查看: 3453|回复: 3
[结构分析] 新手求助:关于ANSYS非线性分析时出现的问题,急!!!
发表于 2009-6-18 00:35 | 显示全部楼层 |阅读模式
命令流如下:
!Analysis on a simple supported reinforced concrete beam
!分离式模型,1/4模型分析,力加载,位移收敛准则,收敛误差设为3%,关闭压碎
!Units: N, mm, MPa (N/mm2)
finish
/clear
/config,nres,2000  !maximum number of results sets (substeps) allowed on the result file, set to 2000
/prep7
!1. Define element types, material properties, real constants-----------------------------
!---set element types---
et,1,solid65  !concrete
keyopt,1,1,0  !Include extra displacement shapes
keyopt,1,7,1  !Include tensile stress relaxation after cracking to help convergence
et,2,link8  !steel/rebars
!---set material properties---
!(a)concrete
mp,ex,1,16588
mp,prxy,1,0.2
!constitutive relationship of concrete
fc=14.3
ft=1.43
tb,concr,1
tbdata,,0.5,0.95,ft,-1,,  !βt, βc, ft, no crush,
tbdata,,,,0.6  !Tc=0.6
tb,miso,1,,19
tbpt,,0.0002,fc*0.232
tbpt,,0.0004,fc*0.432
tbpt,,0.0006,fc*0.602
tbpt,,0.0008,fc*0.741
tbpt,,0.0010,fc*0.850
tbpt,,0.0012,fc*0.930
tbpt,,0.0014,fc*0.979
tbpt,,0.00164,fc*1.000
tbpt,,0.0018,fc*0.988
tbpt,,0.0020,fc*0.949
tbpt,,0.0022,fc*0.894
tbpt,,0.0024,fc*0.834
tbpt,,0.0026,fc*0.773
tbpt,,0.0028,fc*0.715
tbpt,,0.0030,fc*0.662
tbpt,,0.0032,fc*0.613
tbpt,,0.0034,fc*0.570
tbpt,,0.0036,fc*0.531
tbpt,,0.003772,fc*0.5
tbplot,miso,1
!----Steel----
mp,ex,2,2.0e5
mp,prxy,2,0.3
tb,biso,2
tbdata,,300,0
tbplot,biso,2
!-------Real constants--------
pi=acos(-1)
r,1,pi*22*22/4  !rebar at the tensile region corner
r,2,pi*22*22/4/2  !rebar on middle of the tensile region(on the symmetric plane)
r,3,pi*10*10/4  !rebar at the compressional region corner; stirrup
r,4,pi*10*10/4/2  !stirrup on the symmetric plane
r,5,,,,,, !concrete
rmore,,,,,,
!2. Create geometry model--------------------------------------
/view,1,1,1,1
/replot
blc4,,,200/2,300,3000/2
*do,i,1,14
wpoffs,,,100
vsbw,all
*enddo
wpcsys,-1
wpoffs,,,50
vsbw,all
wpcsys,-1
wprota,,-90
wpoffs,,,30
vsbw,all
wpoffs,,,240
vsbw,all
wpcsys,-1
wpoffs,30
wprota,,,90
vsbw,all
wpcsys,-1
!3. Mesh the steel-------------------------
!create components and assign the label of element types/real constants/material properties
elemsize=50  !set element size
lsel,s,loc,x,30
lsel,r,loc,y,30
lplot
cm,As-t,line !As(corner)
latt,2,1,2
lesize,all,elemsize
lsel,s,loc,x,100
lsel,r,loc,y,30
lplot
cm,As-tm,line !As(middle, on the symmetry plane)
latt,2,2,2
lesize,all,elemsize
lsel,s,loc,x,30
lsel,r,loc,y,270
lplot
cm,As-c,line !As'
latt,2,3,2
lesize,all,elemsize
lsel,s,tan1,z
lsel,r,loc,y,30,270
lsel,r,loc,x,30,95
lsel,u,loc,z,50
lplot
cm,Asv,line  !stirrups (general)
latt,2,3,2
lesize,all,elemsize
lsel,s,loc,z,0
lsel,r,loc,y,30,270
lsel,r,loc,x,30,95
lplot
cm,Asv1,line  !stirrup(on the symmetry plane)
latt,2,4,2
lesize,all,elemsize
lsel,all
cmsel,s,As-t
cmsel,a,As-tm
cmsel,a,As-c
cmsel,a,Asv
cmsel,a,Asv1
cm,allrebars,line  !all rebars
lmesh,all
lsel,all
/eshape,1
/number,1
/pnum,real,1
eplot
!4. Mesh concrete-----------------------------------
allsel,all
vatt,1,5,1
mshkey,1
esize,elemsize
vmesh,all
allsel,all
nummrg,all
!5. Apply loads and restraints----------------------
!simple support restraints
lsel,s,loc,y,0
lsel,r,loc,z,1400
lplot
dl,all,,ux,0
dl,all,,uy,0
allsel,all
/replot
asel,s,loc,z,0
da,all,symm
asel,s,loc,x,100
da,all,symm
p=115000  !concentrating load
qe=p/200/100  !equivalent distributing load
asel,s,loc,z,0,50
asel,r,loc,y,300
sfa,all,1,pres,qe
allsel,all
/replot
finish
!6. Set solution options and solve
/solu
antype,0
nsubst,250
outres,all,all
autots,on
neqit,150
cnvtol,u,,0.03
gplot
以上命令流是老师给的,其他人都可以正常计算没问题,但是我每次算到一半ANSYS就自动退出了!
错误日志里的描述是:
*** FATAL ***                           CP =      33.328   TIME= 22:47:23
The supplied nonlinear material properties produced an incorrect
material tangent matrix.  Please check your TB input carefully.  A
very small yield stress may cause this failure.
马上要交作业了!!!
请各位大侠指教!!!
 楼主| 发表于 2009-6-18 00:36 | 显示全部楼层
是与切线模量的设置有关吗?
但是为什么别人计算都没问题呢?
 楼主| 发表于 2009-6-18 13:54 | 显示全部楼层
我把屈服应力改成310以上的值就可以算了
这是为什么呢?
硬件问题吗?
请高手指教啊~~~!!!
发表于 2010-9-6 16:09 | 显示全部楼层
我也出现了这种问题,不知道是什么原因,阿有高手回答一下啊
GMT+8, 2025-1-11 19:55 , Processed in 0.077266 second(s), 18 queries , Gzip On.
