查看: 1283|回复: 3
[分形与混沌] 求助分析一下
发表于 2009-5-6 20:02 | 显示全部楼层 |阅读模式
function [s,delt_s,s_cor]=C_CMethod(data)
%this function calculate time delay and embedding demension with C-C
%Method,which proved by H.S.Kim
%skyhawk&flyinghawk
% %****************调试程序段****************************
% clear all;
data=load('d:/matlab7/toolbox/work/2.txt');
N=length(data);
max_d=100;%the maximum value of the time delay
sigma=std(data);%calcute standard deviation s_d
for t=1:max_d
    t
    s_t=0;
    delt_s_s=0;
    for m=2:5
        s_t1=0;
        for j=1:5
            r=sigma*j/2;
            data_d=disjoint(data,N,t);%将时间序列分解成t个不相交的时间序列
            [ll,N_d]=size(data_d);
            s_t3=0;
            for i=1:t
                i
                Y=data_d(i,:);
                C_1(i)=correlation_integral(Y,N_d,r);%计算C(1,N_d,r,t)
                X=reconstitution(Y,N_d,m,t);%相空间重构
                N_r=N_d-(m-1)*t;
                C_I(i)=correlation_integral(X,N_r,r);%计算C(m,N_r,r,t)
                s_t3=s_t3+(C_I(i)-C_1(i)^m);%对t个不相关的时间序列求和
            s_t2(j)=s_t3/t;
            s_t1=s_t1+s_t2(j);%对rj求和
        delt_s_m(m)=max(s_t2)-min(s_t2);%求delt S(m,t)
        delt_s_s=delt_s_s+delt_s_m(m);%delt S(m,t)对m求和
        s_t0(m)=s_t1;
        s_t=s_t+s_t0(m);%S对m求和
    s(t)=s_t/16;
    delt_s(t)=delt_s_s/4;
    s_cor(t)=delt_s(t)+abs(s(t));
fid=fopen('2.txt','w');
fprintf(fid,'%f %f %f %f/n',t,s(t),delt_s(t),s_cor(t));
fclose(fid);
t=1:max_d;
plot(t,s,t,delt_s,'.',t,s_cor,'*')
为什么会出现这样的错误?     帮忙看看
??? Undefined command/function 'disjoint'.
Error in ==> C_CMethod at 24
发表于 2009-5-6 21:14 | 显示全部楼层
程序不懂, 报错请参考
3F 常见的程序出错问题整理 (eight)
http://forum.vibunion.com/forum/thread-46001-1-1.html
 楼主| 发表于 2009-5-7 21:00 | 显示全部楼层
还不是很明白 谁能帮我改改  真的很急 帮帮忙吧
 楼主| 发表于 2009-5-11 22:02 | 显示全部楼层
自己在顶一下  大家看看这个程序该怎么改? 真的期盼大家的帮忙  谢谢了
GMT+8, 2025-1-8 02:13 , Processed in 0.086182 second(s), 17 queries , Gzip On.
