查看: 2500|回复: 0
[其他相关] 关于s函数与其他进程之间的通信问题
发表于 2009-6-26 16:47 | 显示全部楼层 |阅读模式
目前我在做一个课题,要将simulink仿真数据实时传到一个windows进程然后再进行后面的驱动,通过共享内存和事件机制进行二进程之间的同步交互。
下面是s函数
#define S_FUNCTION_NAME  myport
#define S_FUNCTION_LEVEL 2
#include "simstruc.h"
#include "windows.h"
extern HANDLE hGlobalWriteEvent;
extern HANDLE hGlobalReadEvent;
real_T * pshareblock;
HANDLE hMapFile;
DWORD dwWaitResult;
//HANDLE OpenEvent0;
//HANDLE OpenEvent1;
static void mdlInitializeSizes(SimStruct *S)
    ssSetNumSFcnParams(S, 0);  /* Number of expected parameters */
    if (ssGetNumSFcnParams(S) != ssGetSFcnParamsCount(S)) {
        /* Return if number of expected != number of actual parameters */
        return;
    ssSetNumContStates(S, 0);
    ssSetNumDiscStates(S, 0);
    if (!ssSetNumInputPorts(S, 1)) return;
    ssSetInputPortWidth(S, 0, 6);
    ssSetInputPortDirectFeedThrough(S, 0, 0);
    if (!ssSetNumOutputPorts(S, 1)) return;
    ssSetOutputPortWidth(S, 0, 6);
    ssSetNumSampleTimes(S, 1);
    ssSetNumRWork(S, 0);
    ssSetNumIWork(S, 0);
    ssSetNumPWork(S, 0);
    ssSetNumModes(S, 0);
    ssSetNumNonsampledZCs(S, 0);
    ssSetOptions(S, 0);
static void mdlInitializeSampleTimes(SimStruct *S)
    ssSetSampleTime(S, 0, CONTINUOUS_SAMPLE_TIME);
    ssSetOffsetTime(S, 0, 0.0);
#define MDL_INITIALIZE_CONDITIONS   /* Change to #undef to remove function */
#if defined(MDL_INITIALIZE_CONDITIONS)
  static void mdlInitializeConditions(SimStruct *S)
        hMapFile = OpenFileMapping(FILE_MAP_ALL_ACCESS, // Read/write permission.
            FALSE,                             // Do not inherit the name
            "MySharemem");            // of the mapping object.
        if (hMapFile == NULL)
            printf("Could not open file-mapping object.");
        pshareblock=( double* )MapViewOfFile(hMapFile,
                    0,
                    0,
                    6* sizeof(double));
        if (pshareblock == NULL)
           printf("Could not map view of file.");
          OpenEvent(
              EVENT_ALL_ACCESS,  // access
              FALSE,    // inheritance option
              "WriteEvent"        // object name
            OpenEvent(
             " ReadEvent"        // object name
#endif /* MDL_INITIALIZE_CONDITIONS */
#define MDL_START  /* Change to #undef to remove function */
#if defined(MDL_START)
  static void mdlStart(SimStruct *S)
#endif /*  MDL_START */
static void mdlOutputs(SimStruct *S, int_T tid)
    real_T *u =  (real_T *)ssGetInputPortRealSignal(S,0);
    real_T  *y = (real_T *)ssGetOutputPortSignal(S,0);
    y[0] = u[0];
    y[1] = u[1];
    y[2] = u[2];
    y[3] = u[3];
    y[4] = u[4];
    y[5] = u[5];
#define MDL_UPDATE  /* Change to #undef to remove function */
#if defined(MDL_UPDATE)
static void mdlUpdate(SimStruct *S, int_T tid)
    dwWaitResult = WaitForSingleObject( hGlobalReadEvent,
           INFINITE);
          if (dwWaitResult=WAIT_OBJECT_0)
             real_T *u = (real_T *) ssGetInputPortRealSignal(S,0);
              pshareblock[0]=u[0];
              pshareblock[1]=u[1];
              pshareblock[2]=u[2];
              pshareblock[3]=u[3];
              pshareblock[4]=u[4];
              pshareblock[5]=u[5];
         if ((! ResetEvent(hGlobalReadEvent))||(! SetEvent(hGlobalWriteEvent)))
                     printf("Could not ResetReadEvent or SetWriteEvent.");
#endif /* MDL_UPDATE */
#define MDL_DERIVATIVES  /* Change to #undef to remove function */
#if defined(MDL_DERIVATIVES)
  static void mdlDerivatives(SimStruct *S)
#endif /* MDL_DERIVATIVES */
static void mdlTerminate(SimStruct *S)
  UnmapViewOfFile(pshareblock);
    CloseHandle(hMapFile);
#ifdef  MATLAB_MEX_FILE    /* Is this file being compiled as a MEX-file? */
#include "simulink.c"      /* MEX-file interface mechanism */
#else
#include "cg_sfun.h"       /* Code generation registration function */
#endif
在将c文件编译成mexw32文件时,出现一个错误:
>> mex myport.c
Microsoft (R) Incremental Linker Version 6.00.8168
Copyright (C) Microsoft Corp 1992-1998. All rights reserved.
C:\DOCUME~1\vlp\LOCALS~1\Temp\myport.obj
   Creating library _lib6486.x and object _lib6486.exp
myport.obj : error LNK2001: unresolved external symbol _hMutex
myport.mexw32 : fatal error LNK1120: 1 unresolved externals
  C:\PROGRAM FILES\MATLAB71\BIN\MEX.PL: Error: Link of 'myport.mexw32' failed.
??? Error using ==> mex
Unable to complete successfully
如果将函数static void mdlUpdate中的
           INFINITE);
去掉,则可以通过编译,请高手帮忙,是不是s函数不认识WaitForSingleObject还是什么原因
GMT+8, 2025-2-19 06:46 , Processed in 0.089663 second(s), 18 queries , Gzip On.
