楼主: Crocodilesky
[HHT] 给应用G.Rilling的EMD、但又没完成编译的朋友
发表于 2014-11-24 10:40 | 显示全部楼层
kankankjhkj
发表于 2014-12-3 12:06 | 显示全部楼层
ok,dkfhjkdsahfjadskhfjkdsa
发表于 2014-12-10 15:25 | 显示全部楼层
急切需要这个toolbox啊
发表于 2014-12-12 21:48 | 显示全部楼层
xiexiexiexie
发表于 2014-12-15 16:34 | 显示全部楼层
{:{03}:}
发表于 2014-12-16 13:44 | 显示全部楼层
楼主,你好,我是新注册的成员,没法下载附件,但是急用EMD的程序,能发给我一份么?邮箱2008.weifen@163.com。万分感谢!
发表于 2014-12-16 17:37 | 显示全部楼层
{:{03}:}
发表于 2014-12-16 17:44 | 显示全部楼层
发表于 2014-12-16 17:54 | 显示全部楼层
大家你好,我是新注册的会员,我迫切需要这个EMD这个算法,但是我现在级别不够,刚进来也不知道怎么弄,能不能麻烦您给我发一下这个程序啊,万分感谢,跪谢了。我的邮箱是418910599@qq.com
发表于 2014-12-18 17:10 | 显示全部楼层
2013a   安装出现的问题,求楼主指导
  1. >> install_emd
  2. cannot open output file C:\Documents and Settings\Administrator\×à??\package_emd\EMDs\emdc.mexw32:
  3.   D:\PROGRA~1\MATLAB~2\BIN\MEX.PL: Error: Link of 'C:\Documents and Settings\Administrator\×à??\package_emd\EMDs\emdc.mexw32' failed.
  4. cannot open output file C:\Documents and Settings\Administrator\×à??\package_emd\EMDs\emdc.mexw32:
  5.   D:\PROGRA~1\MATLAB~2\BIN\MEX.PL: Error: Link of 'C:\Documents and Settings\Administrator\×à??\package_emd\EMDs\emdc.mexw32' failed.
  6. cannot open output file C:\Documents and Settings\Administrator\×à??\package_emd\EMDs\emdc_fix.mexw32:
  7.   D:\PROGRA~1\MATLAB~2\BIN\MEX.PL: Error: Link of 'C:\Documents and Settings\Administrator\×à??\package_emd\EMDs\emdc_fix.mexw32' failed.
  8. cannot open output file C:\Documents and Settings\Administrator\×à??\package_emd\EMDs\emdc_fix.mexw32:
  9.   D:\PROGRA~1\MATLAB~2\BIN\MEX.PL: Error: Link of 'C:\Documents and Settings\Administrator\×à??\package_emd\EMDs\emdc_fix.mexw32' failed.
  10. lcc preprocessor error: cemdc.c:19 Could not find include file <complex.h>
  11. Error cemdc.c: .\cio.h: 31  syntax error; found `*' expecting `;'
  12. Error cemdc.c: .\cio.h: 31  skipping `*' `y'
  13. Error cemdc.c: .\cio.h: 39  syntax error; found `*' expecting `;'
  14. Error cemdc.c: .\cio.h: 39  skipping `*' `pointer'
  15. Error cemdc.c: .\cio.h: 53  syntax error; found `*' expecting `)'
  16. Error cemdc.c: .\cio.h: 53  skipping `*' `,'
  17. Error cemdc.c: .\cio.h: 53  missing name for parameter 1 to function `add_imf'
  18. Error cemdc.c: .\cio.h: 53  syntax error; found `int' expecting `{'
  19. Error cemdc.c: .\cio.h: 53  empty declaration
  20. Error cemdc.c: .\cio.h: 53  syntax error; found `)' expecting `;'
  21. Error cemdc.c: .\cio.h: 53  skipping `)'
  22. Error cemdc.c: .\cextr.h: 28  syntax error; found `*' expecting `)'
  23. Error cemdc.c: .\cextr.h: 28  skipping `*' `,'
  24. Error cemdc.c: .\cextr.h: 28  syntax error; found `double' expecting `;'
  25. Error cemdc.c: .\cextr.h: 28  empty declaration
  26. Error cemdc.c: .\cextr.h: 28  syntax error; found `,' expecting `;'
  27. Error cemdc.c: .\cextr.h: 28  skipping `,'
  28. Error cemdc.c: .\cextr.h: 28  empty declaration
  29. Error cemdc.c: .\cextr.h: 28  syntax error; found `,' expecting `;'
  30. Error cemdc.c: .\cextr.h: 28  too many errors
  31.   D:\PROGRA~1\MATLAB~2\BIN\MEX.PL: Error: Compile of 'cemdc.c' failed.
  32. cannot open output file C:\Documents and Settings\Administrator\×à??\package_emd\EMDs\cemdc.mexw32:
  33.   D:\PROGRA~1\MATLAB~2\BIN\MEX.PL: Error: Link of 'C:\Documents and Settings\Administrator\×à??\package_emd\EMDs\cemdc.mexw32' failed.
