查看: 1206|回复: 2
[其他相关] 石英悬臂梁的静态仿真的问题
发表于 2009-4-15 23:28 | 显示全部楼层 |阅读模式
我做石英悬臂梁的静态仿真,如图1所示,梁的右端面固定约束,左端面施加Z方向的力
通过仿真得到的电势云图如图2所示,在梁的+-z面上存在的电势差,按照石英的压电方程,其在Z面上是不可能产生电荷的,为什么在+-z表面上有电势呢?
按照压电方程,由于剪应力XZ的作用,该梁应该在+-Y方向有电势差,为什么会得到这样的仿真结果呢?
请高手明示,是我的理解错了,还是我的仿真错了?
附仿真命令流在楼下
 楼主| 发表于 2009-4-15 23:29 | 显示全部楼层
命令流
命令流
/PREP7
/TITLE, Quartz electric Field analysis
/COM,   Element1
ET,1,SOLID98
KEYOPT,1,1,3
KEYOPT,1,3,0
KEYOPT,1,5,0
/COM,  -- MATERIAL MATRICES : ANSYS INPUT
/COM,   - COMPLIANCE COEFFICIENTS, M2/N
S11=12.77E-12
S12=-1.79E-12
S13=-1.22E-12
S14=  -4.5E-12            !有的资料为4.5E-12
S33=  9.6E-12
S44=20.04E-12
TB,ANEL,1,,,1                     ! ANISOTROPIC ELASTIC COMPLIANCE MATRIX
TBDATA,1,  s11,  s12,  s13,    0,  s14,     0
TBDATA,7,        s11,  s13,    0, -s14,     0
TBDATA,12,             s33,    0,    0,     0
TBDATA,16,           2*(s11-s12),    0, 2*s14
TBDATA,19,                         s44,     0
TBDATA,21,                                s44
/COM,  - PIEZOELECTRIC STRAIN COEFFICIENTS, C/N
d11=2.31E-12
d14=0.73E-12             !有的资料为d11=-2.3E-12, d14=-0.67E-12
TB,PIEZ,1,,,1                     ! PIEZOELECTRIC STRAIN MATRIX
TBDATA,1,  d11,      0,   0
TBDATA,4, -d11,      0,   0
TBDATA,7,    0,      0,   0
TBDATA,10,   0, -2*d11,   0
TBDATA,13, d14,      0,   0
TBDATA,16,   0,    d14,   0
EMUNIT,MKS !Free-space permittivity is set to 8.85E-12 F/m.
!/COM,  - RELATIVE PERMITTIVITY AT CONSTANT STRESS
!EP11=4.52
!EP33=4.68
!TB,DPER,1,,,1,       ! Permittivity matrix at constant stress
!TBDATA,1, EP11, EP11, EP33
/COM,  - RELATIVE PERMITTIVITY AT constant strain
EP11=4.5
EP33=4.6
MP,PERX,1,EP11                    ! Relative PERMITTIVITY (X DIRECTION)
MP,PERY,1,EP11                    ! Relative PERMITTIVITY (Y DIRECTION)
MP,PERZ,1,EP33                    ! Relative PERMITTIVITY (Z DIRECTION)
/COM,  - DENSITY, Kg/m3
RHO=2651
MP,DENS,1,RHO                     ! DENSITY
MAT,1
TYPE,1
/PNUM,KP,1
KPLOT
K,1,-0.0005,0.0001,0,
K,2,0.0005,0.0001,0,
K,3,0.0005,-0.0001,0,
K,4,-0.0005,-0.0001,0,
K,5,-0.0005,0.0001,0.0002,
K,6,0.0005,0.0001,0.0002,
K,7,0.0005,-0.0001,0.0002,
K,8,-0.0005,-0.0001,0.0002,
V,1,2,3,4,5,6,7,8
ALLSEL,ALL
SMRT,1      !Specifies meshing parameters for automatic (smart) element sizing
MSHAPE,1,3D !0 is quadrilateral elements when2D or hexahedral elements when3D;
            !1 is triangle elements 2D or tetrahedral elements when3D.
MSHKEY,0    !free mesh is 0; mapped mesh is 1; free and mapped mesh is 2
VMESH,ALL
EREF,ALL    !mesh more
FINISH
/SOL
ANTYPE,0
DA,3,ALL,0
ASEL,S, , ,5
NSLA,S
F,ALL,FZ,1e-006
ALLSEL,ALL
SOLVE
 楼主| 发表于 2009-4-16 22:52 | 显示全部楼层
有做过石英梁压电分析的吗?帮忙看看!谢谢!
GMT+8, 2025-1-12 10:57 , Processed in 0.081394 second(s), 17 queries , Gzip On.
