查看: 3096|回复: 4
[电力电机类] 求助:异步电机的矢量控制simulink仿真
发表于 2009-7-2 15:49 | 显示全部楼层 |阅读模式
我做了一个异步电机的矢量控制simulink仿真,有一个问题一直解决不了,请高手帮忙解决一下
vector.mdl
98.96 KB, 下载次数: 106
 楼主| 发表于 2009-7-2 15:51 | 显示全部楼层
一直提示:invalid setting for output port dimensions of 'd2/Subsystem8/Subsystem8/Mux'. The dimensions are being set to 12. This is not valid because the total number of input and output elements are not the same.
Error in port widths or dimensions.  Output port 1 of 'd2/Subsystem8/Subsystem8/ 5' is a one dimensional vector with 1 elements.
发表于 2009-9-2 10:45 | 显示全部楼层
模型或者参数有错误
发表于 2013-5-6 13:57 | 显示全部楼层
{:{39}:}{:{39}:}{:{39}:}{:{39}:}{:{39}:}
发表于 2013-5-19 10:45 | 显示全部楼层
下来看看
GMT+8, 2025-2-20 16:45 , Processed in 0.084176 second(s), 22 queries , Gzip On.
