查看: 3723|回复: 4
[Nastran专区] 请高人帮我看看f06问题出在哪里
发表于 2006-3-16 21:10 | 显示全部楼层 |阅读模式
帮我看看f06文件,问题出在哪里。xdb文件就是生成不了 。多谢了
*** USER FATAL MESSAGE 3060 (PREFACE)
SUBROUTINE MODEL - OPTION NAST NOT IN APPROVED LIST.
SYSTEM DATE (MM/DD/YY): 03/16/06
SYSTEM MSCID: 1276473135 (DECIMAL) 4C156F2F (HEXADECIMAL) SYSTEM MODEL NUMBER: 3 SYSTEM OS CODE: -1
SYSTEM MSCID: -1586974041 (DECIMAL) A168B2A7 (HEXADECIMAL) SYSTEM MODEL NUMBER: 4 SYSTEM OS CODE: -1
SYSTEM MSCID: 0 (DECIMAL) (HEXADECIMAL) SYSTEM MODEL NUMBER: SYSTEM OS CODE:
SYSTEM MSCID: (DECIMAL) (HEXADECIMAL) SYSTEM MODEL NUMBER: SYSTEM OS CODE:
REFER TO THE MSC.NASTRAN LOG FILE FOR DETAILED INFORMATION
1 * * * END OF JOB * * *
*** USER WARNING MESSAGE 1152 (XCLNUP)
SOME DBSETS IN THIS DATA BASE WERE NOT INITIALIZED COMPLETELY.
USER INFORMATION: THE DATA BASE CREATED IN THIS RUN IS TOO IMMATURE TO BE RESTARTED.
USER ACTION: DELETE THIS DATA BASE BEFORE STARTING YOUR NEXT RUN.
发表于 2006-3-17 08:48 | 显示全部楼层
这个可能是版本或者安装问题,把你的bdf文件贴出来
 楼主| 发表于 2006-3-17 15:22 | 显示全部楼层
这是我的tml文件。
======== MSC (c) 1994 TskMgr log file ========
job name: brack
local host: hello
submit host: hello
quemgr host: hello
binpath: d:/msc/MSC.Software/MSC.Patran/2004/p3manager_files
orgpath: d:/msc/MSC.Software/MSC.Patran/2004/p3manager_files
user: SYSTEM
version: 2004.0.3
==== < PRE > ====
No external pre program defined.
INFORMATION: No disk space requirement specified
==== < MSC.Nastran > started ====
cmd-line = <d:\msc\bin\nast2004.exe brack old=no not=no scr=yes sdi=C:\DOCUME~1\weekee\LOCALS~1\Temp\weekee\brack284856 app=no out= rcf=no_op.rc>
cmd exit code = 1
==== < MSC.Nastran > finished ===
==== < POS > ====
No external pos program defined.
EXIT msg: ERROR... MSC.Nastran unable to open f04 and f06 files
 楼主| 发表于 2006-3-17 15:24 | 显示全部楼层
NASTRANinputfilecreatedbytheMSCMSC.Nastraninputfile
translator ( MSC.Patran 12.0.044 ) on March 16, 2006 at 19:59:11.
DirectTextInputforFileManagementSection
Linear Static Analysis, Database
SOL 101
DirectTextInputforExecutiveControl
这是我bdf文件数据段前面的内容
CEND
SEALL=ALL
SUPER=ALL
TITLE=MSC.Nastranjobcreatedon15&#8722;Mar&#8722;06at09:24:39
ECHO=NONE
Direct Text Input for Global Case Control Data
SUBCASE 1
Subcasename:Default
SUBTITLE=Default
DISPLACEMENT(SORT1,REAL)=ALL
SPCFORCES(SORT1,REAL)=ALL
STRESS(SORT1,REAL,VONMISES,BILIN)=ALL
BEGINBULK
PARAMPOST0
PARAMAUTOSPCYES
PARAMPRTMAXIMYES
Direct Text Input for Bulk Data
ElementsandElementPropertiesforregion:struct
PSOLID110
Pset: "struct" will be imported as: "psolid.1"
 楼主| 发表于 2006-3-17 15:28 | 显示全部楼层
我的bdf文件有665页的内容,太大了无法帖
是不是我的nastran的设置有没有关系。
我是新手,问的问题弱智些,请各位大侠不要见笑
GMT+8, 2025-1-9 00:06 , Processed in 0.065346 second(s), 17 queries , Gzip On.
