查看: 1240|回复: 0
[混合编程] c#调用matlab的问题
发表于 2009-5-9 15:20 | 显示全部楼层 |阅读模式
matlab的程序是这样的:
function [J]=test0101(path1,path2,path3)
data1=xlsread(path1);
data2=xlsread(path2);
f1=plot(data1,data2);
figure;
imshow(f1);
imwrite(f1,path3,'bmp')
主要是通过打开两个xls文件的数据由matlab产生一个图像
在c#中调用这个例子的时候部分是这么写的:
private void btn_ok_Click(object sender, EventArgs e)
           int t, s;
            object a, b;
           // object j=new object();
            MathWorks.MATLAB.NET.Arrays.MWArray j;
           j = 0;
           string xxx;
            //t = Convert.ToInt16(this.textBox1.Text);
            //s = Convert.ToInt16(this.textBox2.Text);
            int index = xx.IndexOf(".");
            string yy = xx.Substring(index, 4);
            test1010.test1010class lj = new test1010.test1010class();
            MathWorks.MATLAB.NET.Arrays.MWArray m = t;
            MathWorks.MATLAB.NET.Arrays.MWArray alpha = s;
        //    a = t; b = s;
            //object filename_1 = null;
            //string filename_2 = "c:\\test_01.bmp";
            string filename_3 = "c:\\test_2.bmp"; ;
        xxx=  lj.test0101(1,filename_3).ToString();
        //    j = 0;
         //   xyz11.xyz11class lj = new xyz11.xyz11class();
       //    Object  J=lj.xyz_test01(1, 50, 1,j, xx, filename_2, filename_3);
            this.pictureBox1.Image = System.Drawing.Image.FromFile(filename_3.ToString());
            //this.pictureBox3.Image = System.Drawing.Image.FromFile(filename_3.ToString());
          //  this.textBox3.Text = j.ToString();
想在pictureBox1中显示这个图片,其中部分参数是没有用的
error:No overload for method"test0101"takes"2"arguments
望高手相助!
不甚感激!
GMT+8, 2025-1-26 06:45 , Processed in 0.087204 second(s), 17 queries , Gzip On.
