查看: 1425|回复: 2
[HHT] 紧急求助,调用emd时突然出错,以前没有过这种情况。请高手解救。
发表于 2009-5-19 12:49 | 显示全部楼层 |阅读模式
load x;
x=x';
y=emd(x);
mode 3, iteration 600
??? Error: File: num2str.m Line: 150 Column: 13
"u" previously appeared to be used as a function or command, conflicting with its use here as the name of a variable.
A possible cause of this error is that you forgot to initialize the
variable, or you have initialized it implicitly using load or eval.
Error in ==> emd at 204
        disp(['stop parameter mean value : ',num2str(s)])
 楼主| 发表于 2009-5-19 13:05 | 显示全部楼层
回复 楼主 大鹏之举 的帖子
问题已经解决!:lol
求人不如求己!
发表于 2012-3-9 09:38 | 显示全部楼层
回复 1 # 大鹏之举 的帖子
请问楼主怎么解决了呢,我也遇到同样的问题
GMT+8, 2025-1-10 11:34 , Processed in 0.064920 second(s), 19 queries , Gzip On.
