhhjjjhwc 的帖子
>>你应该是用边界元计算的吧?
直接边界元还是间接边界元?
我用的是IBEM;不过这个无所谓,因为模型中没有自由边
>>模型你用的二维模型还是三维模型?
二维模型,模拟无限长屏障;因为要尽可能简化问题;其实文中方法可以用于各种形状的障碍物,只要衍射边之间的距离大于一个波长
没有测试,因为实际测量精度(3~5dB)无法反映提出方法的精度(2dB内)
多多讨论和交流,我对这方面很感兴趣,希望和各位讨论多重衍射相关建模(解析或数值)的各种问题,共同进步
发表于 2011-3-1 14:06 | 显示全部楼层
衍射边之间的距离  是指的哪个呢?
 楼主| 发表于 2011-3-1 15:00 | 显示全部楼层
任意两个edge之间的直线距离
发表于 2011-3-1 15:14 | 显示全部楼层
 楼主| 发表于 2011-3-1 15:53 | 显示全部楼层
这个在BEM中没关系的,仔细赋值好就行;不一定要相等,文章中算的是简单情况;建议你先算那个wide barrier的例子,先把BEM结果比对上
发表于 2011-3-2 17:59 | 显示全部楼层
现在有中文版的了么?
 楼主| 发表于 2011-3-7 09:50 | 显示全部楼层
附件是中文版,交流时请尊重原文知识版权,多谢
第五章 刚性平行屏障对声波的多重衍射.part2.rar (252.84 KB, 下载次数: 58)
第五章 刚性平行屏障对声波的多重衍射.part1.rar (273.44 KB, 下载次数: 52)
发表于 2011-4-8 23:30 | 显示全部楼层
在BEM计算过程边界条件的设置中,edge用不用设置边界跳动声压?还是边界跳动速度?
发表于 2011-9-15 11:04 | 显示全部楼层
谢谢分享
GMT+8, 2025-1-8 01:29 , Processed in 0.079917 second(s), 26 queries , Gzip On.
