查看: 2570|回复: 9
[前后处理] 请教ansys内力输出问题
发表于 2009-5-7 20:27 | 显示全部楼层 |阅读模式
做一个两层平面框架动力分析。
模态分析和位移响应已经算完,我想得到杆件的振动内力响应,不知道如何实现。
请高手指点,谢谢。
 楼主| 发表于 2009-5-8 15:23 | 显示全部楼层
没人知道振动内里输出的方法吗?
这里把命令流放上来,请知道的朋友指点。
/CLEAR
/UNITS,SI
/FILNAME,LNXF
/TITLE,GJ-1
! 建立有限元模型
/prep7
ET,1,BEAM188
MP, EX, 1, 2.06E8
MP, NUXY, 1, 0.3
MP, DENS, 1, 7.85
Area1=0.04204
Iyy1=0.001363
Area2=0.04204
Iyy2=0.001363
/SECLIB,READ
SECTYPE,   1, BEAM, HREC, Column, 0
SECOFFSET, CENT
SECDATA,0.600,0.450,0.022,0.022,0.020,0.020,0,0,0,0
SECTYPE,   2, BEAM, I, Beam1, 0
SECOFFSET, CENT
SECDATA,0.350,0.350,1.300,0.022,0.022,0.014,0,0,0,0
SECTYPE,   3, BEAM, I, Beam2, 0
SECOFFSET, CENT
SECDATA,0.200,0.200,.450,0.008,0.008,.006,0,0,0,0
K,1,0,,,
K,2,0,9,,
K,3,0,14,,
K,4,18,,,
K,5,18,9,,
K,6,18,14,,
K,7,3,14.09,,
K,8,9,14.27,,
K,9,15,14.09,,
LSTR,1,2 !LSTR,P1,P2(两点间生成直线)
LSTR,2,3
LSTR,4,5
LSTR,5,6
LSTR,2,5
LSTR,3,7
LSTR,7,8
LSTR,8,9
LSTR,9,6
LSEL,s,,,1,4,1
LATT,1, ,1, , , ,1
LSEL,s,,,5,5,1
LATT,1, ,1, , , ,2
LSEL,s,,,6,9,1
LATT,1, ,1, , , ,3
LSEL,s,,,5,5,1
ALLSEL,ALL
LMESH,1,9,1
FINISH
/SOL
DK,1,all
DK,4,all
!DK,all, ,0, ,0,UZ, , , , , ,
FK,7,FY,-10
FK,8,FY,-10
FK,9,FY,-10
F,19,FY,-130,,28,1
F,2,FY,-65,,11,1
F,30,FY,-6.6,,41,1
F,6,FY,-4,,15,1
/STATUS,SOLU
SOLVE
FINISH
/REPLOT
EPLOT
/SOLU
ANTYPE,2          !模态分析
EXPASS,0   !扩展分析
MODOPT,LANB,10    !Block Lanczos 方法
EQSLV,SPAR     !稀疏矩阵法,指定求解器
MXPAND,100,, ,yes,    !扩展模态,
LUMPM,1    !质量矩阵,0/1(单元质量/集中质量)
PSTRES,0   !预应力,0/1(有/无)
MODOPT,LANB,100,0.2,600, ,OFF !模态分析选项,最低0.2Hz
/STATUS,SOLU
SOLVE
FINISH
/POST1     !后处理
INRES,ALL      !指定存入数据
FILE,      !存入文件名,扩展名
SET,,, ,,, ,5     !读出步数,模态阶数
PLDISP,0   !显示变形的结构,0/1/2(0 仅显示变形后)
!/EFACET,1   !Specifies the number of facets 显示
!PLNSOL, U,SUM, 0,1.0  !显示等值线或云图
!PLDI, ,    !显示轮廓,0/1/2(//)
!ANMODE,20,,20,0     !动画显示
!PLDISP,0
!SET, , ,1, ,15, ,
!/EFACET,1
/SOL
ANTYPE,HARMIC          !谐响应分析
HROPT,FULL
HROUT,ON
LUMPM,1
OUTPR,BASIC,1
harfrq,0.1,100  !FREQUENCY RANGE FROM 1 TO 100 HZ
NSUBST,200  !指定荷载步
KBC,0   !指定荷载形态0/1(递增/阶跃)
F,31,Fy,1    !
ALLSel     !
SOLVE     !
FINISH     !
/POST26
NSOL,2,31,U,X,UX  !时间历程输出内容,变量号2,节点号21。
/GRID,1    !TURN GRID ON
/AXLAB,Y,DISP   !Y AXIS LABEL AS DISP
/GTHK,CURVE,2   !CURVE LINES THICKNESS RATIO OF 2
PLVAR,2
发表于 2009-5-8 16:54 | 显示全部楼层
回复 沙发 wanyeqing2003 的帖子
nsel,s,..
prnsol,..
 楼主| 发表于 2009-5-8 21:03 | 显示全部楼层
非常感谢。
不过好像只能查看静力结果,动力响应好像看不到。
发表于 2009-5-10 11:01 | 显示全部楼层
动力响应只能读取某一子步的结果,然后在求反力。
 楼主| 发表于 2009-5-20 17:16 | 显示全部楼层
我觉得ansys没有sap2000好用,特别是结构分析输出显示方面。
也可能是ansys功能太强大的缘故,掌握起来也有难度。
发表于 2009-5-21 08:33 | 显示全部楼层
没用过sap2000
 楼主| 发表于 2009-6-14 20:20 | 显示全部楼层
后来用了sap2000,比较简单的完成了这个分析。
发表于 2009-6-15 08:18 | 显示全部楼层
对一般的结构件分析来说,SAP2000,STAAD等专业软件更好一点。
发表于 2009-8-14 20:14 | 显示全部楼层
没有用过sap2000,不过感觉ANSYS太过复杂了,很想尝试学习一下sap2000,不知道大家有没有好的教程推荐?
GMT+8, 2025-1-27 22:44 , Processed in 0.096562 second(s), 17 queries , Gzip On.
