查看: 1655|回复: 1
[分形与混沌] C_CMethod函数调用的问题
发表于 2009-4-22 11:29 | 显示全部楼层 |阅读模式
我在调用C_CMethod函数求延时,总是会出现如下错误,特向各位请教,谢谢!
以下是调用程序:
>> x=rand(1,100);
>> C_CMethod(x)
出错信息如下:
??? Output argument "X" (and maybe others) not assigned during call to "E:\MATLAB71\toolbox\chaos toolbox ver.2.0\main\reconstitution.m (reconstitution)".
Error in ==> reconstitution at 9
M=N-(m-1)*tau;%相空间中点的个数
Error in ==> reconstitution at 30
Error in ==> C_CMethod at 30
                X=reconstitution(Y,N_d,m,t);%相空间重构
C_CMethod函数即为工具箱Chaos Toolbox2.0 里的子函数
程序如下:
function [s,delt_s,s_cor]=C_CMethod(data)
%this function calculate time delay and embedding demension with C-C
%Method,which proved by H.S.Kim
%skyhawk&flyinghawk
% %****************调试程序段****************************
% clear all;
% data=load('f:/sunpot/year sunpot number.txt');
N=length(data);
max_d=20;%the maximum value of the time delay
sigma=std(data);%calcute standard deviation s_d
for t=1:max_d
    t
    s_t=0;
    delt_s_s=0;
    for m=2:5
        s_t1=0;
        for j=1:4
            r=sigma*j/2;
            data_d=disjoint(data,N,t);%将时间序列分解成t个不相交的时间序列
            [ll,N_d]=size(data_d);
            s_t3=0;
            for i=1:t
                i
                Y=data_d(i,:);
                C_1(i)=correlation_integral(Y,N_d,r);%计算C(1,N_d,r,t)
                N_r=N_d-(m-1)*t;
                C_I(i)=correlation_integral(X,N_r,r);%计算C(m,N_r,r,t)
                s_t3=s_t3+(C_I(i)-C_1(i)^m);%对t个不相关的时间序列求和
            s_t2(j)=s_t3/t;
            s_t1=s_t1+s_t2(j);%对rj求和
        delt_s_m(m)=max(s_t2)-min(s_t2);%求delt S(m,t)
        delt_s_s=delt_s_s+delt_s_m(m);%delt S(m,t)对m求和
        s_t0(m)=s_t1;
        s_t=s_t+s_t0(m);%S对m求和
    s(t)=s_t/16;
    delt_s(t)=delt_s_s/4;
    s_cor(t)=delt_s(t)+abs(s(t));
fid=fopen('result.txt','w');
fprintf(fid,'%f %f %f %f/n',t,s(t),delt_s(t),s_cor(t));
fclose(fid);
t=1:max_d;
plot(t,s,t,delt_s,'.',t,s_cor,'*')
发表于 2009-4-24 10:14 | 显示全部楼层
我觉得你应该把最大延迟时间改一下,你输入的时间序列是1*100的矩阵但是你的最大延迟max_d=20,在计算的时候肯定会超出范围,你试一下把max_d改成大一点的数看一下结果。
GMT+8, 2025-1-8 02:06 , Processed in 0.057179 second(s), 17 queries , Gzip On.