  34. lcc preprocessor error: cemdc_fix.c:19 Could not find include file <complex.h>
  35. Error cemdc_fix.c: .\cio_fix.h: 27  syntax error; found `*' expecting `;'
  36. Error cemdc_fix.c: .\cio_fix.h: 27  skipping `*' `y'
  37. Error cemdc_fix.c: .\cio_fix.h: 34  syntax error; found `*' expecting `;'
  38. Error cemdc_fix.c: .\cio_fix.h: 34  skipping `*' `pointer'
  39. Error cemdc_fix.c: .\cio_fix.h: 48  syntax error; found `*' expecting `)'
  40. Error cemdc_fix.c: .\cio_fix.h: 48  skipping `*' `,'
  41. Error cemdc_fix.c: .\cio_fix.h: 48  missing name for parameter 1 to function `add_imf'
  42. Error cemdc_fix.c: .\cio_fix.h: 48  syntax error; found `int' expecting `{'
  43. Error cemdc_fix.c: .\cio_fix.h: 48  empty declaration
  44. Error cemdc_fix.c: .\cio_fix.h: 48  syntax error; found `)' expecting `;'
  45. Error cemdc_fix.c: .\cio_fix.h: 48  skipping `)'
  46. Error cemdc_fix.c: .\cextr.h: 28  syntax error; found `*' expecting `)'
  47. Error cemdc_fix.c: .\cextr.h: 28  skipping `*' `,'
  48. Error cemdc_fix.c: .\cextr.h: 28  syntax error; found `double' expecting `;'
  49. Error cemdc_fix.c: .\cextr.h: 28  empty declaration
  50. Error cemdc_fix.c: .\cextr.h: 28  syntax error; found `,' expecting `;'
  51. Error cemdc_fix.c: .\cextr.h: 28  skipping `,'
  52. Error cemdc_fix.c: .\cextr.h: 28  empty declaration
  53. Error cemdc_fix.c: .\cextr.h: 28  syntax error; found `,' expecting `;'
  54. Error cemdc_fix.c: .\cextr.h: 28  too many errors
  55.   D:\PROGRA~1\MATLAB~2\BIN\MEX.PL: Error: Compile of 'cemdc_fix.c' failed.
  56. cannot open output file C:\Documents and Settings\Administrator\×à??\package_emd\EMDs\cemdc_fix.mexw32:
  57.   D:\PROGRA~1\MATLAB~2\BIN\MEX.PL: Error: Link of 'C:\Documents and Settings\Administrator\×à??\package_emd\EMDs\cemdc_fix.mexw32' failed.
  58. lcc preprocessor error: cemdc2.c:19 Could not find include file <complex.h>
  59. Error cemdc2.c: .\cio.h: 31  syntax error; found `*' expecting `;'
  60. Error cemdc2.c: .\cio.h: 31  skipping `*' `y'
  61. Error cemdc2.c: .\cio.h: 39  syntax error; found `*' expecting `;'
  62. Error cemdc2.c: .\cio.h: 39  skipping `*' `pointer'
  63. Error cemdc2.c: .\cio.h: 53  syntax error; found `*' expecting `)'
  64. Error cemdc2.c: .\cio.h: 53  skipping `*' `,'
  65. Error cemdc2.c: .\cio.h: 53  missing name for parameter 1 to function `add_imf'
  66. Error cemdc2.c: .\cio.h: 53  syntax error; found `int' expecting `{'
  67. Error cemdc2.c: .\cio.h: 53  empty declaration
  68. Error cemdc2.c: .\cio.h: 53  syntax error; found `)' expecting `;'
  69. Error cemdc2.c: .\cio.h: 53  skipping `)'
  70. Error cemdc2.c: .\clocal_mean2.h: 23  syntax error; found `*' expecting `)'
  71. Error cemdc2.c: .\clocal_mean2.h: 23  skipping `*' `,'
  72. Error cemdc2.c: .\clocal_mean2.h: 23  syntax error; found `double' expecting `;'
  73. Error cemdc2.c: .\clocal_mean2.h: 23  redeclaration of `complex' previously declared at .\cio.h 53
  74. Error cemdc2.c: .\clocal_mean2.h: 23  syntax error; found `*' expecting `;'
  75. Error cemdc2.c: .\clocal_mean2.h: 23  illegal expression
  76. Error cemdc2.c: .\clocal_mean2.h: 23  type error: pointer expected
  77. Warning cemdc2.c: .\clocal_mean2.h: 23  Statement has no effect
  78. Error cemdc2.c: .\clocal_mean2.h: 23  syntax error; found `double' expecting `;'
  79. Error cemdc2.c: .\clocal_mean2.h: 23  too many errors
  80.   D:\PROGRA~1\MATLAB~2\BIN\MEX.PL: Error: Compile of 'cemdc2.c' failed.
  81. cannot open output file C:\Documents and Settings\Administrator\×à??\package_emd\EMDs\cemdc2.mexw32:
  82.   D:\PROGRA~1\MATLAB~2\BIN\MEX.PL: Error: Link of 'C:\Documents and Settings\Administrator\×à??\package_emd\EMDs\cemdc2.mexw32' failed.
