查看: 2626|回复: 3
[综合讨论] 求助MATLAB中有效值位数的问题
发表于 2009-5-18 12:08 | 显示全部楼层 |阅读模式
我的一个矩阵中大的有1.0 e+007
小的有0.00001
相差很大
写成矩阵后   MATLAB把1.0e+007提出来
结果0.00001这样的项就显示为0了
结果有了误差
请教各位大哥MATLAB中怎么改有效值显示的位数啊
小弟新手网上搜了很长时间没搜索出来  麻烦各位了    谢谢了
我本来输入的矩阵
y=[0 -1 0 0 0 0 0 0 0 0 0 0 0 0;2*1.823e+006 2*6.563e+006/(0.54219*40) -2*6.563e+006/0.54219 0 0 0 0 0 -2*1.823e+006 0 -2*1.823e+006*1.074 0 -2*1.823e+006*0.0762 0;0 0 0 -1 0 0 0 0 0 0 0 0 0 0;2*0.716*6.563e+006*0.05/(0.4572*0.60252) 0 2*3.646e+006*0.620^2 2*0.716^2*6.563e+006/(0.60252*40) 0 0 0 0 0 0 -2*3.646e+006*0.620^2 0 0 0;0 0 0 0 0 -1 0 0 0 0 0 0 0 0;0 0 0 0 2*1.823e+006 2*6.563e+006/(0.54219*40) -2*6.563e+006/0.54219 0 -2*1.823e+006 0 -2*1.823e+006*1.074 0 -2*1.823e+006*0.0762 0;0 0 0 0 0 0 0 -1 0 0 0 0 0 0;0 0 0 0 2*0.716*6.563e+006*0.05/(0.4572*0.60252) 0 2*3.646e+006*0.620^2 2*0.716^2*6.563e+006/(0.60252*40) 0 0 -2*3.646e+006*0.620^2 0 0 0;0 0 0 0 0 0 0 0 0 -1 0 0 0 0;-2*1.823e+006 0 0 0 -2*1.823e+006 0 0 0 4*1.823e+006+2*0.1823e+006 2*29.2e+003 4*1.823e+006*1.074 0 4*1.823e+006*0.0762-2*0.1823e+006*0.6584 -2*29.2e+003*0.6584;0 0 0 0 0 0 0 0 0 0 0 -1 0 0;-2*1.823e+006*1.074 0 -2*3.646e+006*0.620^2 0 2*1.823e+006*1.074 0 -2*3.646e+006*0.620^2 0 0 0 4*3.646e+006*0.620^2+2.710e+006 0 0 0;0 0 0 0 0 0 0 0 0 0 0 0 0 -1;-2*1.823e+006*0.0762 0 0 0 -2*1.823e+006*0.0762 0 0 0 4*1.823e+006*0.0762+2*0.1823e+006*0.6584 2*29.2e+003*0.6584 4*1.823e+006*0.0762*1.074 0 4*1.823e+006*0.0762^2-2*0.1823e+006*0.6584^2+2*0.3333e+006*0.680^2+4*3.646e+006*0.620^2 2*20.0e+003*0.680^2-2*29.2e+003*0.6584^2]
MATLAB输出的矩阵
y =
  1.0e+007 *
  Columns 1 through 7
         0   -0.0000         0         0         0         0         0
    0.3646    0.0605   -2.4209         0         0         0         0
         0         0         0   -0.0000         0         0         0
    0.1706         0    0.2803    0.0279         0         0         0
         0         0         0         0         0   -0.0000         0
         0         0         0         0    0.3646    0.0605   -2.4209
         0         0         0         0         0         0         0
         0         0         0         0    0.1706         0    0.2803
         0         0         0         0         0         0         0
   -0.3646         0         0         0   -0.3646         0         0
         0         0         0         0         0         0         0
   -0.3916         0   -0.2803         0    0.3916         0   -0.2803
         0         0         0         0         0         0         0
   -0.0278         0         0         0   -0.0278         0         0
  Columns 8 through 14
         0         0         0         0         0         0         0
         0   -0.3646         0   -0.3916         0   -0.0278         0
         0         0         0         0         0         0         0
         0         0         0   -0.2803         0         0         0
         0         0         0         0         0         0         0
   -0.0000         0         0         0         0         0         0
    0.0279         0         0   -0.2803         0         0         0
         0         0   -0.0000         0         0         0         0
         0    0.7657    0.0058    0.7832         0    0.0316   -0.0038
         0         0         0         0   -0.0000         0         0
         0         0         0    0.8316         0         0         0
         0         0         0         0         0         0   -0.0000
         0    0.0796    0.0038    0.0597         0    0.5799   -0.0007
 楼主| 发表于 2009-5-18 12:09 | 显示全部楼层
像矩阵中第一排第二个本来为1
输出为0.0000
小弟想问一下  这样会不会影响运算结果啊
发表于 2009-5-18 12:31 | 显示全部楼层
那仅是显示问题, 不会影响运算结果
试试输入y(1,2)
 楼主| 发表于 2009-5-18 12:58 | 显示全部楼层
GMT+8, 2025-1-11 19:55 , Processed in 0.079877 second(s), 18 queries , Gzip On.
