查看: 1156|回复: 1
Combined Acoustic and Vibration Control Solution
发表于 2009-7-8 22:49 | 显示全部楼层 |阅读模式
  Combined Acoustic and Vibration Control Solution,我这有一篇文章,如有需要可email给大家。
  Abstract
  Successful product development requires simulation of complex environments. Design, validation and qualification engineering groups must perform these simulations to valid flight vehicles as well as to validate and optimize engineering designs. Economic factors limit the capital, facility and staff available to perform these tests. Advantages in performing these tests more quickly and safely translates into competitive advantage in allowing products to reach market more quickly and insure they perform as designed under the extreme stresses of a space launch. Acoustic as well as Vibration environments must be applied on test articles to specifications determined from actual flights and launches. Figure 1 is an example of a space launch environment. The white cloud seen during the space shuttle launch is not smoke it is water vapor. This is over 1 million gallons of water used to dampen the rocket exhausts sound level and the water vaporizes during the launch.
发表于 2009-7-15 13:28 | 显示全部楼层
楼主能否发到这个邮箱一份,tdyso2008@163.com,不胜感激
GMT+8, 2025-1-27 04:59 , Processed in 0.150905 second(s), 17 queries , Gzip On.
