查看: 1136|回复: 3
[图像处理] 解包
发表于 2009-6-1 13:59 | 显示全部楼层 |阅读模式
对相位进行解包的程序,那错了
clear
n=256;
h=fspecial('gaussian',9,1);
I1=imread('image1.bmp');
% figure(1);
% imshow(I1);
M1=rgb2gray(I1); %彩色图变灰度图像
%imshow(M1);
N1=imcrop(M1,[175 105 390 265]);
% figure(2);
% imshow(N1);
A1=filter2(h,N1(:,:,1));
% figure(3)
%  imshow(A1)
I2=imread('image2.bmp');
figure(4)
imshow(I2);
M2=rgb2gray(I2); %彩色图变灰度图像
%imshow(M2);
N2=imcrop(M2,[175 105 390 265]);
% figure(5);
% imshow(N2);
A2=filter2(h,N2(:,:,1));
% figure(6)
%  imshow(A2)
I3=imread('image3.bmp');
% figure(7)
% imshow(I3);
M3=rgb2gray(I3); %彩色图变灰度图像
%imshow(M3);
N3=imcrop(M3,[175 105 390 265]);
% figure(8);
% imshow(N3);
A3=filter2(h,N3(:,:,1));
%  figure(9)
% imshow(A3)
I4=imread('image4.bmp');
% figure(10)
% imshow(I4);
M4=rgb2gray(I4); %彩色图变灰度图像
%imshow(M4);
N4=imcrop(M4,[175 105 390 265]);
% figure(11);
% imshow(N4);
A4=filter2(h,N4(:,:,1));
%  figure(12)
% imshow(A4)
for i=1:256
    for j=1:256
   A4_2(i,j)=A4(i,j)-A2(i,j);
   A1_3(i,j)=A1(i,j)-A3(i,j);
   m=double(A4_2(i,j)/A1_3(i,j));
phase(i,j)=atan(m);
figure(13)
mesh(phase);
width=256;
height=256;
%解包
for i=1:width
    for j=1:height
        if (A1(i,j)==A3(i,j))
            if(A2(i,j)>A4(i,j))
                phase(i,j)=pi/2;
            elseif(A2(i,j)>A3(i,j))
            if A2(i,j)>=A4(i,j)
                phase(i,j)=atan(m);
            else
                phase(i,j)=pi-atan(m);
        else
            if( A2(i,j)>=A4(i,j))
                phase(i,j)=2*pi-atan(m);
            else
                phase(i,j)=2*pi+atan(m);
phase=unwrap(phase);
%消除2pi突变
midx=fix(width/2);
for j=1:width
     for m=height-1:-1:1
         a=phase(j,m)-phase(j,m+1);
         if a>pi
            for n=m:-1:1
                phase(j,n)=phase(j,n)-2*pi;
         if a<-pi
            for n=m:-1:1
             phase(j,n)=phase(j,n)+2*pi;
         if a==pi
            if phase(j,m)-phase(j,m-1)>0
               for n=m:-1:1
         if a==-pi
            if phase(j,m)-phase(j,m-1)<0
               for n=m:-1:1
for k=1:height
     for m=midx:-1:1
         c=phase(m,k)-phase(m+1,k);
         if c>pi
            for n=m:-1:1
                phase(n,k)=phase(n,k)-2*pi;
         if c<-pi
            for n=m:-1:1
                phase(n,k)=phase(n,k)+2*pi;
         if c==pi
            if phase(m,k)-phase(m,k-1)>0
               for n=m:-1:1
                phase(n,k)=phase(n,k)-2*pi;;
         if c==-pi
            if phase(m,k)-phase(m,k-1)<0
               for n=m:-1:1
     for m=midx:width
         b=phase(m,k)-phase(m-1,k);
         if b>pi
            for n=m:width
         if b<-pi
            for n=m:width
               if c==pi
            if phase(m,k)-phase(m+1,k)>0
               for n=m:-1:1
          if c==-pi %
if phase(m,k)-phase(m+1,k)<0
                for n=m:-1:1
phase=phase/(2*pi);
figure,surf(phase)
m=1;n=1;
for i=1:40:256
    for j=1:40:256
        x(m)=i;y(m)=j;
        w(m)=phase(i,j);
        m=m+1;n=n+1;
发表于 2009-6-1 16:44 | 显示全部楼层
求助完整格式:出错代码和出错提示
 楼主| 发表于 2009-6-12 09:08 | 显示全部楼层
相位解包
编了一个相位解包程序,请求修改!!!
clear
n=256;
% figure(1);
% imshow(I1);
%imshow(M1);
N1=imcrop(M1,[175 105 390 265]);%剪切
% figure(2);
% imshow(N1);
A1=filter2(h,N1(:,:,1))%高斯滤波;
% figure(3)
%  imshow(A1)
figure(4)
imshow(I2);
%imshow(M2);
% figure(5);
% imshow(N2);
% figure(6)
%  imshow(A2)
% figure(7)
% imshow(I3);
%imshow(M3);
% figure(8);
% imshow(N3);
%  figure(9)
% imshow(A3)
% figure(10)
% imshow(I4);
%imshow(M4);
% figure(11);
% imshow(N4);
%  figure(12)
% imshow(A4)
for i=1:256     %四步相移算法
    for j=1:256
phase(i,j)=atan(m);
figure(5)
mesh(phase)
ph=zeros(n,n);   %解包
for i=1:n
   for j=1:n
     if j<n/2&phase(j,i)-phase(j+1,i)>pi/2
      for k=(j+1):(n-j)
         ph(k,i)=pi+ph(k,i);
     if j<n/2&phase(j,i)-phase(j+1,i)<-pi/2
      for k=(j+1):(n-j)
         ph(k,i)=-pi+phase(k,i);
for j=1:n
   for i=1:n
     if i<n/2&phase(j,i)-phase(j,i+1)>pi/2
       for k=(i+1):(n-i)
         ph(j,k)=pi+phase(j,k);
     if i<n/2&phase(j,i)-phase(j,i+1)<-pi/2
      for k=(i+1):(n-i)
         ph(j,k)=-pi+phase(j,k);
for i=1:n
for j=1:n
   if i>1&phase(i,j)-phase(i-1,j)>=pi/2
      ph(i,j)=phase(i,j)-pi;
   if i>1&phase(i,j)-phase(i-1,j)<=-pi/2
      ph(i,j)=phase(i,j)+pi;
   if j>1&phase(i,j)-phase(i,j-1)>=pi/2
   if j>1&phase(i,j)-phase(i,j-1)<=-pi/2
figure
mesh(ph)
 楼主| 发表于 2009-6-12 09:38 | 显示全部楼层
相位解包
帮忙修改一下这个程序!解包时出现错误
Untitled8.m
2.18 KB, 下载次数: 1
GMT+8, 2025-1-11 16:57 , Processed in 0.062653 second(s), 22 queries , Gzip On.
