查看: 1922|回复: 0
[Nastran专区] 求教一个warning,帮帮忙啊
发表于 2009-4-14 14:40 | 显示全部楼层 |阅读模式
做非线性分析,单元数量较多,f06文件中出现不少相同警告,某些节点刚度非正定说明什么问题啊,我找到了这些节点没发现有什么不对劲的地方啊。
*** USER WARNING MESSAGE 4698 (DCMPD)
     STATISTICS FOR DECOMPOSITION OF MATRIX KLLRH   .
     THE FOLLOWING DEGREES OF FREEDOM HAVE FACTOR DIAGONAL RATIOS GREATER THAN
      1.00000E+07 OR HAVE NEGATIVE TERMS ON THE FACTOR DIAGONAL.
     USER INFORMATION:
     THIS MESSAGE MAY BE IGNORED IF NO GRID POINT IDS OR HIGH RATIO MESSAGES APPEAR IN THE TABLE ON THE NEXT PAGE.
1    MSC.NASTRAN JOB CREATED ON 23-FEB-09 AT 16:03:45                         APRIL  12, 2009  MSC.NASTRAN  9/23/04   PAGE     7
0
0
         GRID POINT ID       DEGREE OF FREEDOM   MATRIX/FACTOR DIAGONAL RATIO        MATRIX DIAGONAL
             228                    T3                  -8.13190E+02                   7.14999E+06
             266                    R1                  -5.26420E+00                   2.01110E-02
            1654                    R2                  -5.07399E+00                   3.03653E-02
^^^ USER INFORMATION MESSAGE 9004 (NLSTATIC)
^^^ FOR THIS ITERATION, THE DIFFERENTIAL STIFFNESS WILL BE  IGNORED TO AVOID DECOMPOSITION OF A NON-POSITIVE
     DEFINITE STIFFNESS MATRIX.
GMT+8, 2025-1-1 14:46 , Processed in 0.076493 second(s), 18 queries , Gzip On.