  83. lcc preprocessor error: cemdc2_fix.c:19 Could not find include file <complex.h>
  84. Error cemdc2_fix.c: .\cio_fix.h: 27  syntax error; found `*' expecting `;'
  85. Error cemdc2_fix.c: .\cio_fix.h: 27  skipping `*' `y'
  86. Error cemdc2_fix.c: .\cio_fix.h: 34  syntax error; found `*' expecting `;'
  87. Error cemdc2_fix.c: .\cio_fix.h: 34  skipping `*' `pointer'
  88. Error cemdc2_fix.c: .\cio_fix.h: 48  syntax error; found `*' expecting `)'
  89. Error cemdc2_fix.c: .\cio_fix.h: 48  skipping `*' `,'
  90. Error cemdc2_fix.c: .\cio_fix.h: 48  missing name for parameter 1 to function `add_imf'
  91. Error cemdc2_fix.c: .\cio_fix.h: 48  syntax error; found `int' expecting `{'
  92. Error cemdc2_fix.c: .\cio_fix.h: 48  empty declaration
  93. Error cemdc2_fix.c: .\cio_fix.h: 48  syntax error; found `)' expecting `;'
  94. Error cemdc2_fix.c: .\cio_fix.h: 48  skipping `)'
  95. Error cemdc2_fix.c: .\clocal_mean2.h: 23  syntax error; found `*' expecting `)'
  96. Error cemdc2_fix.c: .\clocal_mean2.h: 23  skipping `*' `,'
  97. Error cemdc2_fix.c: .\clocal_mean2.h: 23  syntax error; found `double' expecting `;'
  98. Error cemdc2_fix.c: .\clocal_mean2.h: 23  redeclaration of `complex' previously declared at .\cio_fix.h 48
  99. Error cemdc2_fix.c: .\clocal_mean2.h: 23  syntax error; found `*' expecting `;'
  100. Error cemdc2_fix.c: .\clocal_mean2.h: 23  illegal expression
  101. Error cemdc2_fix.c: .\clocal_mean2.h: 23  type error: pointer expected
  102. Warning cemdc2_fix.c: .\clocal_mean2.h: 23  Statement has no effect
  103. Error cemdc2_fix.c: .\clocal_mean2.h: 23  syntax error; found `double' expecting `;'
  104. Error cemdc2_fix.c: .\clocal_mean2.h: 23  too many errors
  105.   D:\PROGRA~1\MATLAB~2\BIN\MEX.PL: Error: Compile of 'cemdc2_fix.c' failed.
  106. cannot open output file C:\Documents and Settings\Administrator\×à??\package_emd\EMDs\cemdc2_fix.mexw32:
  107.   D:\PROGRA~1\MATLAB~2\BIN\MEX.PL: Error: Link of 'C:\Documents and Settings\Administrator\×à??\package_emd\EMDs\cemdc2_fix.mexw32' failed.
  108. Warning: The compilation of the following files failed:
  109. > In make_emdc at 48
  110.   In install_emd at 26
  111. emdc.c
  112. emdc_fix.c
  113. cemdc.c
  114. cemdc_fix.c
  115. cemdc2.c
  116. cemdc2_fix.c
  117. Some errors occurred during compilation. See details above.
  118. Installation complete. Run index_emd for a list of functions.
  119. IMPORTANT: After running INSTALL_EMD you must run the "savepath" command to save the installation
  120. but be careful that if you previously removed parts of the path (using e.g. the "rmpath" command)
  121. these will be permanently removed after you run "savepath"
发表于 2014-12-21 18:14 | 显示全部楼层
{:{03}:}{:{03}:}
反对: 5.0
反对: 5
请勿恶意灌水  发表于 2014-12-24 09:56
回复 支持 0 反对 1
发表于 2014-12-24 09:34 | 显示全部楼层
发表于 2014-12-24 09:35 | 显示全部楼层
谁可以给我发一份啊,新来的下载不了啊。谢谢了418910599@qq.com
发表于 2014-12-29 15:08 | 显示全部楼层
怎么下载
发表于 2014-12-30 10:51 | 显示全部楼层
怎么看不到啊
GMT+8, 2024-12-28 12:54 , Processed in 0.109815 second(s), 17 queries , Gzip On.
