查看: 1806|回复: 3
[滤波] 请教低通数字滤波器
发表于 2009-6-28 16:41 | 显示全部楼层 |阅读模式
请教滤波器        我用的是正弦窗FIR滤波器。原信号是在0.5Hz正弦信号基础上叠加随机噪声得到的,下面是相关的程序,最后图中展示了“滤波前”。 滤波后为什么顶被削平了呢?我只想去掉高频噪声啊?高人指点应该怎么做,或者有什么不对的地方,谢谢!!!
首先生成基本的0.5Hz正弦信号:
Private Sub CommandButton1_Click()
Dim I As Integer
Dim X As Double
X = 0#
For I = 1 To 1000
    Cells(I, 1) = VBA.Sin(1 * 3.14159 * X)  '原始信号周期T=2s  原始信号频率Fs=0.5Hz 采样频率为50Hz
    X = X + 0.02   '0.02秒采集一个数据  采样频率=50Hz
Next I
End Sub
然后给基本信号加随机噪声:
Private Sub CommandButton2_Click()
   For I = 1 To 1000
      Cells(I, 2) = Cells(I, 1) + 0.4 * Rnd - 0.2
  Next I
End Sub
最后设计滤波器并滤波:
Public Sub FilterSinc()
     '低通 WINDOWED-SINC FIR滤波器
     'This program filters 1000 samples with a 33 point windowed-sinc
     'filter, resulting in 900 samples of filtered data.
     '                      'INITIALIZE AND DEFINE THE ARRAYS USED
     Dim X(0 To 999) As Long            'X( ) holds the input signal
     Dim Y(0 To 999) As Long            'Y( ) holds the output signal
     Dim H(0 to 32) As Double             'H( ) holds the filter kernel
     Dim Pi As Double
     Dim FC As Double
     Dim M, I, J As Integer
     Pi = 3.14159265
     FC =2          '截止频率 2Hz
     M = 32               '滤波器的核,即阶数
'加载数据
    For I = 0 To 999
        X(I) = Cells(I + 1, 2)
    Next I
    I = 0
'计算滤波器的核
     For I = 0 To 32
     If (I - M / 2) = 0 Then H(I) = 2 * Pi * FC
     If (I - M / 2) <> 0 Then H(I) = Sin(2 * Pi * FC * (I - M / 2)) / (I - M / 2)
        H(I) = H(I) * (0.54 - 0.46 * Cos(2 * Pi * I / M))
     Next I
'卷积滤波
     For J = 32 To 999
        Y(J) = 0
        For I = 0 To 32
           Y(J) = Y(J) + X(J - I) * H(I)
        Next I
        Cells(J, 3) = Y(J)
     Next J
End Sub
 楼主| 发表于 2009-6-28 22:24 | 显示全部楼层
期待高人点化~~~
跪请高人指点,等一晚上了,呵呵
 楼主| 发表于 2009-7-1 22:54 | 显示全部楼层
期待高人现身 ~~~~
 楼主| 发表于 2013-9-15 20:11 | 显示全部楼层
我苦苦等了4年啊,大哥啊大哥,出来说说吧
GMT+8, 2025-1-20 00:52 , Processed in 0.084578 second(s), 22 queries , Gzip On.
