查看: 1806|回复: 1
[基本模块类] help me!!
发表于 2009-5-4 16:33 | 显示全部楼层 |阅读模式
我matlab版本为7.1
在Matlab命令窗口下敲入
bdclose all; set_param(0, 'CharacterEncoding', 'ISO-8859-1'),没效果。
用记事本没发现有中文字符。
报错为:
Warning: Loading model 'NCO' generated with a newer version (6.4) of Simulink.
> In general\private\openmdl at 13
  In open at 141
  In uiopen at 181
请大家帮帮忙吧!先谢了。(带有附件,大家可打开看看)
cppll.mdl
37.01 KB, 下载次数: 3
A charge-pump PLL with digital Phase-Frequency Detector in Simulink
 楼主| 发表于 2009-5-4 16:37 | 显示全部楼层
回复 楼主 wsb2010 的帖子
对不起,附件传错了。不过这个cppll.mdl的也打不开!
报错为:Warning: Loading model 'cppll' generated with a newer version (6.6) of Simulink.
  In open at 141
  In uiopen at 181
Warning: cppll.mdl, line 58: block_diagram does not have a parameter named 'AccelVerboseBuild'.
  In open at 141
  In uiopen at 181
Warning: cppll.mdl, line 452: This model contains objects of class 'hdlcoderui.hdlcc' that can not be instantiated. If you save this model, the information associated with these objects will be lost.
  In open at 141
  In uiopen at 181
GMT+8, 2025-2-20 11:55 , Processed in 0.082088 second(s), 21 queries , Gzip On.
