查看: 1832|回复: 3
[结构分析] beam4单元怎么加温度荷载,高手进来
发表于 2009-5-3 16:59 | 显示全部楼层 |阅读模式
/filename,wangqiaofenxi
/title,analysis of wangqiao
/prep7
!!!!!!!!!!!!!!!!!!!!!!材料属性和尺寸
et,1,beam4
r,1,1382e-3,2093500e-12,2093500e-12,114e-3,114e-3,,
rmore,,4187000e-12,,,,,
mp,dens,1,7.85e3
mp,ex,1,2.06e11
mp,nuxy,1,0.3
mp,alpx,1,1.2e-5   !定义温度膨胀系数
mp,reft,20           !初始温度
tb,bkin,1,1,2,1      !非线性材料模型- 与温度相关的双线性各向同性模型
tbdata,,345e6,0.0    !屈服应力和切线模量
模型(省略)!!!!!!!!!!!
!!!!!!!!!!!!!!!!!!!!!!!!!静力分析
/sol
antype,static      !分析类型
acel,0,0,9.8       !考虑重力
!施加温度荷载
pstres,on          !打开预应力
esel,s,,,1,306,1   !选择单元
bfe,all,temp,1,0   !温差-最后这个数
allsel all         !选择全部单元!!!重要!
solve
finish
!!!!!!!!!!!!!!!!!!!!!!!!!模态分析
/sol
AnType,Modal
pstres,on  !打开预应力
Modopt,LANB,10
MXPAND,10
SOLVE
FINISH
结果提示: *** WARNING ***                         CP =      43.172   TIME= 19:25:37
The program chosen initial timestep/load-factor is arbitrary.  It is
necessary for the user to supply a suitable initial
timestep/load-factor through the NSUB or DELTIM command for
convergence and overall efficiency.
[ 本帖最后由 luyunjun023 于 2009-5-3 19:33 编辑 ]
 楼主| 发表于 2009-5-3 17:16 | 显示全部楼层
高手高手能你快来
 楼主| 发表于 2009-5-3 19:09 | 显示全部楼层
高手,你在哪里
急!!!
换成beam4单元也是这样的结果
发表于 2009-5-4 12:33 | 显示全部楼层
initial timestep/load-factor through the NSUB or DELTIM command
设置迭代子步数或者时间间隔就可以了。
GMT+8, 2025-1-12 09:40 , Processed in 0.061485 second(s), 18 queries , Gzip On.
